Results 1 to 8 of 8
    Veteran Member Four Rings maxh2o's Avatar
    Apr 13 2004
    B5S4,C2avant,Cgt,UrQ
    San Francisco
    ABS indicator started flashing a few weeks after I got chipped
    I'm pretty sure they're unrelated, but wanted to double check on this board to see if this happened to anyone else?
    http://www.audizine.com/gallery/data...70780_copy.jpg
    Dominating the fast lane since 1984.
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    I have no idea, but i doubt it has anything to do with your chip
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    Check your ABS sensors... they're very easy to check and install new ones if needed.
    Thank you: MatrixIntegrated
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    Does the ABS still work (engage)?
    Apr 13 2004
    San Francisco
    Brakes straight and true as far as I can tell. How do I check the ABS sensors and any idea how much they run?
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    G35, A4
    Thousand Oaks
    mine also does that how do I tell which sensor is bad? How much do sensor run any how?
    G35, A4
    Thousand Oaks
    anyone know how to tell if the sensors are bad?
