Results 1 to 13 of 13
    Mar 05 2004
    PA
    Car won't start.
    I have a '98.5 a4 1.8tq and yesterday the check engine light went on during my drive to work. Now this morning my car won't turn over at all. The battery is strong and will crank fine. Just won't fire up.
    Any ideas on what it could be, or how to diagnois the problem?
    And I was going to advanced auto so they can do their free check engine code check also.
    This sucks.
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    Have somebody vagcom the car.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Mar 05 2004
    PA
    What is that?
    Sigless...
    Mar 27 2004
    2001 A4 1.8T
    PA
    VAG stands for Volkwagen Audi Group. VAGCOM is a tool used to check the codes in your cars computer.
    2001 A4 1.8TQMS - SOLD
    Mods: APR 93 octane, Milltek Catback, 710N, V&S SS, RS4 grill, RS4 reps, Sport Seats, AWE DTS, Neuspeed 19mm w/ metal end links, S4 wheel liners, PureMS Strut Bar
    Convenience: "one touch up" rear window mod, PhatBox
    my Member Gallery
    Mar 05 2004
    PA
    Do you need a special one? I'm pretty sure last time we used the regular OBD computer at my work. I just didn't have time Saturday to run it.
    Sigless...
    Mar 05 2004
    PA
    I checked the spark, and there is a good one. How do I check if it is getting fuel?
    Where is the fuel filter? Is the fuel pump in the tank?
    Sigless...
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    Coolant Temp Sensor maybe
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Mar 05 2004
    PA
    why would the coolant temp sensor make the car not start?
    A couple months ago, the engine light came on and it was for the coolant temp sensor. I went to change it, but the parts place sent me the wrong one so I put the old one back in. The light went out so I left it go. About 3 weeks ago, however, the coolant temp guage stopped working. Think its related?
    Still, why would the car not start for that?
    Sigless...
    Mar 05 2004
    PA
    Good guess man.
    It was the temp sensor.
    Does the car have a system where if the sensor isn't working, the car will not let it start so it won't overheat?
    Feb 17 2004
    Sterling, VA
    There really is alot of parts to check on this type of problem. I stongly suggest you get someone to plug in a code reader before you bother troubleshooting by other means. You'll save alot of time and prevent a mis-diagnosis of the issue.
    Autozone usually lets people rent or borrow a generic code reader for problems like this. It's worth a shot if you don't have access to a Audi dealership or a VAG-COM PC.
    Post some codes and we can post some remedies.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Feb 13 2004
    <> Posts: 9913
    Actually, that's not what VAG means. VAG stands for Volkswagen AktienGesellschaft. (The translation for AktienGesellschaft is corporation).
    Another fun fact: The 4 rings stand for four companies that banded together to survive Germany depression porst WWI.
    -Theodore Roosevelt, 1907
    Indianapolis
    Originally posted by no1hustller
    Good guess man.
    The coolant temp sensor tells the car how much fuel is needed to start the car. More fuel is sent to the combustion chamber if the engine is cold. If the sensor malfunctions it can either send too much fuel (flooding it) if it thinks the car is cold when it is actually warm, or not enough fuel for a cold start if it thinks the car is already warm.
    I had this problem before. Its a nice $30 easy repair. I could usually start the car with this problem by pressing the gas pedal to the floor and after cranking the car about a dozen times it would start.
    2019 S4 Prestige
    Veteran Member Four Rings Wholsea's Avatar
    1998 Audi A4 1.8tqms
    Blacklick, OH
    Hmm, maybe mine is going bad. Had a flooded engine a few weeks ago, and recently it has coughed at startup...
    1998 A41.8tqms
