Results 1 to 17 of 17
    Registered Member Two Rings suttonb3's Avatar
    May 29 2004
    RX8, Aprilia RSV 1000
    Tampa, FL
    Staggered Wheels
    What are the advantages/disadvantages of using a staggered setup on a car? I understand the basic idea on drag cars, but why do people us it on an AWD car? Is it safe to use on one? Here's a potential setup, any input as to whether it's safe, tires will rub, anything that a newb like me should know would be appreciated:
    1999 A4tq stock (non-sport) suspension
    Front: 18x8 42mm offset 225/40/18
    Rear: 18x9 35mm offset 255/35 18
    Thanks in advance!!
    Ben
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    To me staggered wheels only really look good on cars that have fender flares to constitute the wider wheel.
    A TT would be perfect for a staggered wheel setup., you get the idea.
    789whp
    Mar 21 2004
    Temecula, CA
    Other than appearance, there's no real reason to put staggered wheels on an all wheel drive car.
    You'd do it on a rear wheel drive car to provide a larger footprint for the driven wheels.
    His: 1989 VW GTI 16v
    Hers: 1999.5 Audi A4 1.8tq Tip
    Turn 2 Photography
    May 29 2004
    Tampa, FL
    Thanks guys, I thought it was probably just an asthetic thing. The reason I bring it up is because I've found a brand-new set just like the example I gave in my first post with the tires mounted and balanced for $1,100 vs $289/ea for the wheels alone on websites like tirerack.com (sorry Oscar!) or rimstop.com. So to save myself several hundred dollars I'd be willing to go with that setup as long as I wasn't going to do any damage.
    May 29 2004
    Tampa, FL
    No other input on this topic?
    Veteran Member Four Rings A4_Andre's Avatar
    Feb 13 2004
    99.5 Audi A4 2.8Q Tip
    Staten Island, NY
    i dont really like staggered setups... i like consistency with my wheels
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    I am running staggered 18x8 18x9, but the reason I am doing it is to get a bigger lip in the rear. I couldn't put a 3inch lip on an 8inch wide wheel, so I bumped it up to 9 inch wide to give me another inch or so of lip. Its all preference. But just make sure your suspension isn't TOO soft and your not TOO low in the rear otherwise you may have problems with that 255. By the way I would double check the offsets that you have listed just incase before purchasing.
    Veteran Member Four Rings Starting's Avatar
    Feb 13 2004
    98 A4 1.8t
    Central, NJ
    isn't there more oversteer/understeer with a staggared setup. idk thought i heard that somewhere
    Feb 24 2004
    02 S4 & 67 Goat
    So Cal
    Yeah I've heard it too, but honestly I've gotten loose with my stockies and these. I'm sure most people don't even feel a difference. Of course I the wheel set up I have isn't for tracking so I don't see it as a performance loss, even if it did affect steering.
    Veteran Member Four Rings almaster666's Avatar
    Jan 24 2005
    San Mateo, CA
    i am bringing this thread back even though it is quite old
    to say that you are more likely to get understeer with staggered... i think
    Nissan: 2012 Frontier 4x4
    Honda: XR200R, CR85 Expert and CRF250R
    Kawasaki: KDX250
    Polaris: 2011 PRO-RMK 800 155"
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    I have a staggered set-up, just for the looks though. I havent noticed any under-steer issues, my rear-diff is fine and it wont cause any problems. Trust me, and dont let anybody tell you other-wise. Ive asked the dealer and there isnt a big problem with running it. I have 18x9 inches wide in rear and 18x8 in front.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    SuperbSantorin4's car is awsome i didn't think you could fit 18x9's ? how big can u get without modification last time i looked under rear wheel i wcouldn't fit my finger behind an arm of somekind don't no what it is ?
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    Jan 24 2005
    San Mateo, CA
    what size tires?
    Kawasaki: KDX250
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    225 40 18 front
    235 40 18 rear
    and there is 0 rubbing. I dont think you could go much wider thatn that though.
    MITCH
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    heres my favorite pic to whore out.
    MITCH
    Jan 24 2005
    San Mateo, CA
    hmm, thats cool
    so far as the rubbing goes, my gf's dad had 245/40/17s which didnt rub but defintely dont handle as well as 225s
    i wanted to put 265s in the rear on my camaro, but thats besides the point
    Kawasaki: KDX250
    Jan 24 2005
    San Mateo, CA
    its this one:
    Kawasaki: KDX250
