Results 1 to 32 of 32
    Senior Member Three Rings b5power's Avatar
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Car shutting down...plz help!
    Well today i was on my lunch break, when i was driving my rpm starts to bog up and down i was like,"WFD!"then shuts off at a complete stop and did this for awhile too, thank goodness i was able to make it back on time.lol. All i can think of was the the spark plugs or coil packs or even be the GIAC CHIP (recently installed from AWE_TUNING). I've heard that if the chip wasnt soldered well enough it might mess up the car. is that true? correct me if im wrong.please help me. any suggestions. thanks
    euroBREED
    ASP Stage 3
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Car shutting down...plz help!
    are you getting a CEL? have you checked for codes?
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    yeah i have a CEL, im going to autozone tomorrow to check for the code. hopefully its nothing major.
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    well just got home, got in my car, turned the key, the car turned on and 3 seconds later it just shuts off. whats wrong. now i can even drive my car to autozone. gez!
    euroBREED
    ASP Stage 3
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    5spd or tip?
    Do you have a boost guage?
    Without more information (like fault codes) it's hard to diagnose, but I would first check the bypass valve. Since it's easy to replace and relatively cheap.
    Senior Member Two Rings DTMGuy's Avatar
    Jul 24 2005
    98.5 Audi A4 1.8T Quattro, 04 Nissan Armada
    Alhambra CA
    this happen to me recently... it turn out to be my MAF...
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Its tip and unfornately i dont have a boost gauge, well just 5 minutes i was able to pull in my garage after like 7 minutes of trying. gezz! well i took out the ecu and took off the top part to see if the chip was soldered good and it looked good to me, should i look out for anything else when i see if it was soldered properly. i diconnected the battery, throttle. MAF.
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by DTMGuy View Post
    how did you know it was you MAF did you get a code?and did you clean the MAF or replace the MAF?
    euroBREED
    ASP Stage 3
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    if you disconnect the maf and the car still doesn't turn on, then its not the maf.
    2013 S7 Phantom Black on Black diamond - loaded
    2009 Audi R8, Black on Black w/ Blown V8 and black ADV.1 7.1's. (Carbon, Alcantara, Etc.) - Sold
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential - Traded.
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
    San Jose, CA
    i would say that its your ecu. sorry.
    do u have a 2nd ecu or can somebody lend u one for a day or so
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    I dont know about the rpms going up but if they are going down and your car seems to die at idle it may be a large boost leak.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by Ado View Post
    deng, nah i dont have a 2nd ECU or anyone to lend me one for a day : (
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by DeanUW View Post
    yeah i do have a boost leak somewhere i thought i found it and fixed it but i guess i ONLY FOUND ONE of them...
    euroBREED
    ASP Stage 3
    Feb 22 2007
    Auburn, WA
    Hmm, I'm still not 100% sure its a boost leak due to me not having all the facts and witnessing the symptoms myself but did this problem start off not too bad and increasingly getting worse till you cant really drive it at all?? Do you have any Intercooler work, FMIC, anything from hot side or cold side of intercooler that may become loose?
    Feb 27 2005
    North Wales, PA
    you could have blown off a hose off the IC or off the turbo with the increased boost.
    Washington DC
    I doubt it's your ECU. But you could always post on your regional forum and see if some one with a similar engine can stop by for 20min and swap for a second so you can rule it out of the equation.
    I would check every vacuum hose to make sure that nothing is disconnected or breaking apart. Might as well invest in a boost gauge now.
    Registered Member Two Rings B5-B_Broke's Avatar
    Apr 11 2007
    FlORIDA
    theres a great boost leak test check out http://fix your shit has a bunch of other walk throughs with the maf some say to use alcohol and put it in a bag and swish lightly and let dry over night i just bought the maf spray cleaner it works great. but check the vacuum hoses and i doubt a leaky DV would do that. and if it was stuttering real bad then you might have a real bad misfire.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Thanks everybody
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    yeah at 1st is wasnt too bad than it got worse like within 5minutes and i had to keep stepping on the gas, you know, everything is stock except the chip and i 've been having to drain OIL out of my intercooler hoses : ( for quite awhile now. o i have a stock IC.
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by B5-B_Broke View Post
    yeah ill problee do the boost leak test, hopefully find out whats happening. how do i check if i have a bad misfire? because at some point when i was trying to go, it sounded like a mis fire.
    euroBREED
    ASP Stage 3
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Sounds like a boost leak to me. When I did my FMIC, I kept blowing hoses off when I went for test runs and the car acted exactly like you described when I blew the hose off. The RPMs would go up and down and the car would barely run or just flat out die.
    Oct 30 2006
    05 Mini Cooper S
    I think its the ECU as well, sounds exactly like the same problem I had, would start, then turn off, crank and not turn on at all, eventually it would start again, run for a little then turn off again. GIAC could've messed up the solder, that or the ECU just plain failed, it happens.
    -MilitantGrunt- Certified Audi Dealership Technician
    -05 R53 Mini Cooper S
    -F30 Estroil Blau 335 Xdrive M Sport 6spd. -Sold
    -Brilliant Red B6 A4 Ultrasport 1.8t Avant 621whp - RIP
    https://www.facebook.com/auditech/
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by Militant-Grunt View Post
    just wondering if its possible by just lookin at the chip if it was soldered unproperly?
    But really i hope its not my ecu. : ( or even at that hope the ECU didnt fail on me. Im going to Home Depot today and makiing a boost leak tester...
    euroBREED
    ASP Stage 3
    Oct 30 2006
    05 Mini Cooper S
    Quote Originally Posted by b5power View Post
    I couldn't tell, everything worked fine after I put in a stock ECU.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    do you guys think if i send my ecu back to AWE TUNING, they'll do it free of charge?
    euroBREED
    ASP Stage 3
    Established Member Two Rings Hugh Jass's Avatar
    Sep 25 2006
    C4 Avant.
    Portland, OR
    http://www.audiworld.com/tech/int6.shtml
    Code 1.
    It will give you the code for your check engine light.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    well i found a boost leak from a vacuum hose connecting to my 710n, so im guessin its the ECu : (, im going to ship it today. and hopefully that will solve my problem.
    euroBREED
    ASP Stage 3
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Just Vag my car
    codes:
    PO300(random misfire)
    PO301(Cynlinder 1 misfire)
    PO303(Cynlinder 3 misfire)
    PO102(MAF Circuit Low Input)
    I just called AWE-Tuning, and they said non of those have to do with the ECU.
    Thay said it was either coilpacks and MAF, so ill go from there.
    Any suggestions? Thanks
    euroBREED
    ASP Stage 3
    Washington DC
    swap the coil packs around to see which ones could be failing.
    Jan 14 2007
    B5 1.8T
    Las Vegas, NV
    Quote Originally Posted by Zodiak View Post
    Well the VAG displayed that it was 1 and 3 that are failing
    euroBREED
    ASP Stage 3
    Apr 11 2007
    FlORIDA
    check your cel code and then play musical coil packs and see if it follows the coil pack and theres your misfire
    Jul 24 2005
    Alhambra CA
    see i didnt get a CEL at all.. my mechanic said it was my ECU but after doing some more test it turn out to be my MAF and had to be replaced.. and now the car runs way better
