Results 1 to 3 of 3
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    My ABS indicator started flashing. Who should I take it to?
    I Live in SF and work in Redwood City. Recommendations?
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    Veteran Member Three Rings Audiboy's Avatar
    May 14 2004
    Audis and stuff
    Fremont, CA
    o-oh, another one. Do you have ABS while it is flashing? Might be the ABS pump module. Have you done any work recently? Maybe you just broke a sensor or pulled the sensor wires out. Check your fluid also.
    Apr 13 2004
    San Francisco
    Just had the chip installed and an oil change. I'll check the fluid level tonight after work.
