Results 1 to 13 of 13
    Feb 17 2004
    Braking problem...need help
    When braking, it feels that the rotors are wharped...so after I changed it, the problem wasn't solved. During braking, it feels like the brakes are engaging on and off...any clue to as to what this could be?
    If it's the abs system, what can I do to replace it or resolve the problem?
    TIA
    1999 A4 1.8TQ
    San Jose, Ca
    Its the ABS. Thats how it works. Theres no fix or resolve. Well you can stop tailgating and braking so hard.
    May 20 2004
    More cars
    Never Land Ranch
    LOL
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    Haha,, yeah it sounds like the ABS.
    But if it is happening all the time you probably have air in your system. Or a bad ABS sensor.
    Registered Member Three Rings
    May 28 2004
    00' VW MKIV GTI GLX
    PNW - 509 reppin' hard
    I swear, our cars brakes are the worst at stopping the car. Isn't that what they were meant for? ;-)
    Whenever im braking and coming to a stop, if I hit a pot hole in the road or a really rough spot, the brakes feel like they stop working. It's hard for me to stop, because it feels like the ABS is preventing me from getting any brake pressure so I have to let off the brakes, when I do, i can then re apply and the brakes are fine. If this is the ABS its not very safe, unless mines broke. But I don't have the abs light on.
    SOrry to hijack, but anyhelp would be appreciated.
    MKIV GTI GLX
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    How hard are you guys braking??
    May 28 2004
    00' VW MKIV GTI GLX
    It will do the shit im talking about if im braking hard or soft. Generally though, I get that type of feedback when im somewhat hard. It really is dangerous though, if I needed to stop, say if a car was infront of me, and I hit the brakes, it would not properly slow the car down, i'd have to let off, and re-apply. :(
    MKIV GTI GLX
    Somewheretown, PA
    Try flushing the system out with a good brake fluid. Make sure you get all the air bled out and all the old fluid.
    May 20 2004
    More cars
    Never Land Ranch
    If there is time, and while you are hitting the brake, put car in gear and slowly let off the cluth and or Ebrake also
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Feb 17 2004
    I'm getting the feeling under both hard and soft braking....I'll try flushing out the system.
    Where is the abs sensor? Maybe I need to clean it?
    May 28 2004
    00' VW MKIV GTI GLX
    I'll flush my system this weekend.
    MKIV GTI GLX
    May 20 2004
    More cars
    Never Land Ranch
    ABS is located behind the rotor. If youare looking at the drivers side its on the left and on the Pass. its on the right. Its a plug.
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    May 28 2004
    00' VW MKIV GTI GLX
    Anyone know a write up on how to flush the brakes?
    MKIV GTI GLX
