Results 1 to 2 of 2
    Jun 24 2004
    audi a4 2002 1.8t
    Stanford
    help w/ interpreting fault code
    hello everybody,
    does anybody know what this fault code means? and how serious it is? thanks.
    Address 01: Engine
    Controller: 8E0 909 518 F
    Component: 1.8L R4/5VT G 0001
    Coding: 0016501
    Shop #: WSC 63351
    1 Fault Found:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 001 - Upper Limit Exceeded
    Readiness: 0000 0000
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    Re: help w/ interpreting fault code
    Originally posted by pyc
    hello everybody,
    Address 01: Engine
    Coding: 0016501
    Shop #: WSC 63351
    1 Fault Found:
    Have you done any mods recently?
    I'm guessing here but it looks like the ECU finds the air/fuel mixture too lean and it has adjusted it to its max limit and it is still too lean.
    It could be a vaccum leak or problems in the fuel delivery and you should take care of it soon.
    You could try the vag-com forum over at Audi World for a more accurate answer.
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
