Thread: Master Cylinder
    Feb 17 2004
    Master Cylinder
    How can I tell if my master cylinder needs to be replaced? Is there anything I need to be aware of to test?
    TIA
    Registered Member Two Rings a4sport's Avatar
    Feb 13 2004
    doritos
    brake? please explain...do you have leaks visually?
    Feb 17 2004
    Sorry...yes the brakes...no visible leaks...however, I'm experience other problems and want to eliminate the fact that it's not the master cylinder.
    Feb 13 2004
    doritos
    what kind of problems are you encountering? need details if u want help...
    Feb 17 2004
    I posted another thread about my brakes engaging and disengaging constantly under both hard and normal braking.
    I figured it could be the ABS system, but I wanted to be sure it's not anything else.
