Results 1 to 26 of 26
    Stage 3 Forum Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    Lathrop, CA
    NEW! "solid" LINKAGE UPGRADE now selling (from JHM)
    Introducing the JHM "Solid" Linkage Upgrade for the B5 A4 and Passat.
    This upgrade is the most bang for your buck to make your B5 A4/Passat shift with more precision and feel. Intro price at only $89.99! Our test car saw a reduction in slop when shifting by more than 60%. It works with any stock or aftermarket shifter, for best results our shifter is recommended.
    View the tell all comparison video to the stock linkage here: http://audishifter.com/videos/JHM_B5...parisonWeb.wmv
    Buy yours here:https://www.shop.jhmotorsports.com/d...&categoryId=21
    All the details on our site here: http://www.jhmotorsports.com/products/linkage.html
    Install instructions here: http://jhmotorsports.com/products/do...ge_install.doc
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: NEW! "solid" LINKAGE UPGRADE now selling (from JHM)
    wow, crazy that this will make your shifter feel even better. cause i love how it feels already..
    definately buying this.. keep up the good work
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    i cant open the page for whatever reason. whats the price on that, i want my hands on one of those.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Looks like a good addition to any short shift kit...but any chance you'll be offering free shipping...the UPS Ground costs are almost $15 from CA to PA.
    Aug 23 2005
    Lathrop, CA
    Quote Originally Posted by sean1.8t View Post
    Thanks, I plan on it.
    Quote Originally Posted by pipe7284 View Post
    $89.99. Is the page working for your now? Try just navigating my store. http://shop.jhmotorsports.com
    Quote Originally Posted by EuroA4 View Post
    Try USPS priority. It is only $9. You gotta remember I need to insure and track all my packages. Now you save 6 bucks for 2 gallons of gas. gas prices =
    Feb 12 2004
    PA-NJ
    Fair enough...I ordered one...and I'll give full feedback on install and results as soon as its installed. Thanks.
    Nov 24 2006
    Ottawa
    How easy are these to install?
    Aug 23 2005
    Lathrop, CA
    Got your order. I will get it out on Monday. Thanks.
    Quote Originally Posted by vdub_15 View Post
    Here are my instructions. If you think you can remove the shifter rod (2 bolts) one in the car and one underneath. Then some drilling of aluminum rivets. See these instructions also check the link on my first post for all the info.
    http://jhmotorsports.com/products/do...ge_install.doc.
    Then when done put the rod back in and readjust your shifter.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    I've been prototype testing this unit for the past 2 weeks. It is a work of art. Not only is the shifter physically stiffer in gear, but the shifts are a lot easier and more precise.
    Once again JHM provides us with a quality product with fantastic results.
    JHMotorsports Shop - (209) 968-0077 - Matt@JHMotorsports.com
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Four Rings Nebone's Avatar
    B6 & B7 A4
    Cumberland, RI
    I have vertical slop in my shifter when in gear or neutral. When in neutral I can move the shifter up and down about an inch. I have a UUC Motorwerks Short Shifter in. I believe that there will be lots of vibration transfered to the shifter from the trannie via that solid mount making the knob shake.
    Aug 23 2005
    Lathrop, CA
    Quote Originally Posted by nebone22 View Post
    Does your car have pushdown reverse?
    Elitedrmr above has my shifter and the linkage, ask him. With the linkage and getting rid of the rubber it has a little more feel. No major vibrations. You can feel a little, but that is what some people like including me, a full sporty feel.
    Does your car have pushdown reverse? Also if your shifter goes up and down then it is your plastic shift ball and cage that are worn out. My aftermarket shifter is the only one on the market that replaces this with a steel spherical bearing. Check them out here: https://www.shop.jhmotorsports.com/c...g?categoryId=4
    Make sure you watch the comparison video and it will explain why you are having that problem. With my shifter and the stock rubber u-joint you should be happy since it won't give any vibration, due to the rubber joint dampening all of it.
    you misspelled volkswagen
    contact via email please.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Will this work in a B6?
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Quote Originally Posted by Saturnine View Post
    that is TBD, like myself we are patiently awaiting for a test fit on Greg's car
    Some fast things and some slow things
    ~Josh~
    Aug 23 2005
    Lathrop, CA
    Quote Originally Posted by k0mpresd View Post
    HAHA, thanks. At least I got it right on the store portion. That is what I get for building my websites in the middle of the night when I am bored.
    Dooo deee dooo
    Aug 23 2005
    Lathrop, CA
    UPDATE:
    Greg (400HPA4) made it by my shop today and guess what, it fits!!!
    Buy yours here--->>B6 A4 5-speed linkage upgrade
    Get in on our memorial day sale here--->>http://www.audizine.com/forum/showthread.php?t=139439
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by jaybquick@JHM View Post
    UPDATE:
    Did you mean to post this update in the B6 forum seeing that is what greg owns and what your link is for?
    BTW the bushing setup you put in is working great, the shifter box doesn't move at all which makes the shifter feel even more solid. Now I see how bad the stock bushings were which caused the shifter box to move so much.
    Aug 23 2005
    Lathrop, CA
    Yeah, I need to release those bushings. I just need to get them on my site. I put the update here since many people asked about it.
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    03 Golf GL (2.slow)
    Arlington, VA
    hey Jay, do you offer a military discount? lol
    -Cliff
    Current:
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
    Aug 23 2005
    Lathrop, CA
    Quote Originally Posted by psyct1 View Post
    Email me from your military email address at jason@jhmotorsports.com and I will see what I can do.
    Oct 19 2005
    03 Golf GL (2.slow)
    Arlington, VA
    wow, i wasn't expecting it but, email sent!
    -Cliff
    Current:
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    how about a student discount? :p
    Jul 07 2004
    socal
    Quote Originally Posted by Bic-Ball View Post
    Yeah that means "double the price" but in monthly payments.
    Mar 29 2007
    Is the street.
    i guess i'll have to join the military then. damn you solid linkages!
    Aug 23 2005
    Lathrop, CA
    Exactly. School will make him a ton of money.
    Plus I got to show my appreciation to the guys who help provide me with the freedom to have a business.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Quote Originally Posted by Elitedrumr View Post
    I agree I love my JHM short shifter
    1998 Audi A4 built 1.8t Quattro--Eurodyne Maestro---870cc tune---Custom Elim Gt3076---on E85 Gas---044 Bosch Drop in fuel pump---Street tuned by me---402awhp 387tq---12.1@118mph on 19" wheels
    2003 Audi Avant 1.8t Quattro 5speed--Eurodyne Maestro---gt2871--- On E85 gas--- 630cc injectors--19" Staggered iForged Daytona wheels
    2003 Audi A4 3.0 Automatic Daily
