Results 1 to 23 of 23
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    Need logs from DBW guys
    Im trying to diagnose my k04 problems, any DBW guys have a log of block 054? Thanks.
    2013 S7 Phantom Black on Black diamond - loaded
    2009 Audi R8, Black on Black w/ Blown V8 and black ADV.1 7.1's. (Carbon, Alcantara, Etc.) - Sold
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential - Traded.
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Re: Need logs from DBW guys
    Quote Originally Posted by TurbousMaximus View Post
    I don't have any logs, but what is the problem you are having or think you might be having? Throttle cut?
    "You know you have a bad idea when Ford guys are making fun of you."
    Aug 25 2004
    Whitehall, PA
    This is a WOT run. Ever since i put my k05 file on the k04 its been surging and running bad.
    Apr 18 2007
    Orange Park, FL
    Hmmm. What injectors are you running? How is boost regulated? Do you let the n75 control boost or do you use an MBC/EBC? If you have a boost gauge, what is it doing? Is boost fluttering all over the place?
    Aug 25 2004
    Whitehall, PA
    Im running the stock injectors with the 5 bar fpr. Its running real rich, -21.7 fuel trim. The n75 is the F valve replaced not to long ago, no mbc or anything. Boost fluctuates a lot and if i ease into the throttle even at around 5psi it jerks and feels like its hitting a wall. When i flash to the stock file everythings smooth.
    Apr 18 2007
    Orange Park, FL
    Sounds like you might be maxing out your injector duty cycle. I had a similar problem with my car. Boost would fluctuate because the ECM was cutting throttle since the injectors were maxing out. Replaced the injectors with something a little bigger and all was gravy. Probably the best option for you would be to run TT injectors or possibly some 415cc injectors from USRT.
    Aug 25 2004
    Whitehall, PA
    yah but a bunch of other guys are running the same set-up with optimal results.
    Aug 25 2004
    Whitehall, PA
    anyone?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by chris164935 View Post
    Chip was tuned for stock injectors and 5 bar fpr, it has been sold for many years now and plenty of people have used it without any issues.
    What we are trying to figure out is if the ecu is closing the throttle at this point since his 054 log should read 100/100 the whole time he is at WOT but it doesn't. Right now we just want to see some other logs of 054 on a dbw car so we can figure out if his vag software just has the wrong labels for the TB and pedal. IIRC it was always the throttle body plate postion on the left and the pedal position on the right, but we just want to double check that because I lost all my dbw logs of block 054 on my other computer when it crashed.
    Apr 18 2007
    Orange Park, FL
    Well, something is causing his throttle body to close. He told us that he did a log at WOT. So, the block for pedal position would be the one that is at ~100%. The only difference we would see between his log and the log of a properly running car is that the properly running car would have WOT in the Operating block, and ~100% in the throttle position blocks. Which would just tell us that the ECM is closing the throttle body.
    Are you using the proper-sized MAF housing? Any DTCs stored in the ECM?
    Jul 07 2004
    socal
    Yes all the parts are stock parts that are used for this chip. No DTC's that would cause this issue.
    Apr 18 2007
    Orange Park, FL
    Who makes this file? Might be best to ask them for help.
    Jul 07 2004
    socal
    GIAC. It is the K05 file which is basicly a detuned tune of the J31 monster file.
    Aug 25 2004
    Whitehall, PA
    Operating block never read WOT from what i recall.
    Apr 18 2007
    Orange Park, FL
    Maybe have your shop reflash your ECM?
    Jul 07 2004
    socal
    That is one of the things he is going to try, but AWE cant get him in till the 1st.
    Apr 18 2007
    Orange Park, FL
    Tell them they f'ed it up. You shouldn't have to wait that long for them to fix their mistake. Especially if it only takes like 10 minutes tops to flashload an ECM.
    Jul 07 2004
    socal
    Well he should just drive in, pop out the ecu and tell them to reflash it right there.
    Apr 18 2007
    Orange Park, FL
    They don't do flashing through the obd2 port? I don't see why they wouldn't be able to do a 10-20 minute job for a customer who already paid for a flash that didn't take very well; or they loaded the wrong file.
    Jul 07 2004
    socal
    Yeah they can, but the can also do it right on the bench using a special cable.
    Apr 18 2007
    Orange Park, FL
    Cool. Yeah, I know about the tool, was thinking of making one myself. I just thought they didn't really do bench flashing anymore, unless you have to ship your ECM off to them.
    Jul 07 2004
    socal
    Well he wouldn't want to give them any reason not to walk their butt outside to his car now would he?
    Aug 25 2004
    Whitehall, PA
    hahah yah, i think they want to try and diagnose the problem to charge me. Im just going to call them again and tell them i want a reflash.
    Here are my plugs after i pulled them out today. Cylinder 1-4 from left to right. I wiped a lot of the oil off of them, but 3 and 4 didnt have much. Pics are kindda crappy(phone) sorry.
