This may help people that are concerned about how hard it is to adjust Koni coilovers UP while they are installed on the car.
Luckily my coilovers were "almost" perfect when we installed them (2" of thread below the perch in the fronts, 1.5" of thread below the perch in the rear). However I wanted to move the fronts up about 1/4" to get my perfect look. I tried to do this twice and couldn't move the perch more than 90 degrees. The problem was the perch would not slide under the spring but it would "twist" the spring making it very difficult to make progress as the spring would just "un-twist" and move the perch back to where I started.
My solution was to relieve the pressure at the point where it was digging into the perch so I could slide the perch under the spring. To do this I bought a small ratchet vinyl strap at Home Depot. I used this to slightly compress the spring where I thought the greatest pressure was. Once I did this I had no problem moving the perch up 4 full turns. Here are some pics:
I tried to get the strap as close to the end of the spring as possible:
Before compressing spring:
After slight compression:
