Results 1 to 22 of 22
    Veteran Member Four Rings 1 ate T's Avatar
    VW Jetta GT, 01 Eclipse GS
    Newark,OH
    A/C Compressor Tensioner...
    It broke off somehow... Anybody know if that tensioner comes off of the compressor? Or will I need to buy a whole new one...?
    Does anyone know what the socket size for the screw is down there?
    2000 A4 1.8TQM - Sold
    Will be back in an Audi this summer!
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: A/C Compressor Tensioner...
    IIRC there are two or three hex head bolts about 6mm. The tensioner is NOT part of the compressor.
    Newark,OH
    Do you know if I'll have to remove the compressor to get the tensioner off?
    Florida heat is a biatch, and it's only April... I was fine in Ohio, but my belt will not stay tight...
    Veteran Member Three Rings seatown88's Avatar
    Nov 28 2006
    66 mustang, 97 a4 1.8t
    seattle
    you dont have to remove the compressor to get the tensioner off
    Mar 04 2007
    nothing
    nowhere
    The only thing you may have to remove is the front lip spoiler. Would make things easier but not 100% needed I don't think.
    Registered Member Two Rings blackaudia4tk's Avatar
    Jan 20 2007
    99.5 a41.8tqm
    bradford
    this is kickin my ass i cant seem to get on it at all il have to try takin off the lip spoiler unless someone has a trick i only have like a inch of room between the intercooler pipe and the tensioner.... im hopin i dont have to pull the front end out to get on it and get it out any help?
    i changed the turbo today and was gonna do it at the same time but couldnt get it
    a4 1.8tqm
    car sold
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    All you have to do is jack the car up and take it off from underneath. No need to remove anything. I actually just replaced my AC compressor tensioner thinking it was bad only to find out the clutch on the AC compressor was bad so I am in the market right now for a new or slightly used AC compressor. Back to the thread topic, and as I mentioned before you do not need to remove anything and purems has that part in stock and I usually get my parts from them in a day or two. It might be a little longer for you but they have good prices.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Registered Member Two Rings audi1888t's Avatar
    May 07 2007
    BOston
    yepp it just happend to my car two weeks ago
    Jan 20 2007
    99.5 a41.8tqm
    bradford
    what tools did ya use i tryed again today and i can get on it with a old style allen wrench but it wont turn at all pisses me off
    a4 1.8tqm
    car sold
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    it only has to hex bolts, i cant recall what size, its totally independent from the compressor.
    1 ate T= where have you been BTW.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Nov 28 2006
    seattle
    i had to use a little leverage action to crack them loose, i used a small pipe on the end of the allen just be careful not to strip them, it is a real pain when that happens, trust me i know
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Use a 6mm allen and a cheater bar - use something like a hollow pipe to give you better leverage and then go for it. thats what you have to do. Mine is getting here on Thursday from ECS so I'll be doing the same job -
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    DONT ROUND OUT THE ALLEN HEAD!!!! Unless you dont want A/C for a few more days :)...
    Use a a 6mm allen head socket, hold that socket tight into the head, and get a hammer a hit the ratchet to break the loctite.
    I just had to retension my belt as I just replaced it. MUCH MUCH MUCH easier to take the front bumper off and loosen the support upfront. The whole support swings forward about 8-10 inches and gives you more room to work with. but if you like bloody knuckles go for it...
    Josh
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The core support slides forward about 3". An allen bit and a 1/4" gearwrench will get you right in there and eliminate the need to constantly reposition the 'L' allen wrench.
    Jim
    I Do Werk.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    mmm.... yea 8-10 inches was an exaggeration. I know I was able to put a 2x4 piece of wood inbetween the snub and its mount to get some more room down there, so maybe you gain 3-4 inches. It seemed like 8-10 inches since tehre is SOOO much room to work in down there... NOT
    josh
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    As mine had been off before,it was easy to move mine with a long 6mm allen key and a bit of pressure.It is fiddly,no doubt
    As stated DO NOT round that baby out or the whole front will need tp come off
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Jan 20 2007
    99.5 a41.8tqm
    bradford
    so a guy at work finaly got it today those bolts just wouldnt come loose but it only takes 2 bolts to drop the ac compressor and then take off the turbo brace and 3 bolts i think and the whole piece that its attached to can come down then we threw it in a vice and changed it so if ya rounded them over no need to take ur front end off just thought i would share..ps my car is so quite now love it that thing was makin so much noise (who ever said 5 mins should work for audi )
    a4 1.8tqm
    car sold
    Oct 27 2006
    Fargo, ND
    Yeah - just did mine like 20min ago - very simple - if you can get the bolts loose. took me maybe 30 min to R&R
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    i was able to get an allen key in there but i couldnt turn it. i got a long small socket from my ratchet and put it over the key and was able to turn it. how the hell did you break the tension? i get it tight i hung from it, it wasnt going anywhere.
    Jan 20 2007
    99.5 a41.8tqm
    bradford
    i had to cut the belt and take the whole bracket out it just wouldn't come loose
    a4 1.8tqm
    car sold
    Newark,OH
    Quote Originally Posted by pipe7284 View Post
    sorry man, lol I fell off the Earth.
    Ok so the heat here in Florida without A/C is kickin my ass. Anyone got the link to the part?
    Mar 04 2007
    nothing
    nowhere
