Results 1 to 12 of 12
    Apr 07 2004
    San Diego, CA
    Last time i ask about what suspension to get i swear.
    Okay im either gonna get, Koni Coilovers or the HR/Bilstein Adjustable setup. I can't decide. The price is the same. Cause i will install the CO's my self but i will have to pay to install the other setup. What should i get?
    "All the dude ever wanted was his rug"
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    eh? why would you have to pay to install the other setup? The install is more or less identical.
    Apr 07 2004
    San Diego, CA
    Actually my friend is gonna help me, he has CO's on his Honda, plus he is a mechanic, wouldn't it be harder to do the adjustable setup?
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    As far as labor goes, no. If you select a clip and then want it higher or lower,, yes. Since you will have to disasemble the whole thing and move the clip. You could also go with the Blisten Sports with ECSs budget CO system. Then you can adjust ride height just like a CO.
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    I did my own bilstein / Neuspeed race setup. I had never even touched a suspension in my life.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Registered Member Two Rings
    Apr 17 2004
    Greenville, SC
    The thing that convinced me to get the Koni coilovers is I'm too picky about the height I wanted. So I knew I would want the infinite height adjustment capabilities. Also the ride on them is comfortable, close to the stock sport but probably not aggressive enough for a track person.
    Installation with a friend is very doable but not so easy that I would be happy about having to un-re-install to adjust anything. Also things that went wrong for me were putting a hole in the CV boot and missaligning the abs sensor...
    Veteran Member Four Rings audidood's Avatar
    56 Oval, 2017 Tacoma
    san diego, ca
    dood get the coilovers. if you get the spring/shock setup and you're not satisfied with the drop, you'll wish you got the c/o's. besides, koni c/o's are height and dampening adjustable. shocks/springs is pretty much WYSIWYG, ya know?
    2004.5 USP A4 1.8t with mild mods.
    1956 VW Bug with major mods.
    san diego, ca
    but i'm going for springs and shocks cuz i'm getting a great deal on em. someday i'll get c/o's.
    Q7, Q7, F-type manual
    from a person who has had both, get the coilovers. if you dont, you will regret it later. install difficulty is pretty much the same for both. one thing with the coilovers, ask someone about setting the dampening rates before you install the coilovers, because once you do, you have to take them off to adjust the rates again. i or several other people can give you a good idea of where to start for the rates.
    Feb 16 2004
    99` a4qtip
    Nu York
    Hey by anychance is there a DIY on suspension install ?
    -=SiNeD=-
    http://img22.photobucket.com/albums/...AZsig_copy.jpg
    | Will work for mods !! | (Q'.')--Q(^.')> |
    there is one in the audiworld tech section. i am too lazy right now to find the link.
    Feb 16 2004
    99` a4qtip
    Nu York
    thnx i found =)
    -=SiNeD=-
