Results 1 to 2 of 2
    Mar 01 2004
    Remove front seats
    How can I remove them to clean the carpets? Also can carpets be removed and shampooed at home?
    KM
    KONTESTO
    2008 AUDI A4 2.0T
    Mar 27 2004
    2001 A4 1.8T
    PA
    It's pretty easy really. The hardest part is getting them out without scratching anything. I am assuming you have manual seats for these instructions, I think power seats are probably even easier. First off, I would recommend putting the seatback back far enough so you can remove the headrest. This will give you more room to work with to get the seat out of the car. Then there are 2 screws and plastic pieces at the back of the rails that you remove. The one towards the middle of the car has a little cap over it that you have to remove before you can see the screw. Then there is a little clip in the front on the center rail. Remove that and the little piece of rubber. Then look under the seat and disconnect the wiring harness connectors. Now you can just slide the whole seat backwards out of the rails. It takes a little coercing to get it out because it's a tight fit. You have to work it past the little bits of carpet at the end. Once you've got it out of the rails, BE VERY CAREFUL when removing it from the car. The edges of the seat rails can very easily scratch up the plastic bits and door sills. The seats are heavy and awkward, so take it easy while lifting them out. I tried to rush it and I scratched up the previous mentioned bits.
    2001 A4 1.8TQMS - SOLD
    Mods: APR 93 octane, Milltek Catback, 710N, V&S SS, RS4 grill, RS4 reps, Sport Seats, AWE DTS, Neuspeed 19mm w/ metal end links, S4 wheel liners, PureMS Strut Bar
    Convenience: "one touch up" rear window mod, PhatBox
    my Member Gallery
