Results 1 to 9 of 9
    Apr 07 2004
    San Diego, CA
    About to paint my lowers.
    Is there a write up somewhere of how to remove the lower door moldings and/or rear valence from the car?
    "All the dude ever wanted was his rug"
    May 02 2004
    99.5 1.8tqm
    Flemington, NJ
    i did it on my car. never took it off. i took off the front valence, but not the sides or the rear. i just purchased some 3 foot wide paper that they have at sherwin williams and taped my car off. it came out perfect for me.
    4 wheels
    2 headlights
    1 glovebox
    1 ac unit
    1 radio
    1 engine
    Apr 07 2004
    San Diego, CA
    wouldn't it be easier to take it off so you could lay it down flat, so the paint doesn't run? I don't know im knew at this. TIA
    Registered Member Four Rings joeya103's Avatar
    Apr 04 2004
    98.5 A4 1.8T Tip FWD
    Northern VA
    It doesn't run if you spray it right and lightly, which is what you should be doing anyway.
    Haha I guess you couldn't trust my PM eh? =P I think the sanding and priming helps the paint stick on contact.
    Apr 07 2004
    San Diego, CA
    Nah i trust ya dude, i just thought it would be easier to paint. :)
    Q7, Q7, F-type manual
    you also want to use a good plastic flex primer. it will help the paint stick much better, especially to the black lower door molding. joeya103 is right, if you are having problems with paint running, then you screwed up and put way too much on for that coat. it will probably not hold up nearly as well as if you do several lighter coats that wont have problems with running.
    May 20 2004
    More cars
    Never Land Ranch
    Wouldn't it be hard to match the color of your car?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Registered Member Two Rings
    Feb 12 2004
    audi
    Augusta, GA
    pics?
    Yes.. it's back.
    Apr 07 2004
    San Diego, CA
    I'll post pics later on next week, when i have my new wheels mounted and my lowers painted
