Results 1 to 21 of 21
    Apr 21 2004
    2013 S4 6MT, 2011 Escalade
    Coopersburg, PA
    Serious Newb question here....
    I have found the spark plugs, now how the heck do you get the wires off of them? Do you pull? I just dont want to F anything up.
    2013 S4 6MT // sport diff // B&O // Phantom Black // Black Leather and Black Alcantara
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    pull
    Account Terminated Four Rings MR VTEC's Avatar
    98.5 Audi 1.8TQM
    Brooklyn
    push
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    twist
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    pry.
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    98.5 Audi 1.8TQM
    Brooklyn
    snap
    Feb 17 2004
    South Philadelphia
    crackle.
    F the Jersey Jerks
    Jersey Jerk hata #1
    www.REVI21ON.com
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Well, you might have the older style of coilpacks, where you have to remove the 2 bolts that are holding them to the valve cover.. Once you do that, just pull up firmly, and they should just pop right off
    Mar 22 2004
    B6 S4 6MT
    Los Angeles, CA
    pull up twisting left and right slightly
    Apr 07 2004
    San Diego, CA
    pop
    "All the dude ever wanted was his rug"
    Feb 16 2004
    yank
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    bukake
    98.5 Audi 1.8TQM
    Brooklyn
    boyiong!!!
    Feb 13 2004
    <> Posts: 9913
    Originally posted by nizmosx
    bukake
    hahaahaha...
    -Theodore Roosevelt, 1907
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    Originally posted by DDQ
    hahaahaha...
    LMFAO!!!
    Thank you: MatrixIntegrated
    98.5 Audi 1.8TQM
    Brooklyn
    hahaahaha...
    Veteran Member Four Rings AudiSnawb's Avatar
    99.5 Audi A4 2.8 Quattro & 2001.5 VW Passat Sedan
    Derry, New Hampshire
    cut with scissors...
    No, dont......
    There's No "I" In "Team America"
    Apr 21 2004
    Coopersburg, PA
    Okay got the plug wire out. Now Im no stranger to tools but how the heck am i supposed to get a socket down in there?? Can you only use a special tool? Do I have to go and find some really thin socket?
    Registered Member Four Rings audlman's Avatar
    Apr 19 2004
    04 SRT-4
    louisville, ky
    the biggest sledge-hammer u can find, then start pouding away till they fall out. good luck!
    98.5 Audi 1.8TQM
    Brooklyn
    sledge hammer is way to big you need a pick axe, Silly! when you see sparks fly out the hole you know your done, the move to the next one.
    It would help if you have a car vac to suck up the excess pieces but not neccessary the old broken up spark plug flying around in your engine won't hurt any!
    Feb 13 2004
    <> Posts: 9913
    All you need is a 5/8s plug socket, and maybe a 4 inch extension, which both come with most socket sets.
    Also, I'd highly recommend you use a torque wrench when changing your plugs to avoid any potential problems from over- or under-tightening the plug into the head. The torqe specs are 22ft/lbs.
