Results 1 to 9 of 9
    Mar 02 2004
    Phoenix, AZ
    I want to upgrade the stock alarm siren... *Questions inside*
    Taking the siren out of it's spot and activating it produces a deafening high pitched screetch...but with the liner back in place and the trunk shut, you can bearly hear that thing.
    So what options are there? What do you guys think?
    Move the stock siren to a different spot? Replace it with an aftermarket siren? Add a second siren in a different spot?
    The stock siren has three wires which I don't know what they are for...I assume negetive, 12v positive and a signal wire?
    If I were to add another siren...would I just splice into the wires or would that cause a problem electrically?
    2011 Audi A4 • Premium Plus • Navigation+ • Sport Package • Bang & Olufsen
    www.DIYAudi.com: Audi Wheel Spacers Install • Audi MFSW Install • Audi Cargo Mat and more...
    May 07 2010
    woodbridge, Ontario
    Bump for the 3 wires question... My siren just went and I wouldnt mine putting in an aftermarket
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    what??? its loud when removed? that thing is like a baby.
    Established Member Two Rings Allhailpoptart's Avatar
    Mar 16 2010
    NH
    The reason it's so quiet is because of the fact that 1) it's in a closed trunk and 2) it's behind the carpeting inside the closed trunk.
    Rather than add another siren to the existing system you can replace what is there. If you add another one into the current system (depending how it's wired, see below) you would have the new siren and the old siren chiming when you lock the car. Unless that's what you're going for it could get super annoying quick. The best bet is to find a weather proof, or water resistant siren and wire it up behind the rear bumper, out of the trunk if you're going direct replacement.
    -OR-
    You could splice in a relay to the power wire (or signal wire whichever gives the alarm sound rather than the door lock chirp) and mount that outside the trunk somewhere. That way you could have both sirens working when the alarm goes off and only the stock "beeper" working when the doors are locked. This would probably be the ideal solution as it would give the appearance that the car does not have any type of aftermarket alarm but it would be loud as hell once someone trips it.
    As far as I know you have the wires correct. 12v DC, Ground and signal. I don't know which is which yet though as I haven't had time to rip apart my trunk and test them since I started looking into this. I'm working on a similar project currently and I'll be posting up what I find when I get it done. I'm leaning more towards option #2 presented here to save the annoyance of a crazy loud chirp every time the doors are locked.
    1995 URS6 Avant | 2.6L Eurospec Sport Stroker | EFR7163 @ 25psi | Tuned by EFI Express
    Dec 06 2007
    Add 2 piezo sirens one inside and the other out and it'll make peoples ears bleed.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    i'd want to somehow hook the alarm to the horn mechanism. at least i will be able to hear a horn from 2 feet away
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    I spliced in with a relay and it controls the loudest friggen horn I could buy, mounted in the front of the car. I did it so long ago, however, that I can't remember how I did it. I got the wiring diagram off of Audiworld (rest in peace).
    Established Member Two Rings Provistic's Avatar
    Apr 16 2010
    Waco, Texas
    Quote Originally Posted by rxrep View Post
    Why (rest in Peace)?
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by Provistic View Post
    It ain't what it used to be. AW Off Topic had me addicted. I stopped AW when the forum format changed and the old schoolers seemed to have left.
