Results 1 to 15 of 15
Thread: rear sway bar
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    rear sway bar
    hey guys im going to be putting in my intrax rear sway bar today, is there anything i should know ahead of time like any special tools or anything or if i should be prepared for something. let me know.
    Registered Member Three Rings S-fear's Avatar
    Feb 12 2004
    S4, A4 1.8T, Subaru Legacy, supercharged Miata, Turbo Alfa (top 10 in GRM $2000+ challenge). UR Quat
    SE MI
    Yeah, if you have any rust on the end links, you are going to have a hard time getting the nut off. It can be a nightmare.
    I ended up using lotsa liquid wench. I also took a second nut of the same size, and put it ON the end link. This had the effect of cleaning the threads on the bolt. I don't think I would have gotten the original nut off without this extra step.
    There has been more written on this if you want to do a search...
    Jeder Bloedmann faehrt 'nen Porsche, Jeder Arsch 'nen Audi Sport
    Nur Geniesser fahren Fahrrad, Und sind immer schneller da
    Q7, Q7, F-type manual
    Yeah, the endlinks can be a real pain in the ass. Soak them with some lubricant the day before you want to put the new sway bar in and it should help a little. Other then that, it is a pretty easy job.
    Veteran Member Four Rings Audi_Sniper's Avatar
    01 & 04 Audi A4 1.8t quattro
    Buffalo, New York
    Ditto
    It can be PITA
    Bringing the Great Lakes Regions Together
    http://www.greatlakeseuros.com
    BetaAlphaTau Member # 30
    The toys:
    01 Audi A4 quattro APR stage III (Fast and tight like some of your little sisters)
    04 Audi A4 quattro (Der neue tägliche Treiber)
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    GREASE THE BUSHINGS.
    Feb 17 2004
    Montreal
    what kind off grease do you usually use forthe bushings ???
    Feb 12 2004
    99.5 1.8T A4
    Cleveland OH
    how much was the intrax sway?
    Feb 13 2004
    Lakewood, CA
    i baught it slightly used for 80 bucks then i had to buy new end links wich cost me 50 at hartman. so 130 total. its in dam,n good shape
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    nuespeed has their own "special" grease, but i called them up and they said it would be fine if i just used regular marine lube (used for trailer bearings and other grease fittings and stuff). yuo can get it at any hardware store.
    Feb 17 2004
    Montreal
    Thanks
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    dumb question, but what does a rear sway bar do
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Veteran Member Three Rings rbt's Avatar
    Feb 25 2004
    Tracy
    Just so you know, your car already has'em, on the front and rear axles. It links the left and right wheel corners somewhat,, so that the net effect is that during a corner your car doesn't lean as much, it stays more 'planted'. the discussion here surrounds replacing stock SB with a stiffer one, which resists twisting more. it provides a greater effect on keeping the car level during cornering.
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    is that refering to body roll.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Washington DC
    yes
