Results 1 to 6 of 6
    Active Member One Ring jlew's Avatar
    Dec 12 2006
    Stamford, CT
    Question Sounds like a marble is rolling around in my dashboard. DRIVING ME NUTS!
    (posted on AW also...)
    So, here's what I'm hearing... it sounds like a marble (or more likely a screw or bolt) rolling around INSIDE the dash. I hear it from the passenger side anywhere from the center of the car to the side window. It is NOT something in the glove box as I totally removed it from the car and am still hearing it. It actually sounds higher up... closer to the base of the windshield. Is there a way to safely remove the pass. airbag? Would I need a VAG to put it back?
    I've pulled out a couple of the vents and peaked in with a flashllight but havent' found anything yet.
    Since the car is under warranty I can bring it in, but I'm worried that if by some random chance something fell in (no idea what or how), that I would be charged a ton in labor pulling the dash apart.
    Has anyone experienced this (or similar)? Suggestions? Does anyone have a tips? A diagram of the air vents?
    THANKS!
    Mind the Gap
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    Re: Sounds like a marble is rolling around in my dashboard. DRIVING ME NUTS!
    I have... it was very faint and went away. It just sounded like like a slight vibration or something inside the dash.
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Is it a bunch of peanut M&M's?
    Veteran Member Three Rings 08lichmanj's Avatar
    Nov 18 2006
    PA
    Quote Originally Posted by chrislane31 View Post
    Hahaha, best movie ever!
    2006 A4 2.0t Quattro 6 Speed
    Tein Basics-20% tint-18x8 Privat Reserv-VMR Testpipe-Revo Tuned Stage 2
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    It's ok, they have a thin candy shell.... suprised you guys didn't know that...
    789whp
    Deactivated Three Rings Coker Rat's Avatar
    06 2.0T A4 w/quattro
    Fort McMurray, Alberta
    LOL, i was thinking the exact same thing
    You didn't give Chris Farley a ride did you? ...Wait, I guess you would have bigger problems if that was the case.
