Results 1 to 40 of 50
    Registered Member Three Rings SP's Avatar
    Feb 18 2004
    04' B6 A4 1.8TQM Ultra Sport
    Chapel Hill, NC
    Thumbs up How Difficult Is It to Install S4 Bi-Xenon Ecodes?
    Purchasing a S4 Ecode Bi-Xenon Kit and was wondering if these were Plug-n-Play. How difficult is the installation and was wondering if anyone had DIY on it. Any install or operation issues (i.e. autoleveling and such)?
    TIA,
    Oenophile
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    Its all plug and play.. Its a really tight fit on the passenger side thou, since the wiring harness *barely* has enough slack in it..
    Feb 18 2004
    Chapel Hill, NC
    How mcu did you pay for it and where did you get it I might ask? The place that I am looking to get is going to charge me $1000 for Valeo PnP unit. Does this sound right?
    Palo Alto, Ca
    1000 bucks??? sheesh.. I bought mine from Ebay for 600 shipped from Germany.
    Veteran Member Three Rings SAlNlDllvllAlNl's Avatar
    May 06 2004
    San Diego
    I think he's taking about $1000 including ballasts and what not. At least I hope thats what he's talking about or else a $1000 is wayyyy to much.
    Registered Member Three Rings BrokenXenon's Avatar
    Apr 28 2004
    OWNED
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    The s4 bixenon's all should come with ballasts and bulbs. The ones that Saturnine got has ballasts and bulbs included.
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    really? well, I paid $710 shipped from germany. (came with D2S xenonx)
    Palo Alto, Ca
    Damn, how did you get D2S blubs??? I wish mine had come with those, there are waaaaay more bulb choices for D2S..
    Feb 18 2004
    hun? not all xenon plus comes with D2S? isn't that standard in europe?
    Palo Alto, Ca
    The 4 sets of Bixenons that ive had all had D1S blubs..
    weird.
    Feb 12 2004
    2002 A4 1.8T Tip/Q/Xenon
    Sacramento
    From what I know, they all come with D1S bulb. Valeo did not make any D2S bi-xenon projectors.
    Feb 12 2004
    Sacramento
    I have tried. My wiring harness on the passenger is not long enough at all.
    I would have to build an extend harness to go with it. Now I have only the driver side working.
    Palo Alto, Ca
    Check your Bixenons out.. they are Valeo's..
    Feb 12 2004
    Sacramento
    I know. Thats what i am saying. Valeo did not make any D2S bi-xenon. They are all D1S bi-xenon.
    Palo Alto, Ca
    Oh.
    Feb 12 2004
    Sacramento
    Oh.
    Hey man, on the driver side, did you have to relocate some other wire harness before you get put the headlight in??
    I have to move some wiring harness otherwise it wont fit. How did you do yours?
    NOR CAL
    If you look on the inside of the pass side fender withthe headlight out, there should be a plastic clip that holds that harness in. Take the harness out of that clip, and it should give you some slack. Then, as you push the housing in, connect the harness as soon as you can and push it all teh way in.
    Currently:
    Palo Alto, Ca
    Its a tiiiiiiight fit fo sho..
    Feb 12 2004
    Sacramento
    Feel like almost breaking it.. you dont want to have a tight wire because wire will be hardened and degrade as it ages, you dont really want to stretch it too tight or else you may have a bad wiring harness which will be costly to replace later, especially when you have electrical problems.
    I am trying to build an plug and play extension harness with OEM parts. Researching right now. I am half way done.
    Having only 1 light sucks.
    NOR CAL
    It's not tight enough to cause any sort of degradation. It's taut for sure, but not tight enough to cause rubbing and degredation.
    Currently:
    Feb 12 2004
    Sacramento
    John,
    Do you have autoleveling on your car??
    Feb 12 2004
    Sacramento
    Oh you sure? coz mine is tight enough to cause rubbing... Can you take a picture of how you route the wire?? maybe I am doing something wrong here.
    Palo Alto, Ca
    Yes sir.
    John,
    Feb 12 2004
    Sacramento
    Yes sir.
    I see. Nevermind.
    I dont and I am also researching how to get manual leveling to work. I got all the parts for that just need to see how to wire them together also. Just checking.
    Palo Alto, Ca
    Wait. Manual leveling? you mean the adjustment screws on the top?
    I see. Nevermind.
    Feb 12 2004
    Sacramento
    No. Manual leveling is different from auto-leveling.
    In Germany, all A4 with halogen headlight have manual leveling, which means inside the cabin, there is a oem knob switch in the dash that let you adjust the headlight level, up and down with 4 different step level. The switch is somehow connect to the manual leveling motor inside the headlight.
    But for A4 with xenon headlight, they all have auto-leveling sensor build into the suspension and then sensor will talk to the ECU which then talk to the autolevel motor to adjust the level depending on the load of your car.
    Once I can get it to work, I can adjust the headlight level up and down as needed.
    Feb 12 2004
    Sacramento
    and no... i am not talking about the adjustment screw in which they are used to align the headlight somewhat.
    Manual leveling is another stuff..
    I have seen some people have retrofitted manual leveling even on their xenon car which already has autoleveling, they make something to override the autoleveling which is kinda cool.
    Palo Alto, Ca
    Ahh cool.. I cant put that manual adjustment knob in there anyways, my sub level knob is there already
    Feb 12 2004
    Sacramento
    John, are you good at electronics?
    Palo Alto, Ca
    Not really
    Feb 12 2004
    Sacramento
    I was trying to get a hand to help me in researching that together.
    Palo Alto, Ca
    i can do stereo stuff, but thats about it..
    Feb 12 2004
    Sacramento
    I need to reverse engineer the switch and need to find out what pin go to what and then how to hook it to the little motor.
    Feb 12 2004
    Sacramento
    How can you adjust the headlight horizontally AND vertically??
    after the headlight is installed on the car, you will ONLY see 1 adjustment screws... is that for horizontal or vertical?
    What about the other one??
    Palo Alto, Ca
    The second adjustment screw isnt in the same place as US-spec etc.. If you look near the turn signal side of the light, there is a hole in the fender.. That's the new place where you stick the Allen key to adjust the vertical/horizontal (i cant remember which) position..
    Take a look at the other light if you havent installed it yet..
    Feb 12 2004
    Sacramento
    ya i see that when i have the headlight out.. but it was covered when I put the headlight in..
    am i doing something wrong?
    Palo Alto, Ca
    Read this again.
    Feb 12 2004
    Sacramento
    So here is my solution for the short wiring harness on the passenger side, One end plug right into the original harness, the other end plug into the headlight. This is made of 100% pure OEM Audi parts:
    Walnut Creek, Ca
    Nice! I would have made one if I had the parts. =/ How much did it cost you?
    So here is my solution for the short wiring harness on the passenger side, One end plug right into the original harness, the other end plug into the headlight:
    - JoJo
