Results 1 to 40 of 55
    Registered Member Two Rings overboostpsi's Avatar
    Apr 30 2004
    2001 Audi A4 1.8T Quattro Sport Winter package RS4 rims
    Exclamation HID Conversion Kits...Update...
    HID Conversion kits for sale for halogen H7 and xenon D2S headlamps.
    The Conversion kits include:
    2 xenon bulbs, ~2500 hr life span
    2 water resistant ballasts with igniters
    Wiring harness with waterproof connectors
    Ballast mount and accessories
    The kits are plug and play, so you don't have to cut or splice any wires.
    The kit will come with instructions on how to install the ballasts into your headlamps including a 1 year warrenty.
    Here are some pics of my install:
    I removed my headlamps, and on the underside of the headlamp is where the stock HID system is mounted. This is where you can mount these ballasts.
    I placed a bracket to hold the ballast using the existing screw holes for the stock hid ballast.
    Just to show you that no wires need to be cut, the ballast connects to the existing wires from your headlamp.
    Here's a pic of the xenon bulb and this is an H7 bulb that will fit directly in your H7 halogen slot...no mod needed.
    You can cut a small hole for the wiring harness to pass through the headlamp from the bottom where the ballasts mounts or you can cut a hole in the back of your cover and pass the wires through there. I have the latter set up because I was running a diff. system before so didn't want to make any more holes in my headlamp...I also have not had any condensation buildup in my headlamp either.
    Here's a pic of the setup installed completely.
    5300K kits and 6000K kits are going for $250 plus $15 for shipping.
    If you need more info, please email me at [email protected]
    Also installed an HID kit in my fogs...Looks sick...pics to come soon...
    Veteran Member Four Rings canadian_driver's Avatar
    Feb 17 2004
    3.0 A4, caddy CTS, toyota solara, jeep grand, beat up old crappy jimmy
    toronto, canada
    looks like a good system will it work with s4 ecodes? and is it the same price for every intensity
    Registered Member Three Rings aborchew's Avatar
    Feb 25 2004
    '98 Audi A4 2.8QM
    Chicago, IL
    Can you post some pics of the lights running on an A4 please?
    Apr 30 2004
    Lights...more pics to come soon...hopefully this afternoon.
    Apr 30 2004
    If you have a D2S set up...yes...the I can get kits that are set up for D2S bulbs. That kit includes 2 D2S xenon bulbs, 2 ballasts and igniters, and wiring harness.
    5300K crystal white and 6000K white/blue are $250
    8000K ice blue $300
    10000K deep blue and 12000K violet are $350
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    count me in, i want the b6 h11 fogs like we talked about. see if he can do that up!
    Registered Member Three Rings BrokenXenon's Avatar
    Apr 28 2004
    looks nice man.
    just one question for you...
    i had these 5000K philips kit but my bulbs broke.
    i still have these working philips ballasts..
    is it possible to use these ballasts and buy your bulbs?
    Apr 30 2004
    No prob...
    Apr 30 2004
    Originally posted by BrokenXenon
    looks nice man.
    Hey...wassup...thought you were coming out the the meet this past weekend...???
    I could have shown you the setup and we could have tried out the bulbs I have on your kit.
    Anyway...I believe that might work out for you...I can get replacement bulbs for you for $75 each for 5300K or 6000K.
    the 10000K and 12000K go for $100 each...
    let me know if you want to try it out...we can test it if you like before you buy them...I'm in nyc...
    If your phillips ballasts has the same connectors it shouldn't be a problem.
    let me know
    Apr 30 2004
    REMINDER...for those who have halogen ecodes, the output will be much better than your US halogen headlamps...
    Apr 28 2004
    hopefuly it works but from the pictures u posted, looks like mine uses different plugs.
    Feb 12 2004
    2002 A4 1.8T Tip/Q/Xenon
    Sacramento
    Very nice write up I would say.
    Are they the same kit as your previous post at:
    http://www.audizine.com/forum/showth...threadid=10766
    The reason I asked because I have seen that you now lowered the price of the kit. I wonder if it is the same kit that you had.
    You changed the price of the kit from $300 to $265 shipped and the replacement bulb from $100 to $75 which is a good thing for a lot of members here.
    You would make some sale for the good price I am sure.
    Are you also selling replacement D2S bulb at the same price too??
    I think some members here would want to get higher color temp replacement bulb for their car without switching anything else.
    My OEM bulb would get pricey when it hit 5000K and 6000K.
    So just a suggestion to you.
    Established Member Two Rings wakko's Avatar
    Apr 08 2004
    Temple City, CA
    I am also wondering the same thing, do you sell any replacement D2S bulbs?
    2000 A4 1.8T FWD TIP / 20%F 15%R tints/GIAC 1.0/ GIAC TIP / Full 2.5" DP back custom exhaust / Flik WASP-A 18" / RS4 grill / Ecodes / OEM RS6 4300k HID / Reiger V1 sides / Painted Front lower / Molded SGI rear / Apex Cupkit Suspension / Greddy TT / AutoMeter Boost Gauge / Audi all-weather mats / Forge 007 DV
    Apr 30 2004
    Yes...I did lower the price since you're selling the stock rs6 and A8 HID's for a great price...I'm trying to make business and That's about the lowest I could go, otherwise it would not be worth it at all and I'll just buy the kits for myself and friends.
    The lower prices were for the guys who were coming out to the Rutgers meet, but most of them didn't show...
    I can get replacement D2S bulbs...not as good as osram or phillips, but they work great IMO...deep blue 10000K and violet 12000K are going for $100 each. For now the 5300K and 6000K bulbs are going for $75.
    I'm selling at these prices for now, but I'm going to raise them soon back to 300 for the 5300K & 6000K, 350 for the 8000K, 400 for the 10000K and 12000K.
    Apr 30 2004
    Sure...just let me know what you need.
    Apr 30 2004
    Also if you're located in NYC, NJ, and CT...I can help you with the install.
    Apr 30 2004
    If you could send me a clear pic of your ballasts...I can see if they'll work or not...I really couldn't see if the connectors were the same...
    Let me know
    Feb 12 2004
    Sacramento
    each one or each pair?!
    West LA, CA
    Would these work in my S4 Xenon housings? I think someone already asked this question, but would they work w/o any cutting? Will the D2S bulb holder fit because the RS6 kit's bulb holder is too big.
    Apr 30 2004
    It should fit just fine because it's just the bulb and not the bulb and igniter...The igniter in this kit is incorporated with the ballast.
    I can get a D2S kit that will fit just fine in your housing...
    Apr 30 2004
    All prices that I list for bulbs is each...only one bulb. For the set of a 5300K and 6000K it would be 150. For the set of a 10000K and 12000K it would be 200
    Feb 12 2004
    Sacramento
    Oh I see. So for a set of D2S bulb it will be $200 then?!
    Apr 08 2004
    Temple City, CA
    Originally posted by overboostpsi
    All prices that I list for bulbs is each...only one bulb. For the set of a 5300K and 6000K it would be 175. For the set of a 10000K and 12000K it would be 200
    The math don't quite adds up here...you mentioned that 1 D2S bulb is $75 when a pair is $175?? unless that special price is temporary
    Apr 30 2004
    Dude...sorry, I' meant 150
    Apr 30 2004
    Here are the pics of HID's in my fogs...just exterior...going to do a write up on it soon...more pics to come...
    Apr 30 2004
    D2S Bulbs: 5300K & 6000K $75 each 8000K $90 each 10000K & 12000K $100 each...
    I hope this clarifies things...sorry for the mix up...
    Feb 25 2004
    02 A4 1.8t BT / 03.5 M3
    B-more, MD
    [QUOTE]Originally posted by overboostpsi
    [B]
    looks nice man.
    let me know
    Can't you just cut wire and hook up the old bulbs connector to the new bulb. That what I did when I had get replacement bulb for my kit. (not your the SPP kit)
    Veteran Member Three Rings DGS4's Avatar
    Apr 28 2004
    fast legs
    Im curious. What are the incentives of buying your kit over ProtocoID's kit? I mean yours is aftermarket and his is OEM. Is it worth sacraficing 30 bucks to go non OEM?
    Apr 30 2004
    You could do that and it will work, but it will no longer be a waterproof connection. This is done at your own risk if you do that...I would not be responsible if something were to go wrong with your ballasts or if your bulb were to blow out.
    You could also cut the wires and attach new connectors...
    Apr 30 2004
    I guess it's a question you would have to ask some one who has ProtocoID's kit.
    My kit is a conversion kit designed for those who don't have an oem HID set up.
    ProtocoID has also solved this problem for those who don't have an HID set up by providing an H7 adapter for the D2S bulbs...
    The thing is I can produce a kit for any type of bulb you require.
    I installed the kit in my car and loved it...I'm trying to share that with everyone else and also trying to make some money as well...
    I can also provide different color temperatures if anyone is interested.
    In any case it's hard to compete with ProtocoID's kits since their OEM, but when I originally posted my kits for sale, I did not know who he was, nor did I know that he was selling oem kits for such a price...
    Feb 25 2004
    B-more, MD
    I wonder if there anyway get you bulbs into the b6 fogs
    02 A4 1.8T fwd
    Maestro tuned and built by RAI.... bottom end, some head work, 3071 for now, custom RAI FMIC, and bunch of other stuff that I gotta find receipts for.
    my gallery
    Apr 30 2004
    We're going to do it to nadroj81 B6...I believe it's an H11 bulb...I'm sure we can do it. I'll keep you posted after we do it so you can see how it turned out.
    Feb 25 2004
    B-more, MD
    most def been think of doing it for sometime now.
    02 A4 1.8T fwd
    my gallery
    Apr 30 2004
    Cool...I'll keep you posted.
    Apr 30 2004
    I'm putting in a order for a shipment of HID kits...please let me know if anyone is interested in H7, D2S or H11 fogs (B6) kits in 5300K, 6000K, 8000K, 10000K and 12000K.
    Thanks
    Veteran Member Three Rings chrisrunner's Avatar
    Feb 12 2004
    97 A4 1.8t, 2000 BMW 328i
    boston area.
    can i use these without projector headlights? i have a 97 with halogen h7's....will this setup work as easily and look good enough to warrant buying?
    chris.
    chris.
    http://img.photobucket.com/albums/v9...ri/Driving.gif
    you call it your right. i call it your weakness.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    chris.
    No. there's no point since the light won't be focused at all. Just buy 2piece projectors, they aren't that expensive on ebay. But there's no point in installing them behind the reflector housings
    Feb 12 2004
    Albany
    b6 Xenons going in next weekend (Tenetavie).
    You know what the means, a clear left lane. HAHAHAH
    Veteran Member Four Rings fongaroos's Avatar
    Feb 12 2004
    cali
    do you sell just HID CAPSULES?
    i already have ballasts and im wondering if i could get some H11 capsules?
    the B6 fogs use H11 right?
    Mar 27 2004
    1.8T, M3, X5, 318i, Ek Dx
    NOR*CAL
    Can you get H1 too?
