Results 1 to 17 of 17
    May 13 2004
    New Jersey
    Door Handle Replacement (Rear to Front)???
    Im trying to install rear left door handle on the drivers door for security purposes, did anyone do this before, is it easy swap? or is there something that has to be done at the body shop, any suggestions, and help greatly appreciated.
    thanks guys
    Veteran Member Three Rings Kurzer's Avatar
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    If it's only for security reasons, why not just disable the locks? I think the rear handles are smaller than the fronts?
    Mine has the little lock/unlock pin disabled but the locks themselves are still hooked up (since I don't have keyless) no-one can unlock the car by pulling on those. I almost got carjacked once... The guy pulled the lock/unlock pin and threw me out of the car. I managed to grab the keys and take them with me, when he turned to grab them from me he was staring down the barrel of an Officers .45 ACP... He decided to walk away at that point. Ever since then, all my cars have had the pins disabled.
    Thank you: MatrixIntegrated
    May 13 2004
    New Jersey
    I NEED TO DO THAT, SO THEY CANT SHOVE SCREWDRIVED INTO MY LOCK AND OPEN THE CAR, THAT'S THE WHOLE IDEA BEHIND IT, I KNOW PEOPLE HAVE DONE SUCH A SWAP IN THE PAST, SO I NEED SOME HELP
    Feb 13 2004
    <> Posts: 9913
    CAPS LOCK IS ON.
    It's do-able. I've seen others that have done it. The door handles are the same size. I'd say just pull off the interior door panel and you should be able to figure it out from there. No body work needed.
    -Theodore Roosevelt, 1907
    Veteran Member Four Rings DRA4's Avatar
    Feb 12 2004
    B5 S4
    I did that to my car, the door handles are the same size, simple job.
    Giac stage 1 279whp-327wtq
    TEAM A.C.E. NY
    Me: Siri where do lesbians hang out?
    Siri : I found 2 Subaru dealers fairly close to you
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    Stupid question... You have keyless entry right?
    What about a kitty switch with a backup battery to unlock in case of power failure? Hotrod shops will have these, they do that all the time with cars that have shaved doors.
    Active Member Four Rings ECA4's Avatar
    Feb 14 2004
    New Jersey
    Would it be possible to swap the 98.5> door handles with the newer model ones?
    Feb 12 2004
    B5 S4
    Yes i have keyless entry, if not open the trunk with the key, that should open the doors also.
    TEAM A.C.E. NY
    Active Member Two Rings flipstahylez's Avatar
    May 24 2004
    2001 A4 2.8 quattro
    NY/NJ
    Not to be an ass****, but what if your battery dies?
    Feb 13 2004
    <> Posts: 9913
    That's the rub.
    You can get into the trunk, and hire a midget to crawl through the ski sack after you slice it open,
    Veteran Member Four Rings A4 in SC's Avatar
    Feb 16 2004
    '84 911 Carrera GP White, Burgundy cloth
    Simpsonville, SC
    Another reason I love my Avant. You don't have to crawl anywhere... hehehe
    I might just have to do this. Obviously, if I ever get my car painted, I'll certainly do it.
    Mike
    May 13 2004
    New Jersey
    so you guys say that this should be an easy job right?, im gonna have to do this, i live in NJ it sux here
    Feb 12 2004
    MkV VW Rabbit
    Beaverton, Oregon
    It sounds like the rear is the same size as the front. It's not terribly hard, I'd say go for it!!! It will look very nice without the locks in the front doors.
    I would strongly suggest that sometime in the near future after you do this, to get a battery backup with a switch hooked up. My suggestion for this (A friend of mine's dad had this on his 55 Chevy).
    Normal battery with keyless entry as main system.
    Backup battery with switch as secondary system.
    I think it was some sort of voltage regulated relay? Basically, if/when the main battery died, the relay would change over to the battery with power so you can always open the doors. The only time I ever saw this was when he disconnected the main battery, as far as I know he never had a dead battery but the backup system was there just in case.
    May 13 2004
    New Jersey
    anyone got insturctions, on how to do this?, or did anyone do this?
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    um how hard can it be...just remove the inside door cards pop out the handle with the lock after removing all the steel rods connected to it. them pop in the new handle without the lock. to me it just seems straight forward
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    May 13 2004
    New Jersey
    what is seems it's not really what it is, i have heard that it is PITA to do, but im just looking for advices
    thanks
    Dodge RAM 1500
    Pittsburgh Area
    um I have done this with a VW and all i did was just replace the handle with another one...I don't know man I am thinking about doing this when I can afford to buy a handle
