Results 1 to 9 of 9
    May 13 2004
    New Jersey
    Door Handle Swap (Rear to Front)???
    Im trying to install rear left door handle on the drivers door for security purposes, did anyone do this before, is it easy swap? or is there something that has to be done at the body shop, any suggestions, and help greatly appreciated.
    thanks guys
    Registered Member Two Rings
    Jun 20 2004
    South Carolina
    just curious... but how could that be for security purposes?
    mom's car: 2002 S4... my next car: can't decide
    http://www.audizine.com/gallery/data...2555audi-2.jpg
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    I was thinking of that myself! It would look trick and deter theives. I will do this to my s4 as soon as the body comes time to complete(i am doing the motor right now rsko4/16plus) I wish someone could do a write up!!
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Four Rings Imperial's Avatar
    Köln / Cologne - NRW
    I've heard of some doing that because the keyhole on the driver's side door is a security risk due to some design flaw. Someone was telling me once about just how easy it is to get into the car and bypass the stock security system via that keyhole, so replacing the driver's door handle seems like it'd be a good way of protecting against that. Just better hope you don't ever lose your remote
    PLVS VLTRA
    Veteran Member Four Rings cj-S4's Avatar
    Not enough space here
    Somewheretown, PA
    All you have to do is remove the rod that goes from the lock. Rendering the key hole useless. Besides they don't use the key hole,, they punch a hole in the door near it, then they grab the rod and unlock the door.
    May 13 2004
    New Jersey
    thanks,
    bud did any one do the door handle swap, is it easy, any instuctions
    Oh? You know how to do that exactly? Cuz if so, you might have to help me out with that soon
    Feb 21 2004
    Bay Area
    Bling
    A body shop did it so I can be of no help
    Somewheretown, PA
    Yes, its pretty easy. Just remove your inner door cover and you will see the rod. It is held in place by clips on either side, remove the clips, remove the rod, replace door cover, done.
