Results 1 to 9 of 9
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2025 Audi S4, 2023 Audi A4 & 2024 Subaru Crosstrek
    NY/FL
    Important Info On Fuel Cut Out APR
    Previous Cars: 2006 Audi A4, 2011 Audi S4, 2016 Audi S4, 2017 Audi A4, 2019 Audi S4, 2023 Audi S4, 2024 Audi S4, 2019 Benz E450, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150, 2020 Lexus GS350, 2016 Subaru Crosstrek, 2024 Porsche Cayenne S
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    Re: Important Info On Fuel Cut Out APR
    I think it's a pump issue. I have the revised valve.
    Feb 16 2006
    NY/FL
    OEM Breather Update Kit
    Restore proper boost levels with this kit. This kit comes without a gasket
    This ECS/OEM kit includes the following parts:
    OEM Upgraded Regulator Valve ("G" Version)
    Gasket for valve
    Upgraded valve cover breather tube with internal check valve
    nadroj81 is this what you got?
    Feb 12 2004
    Albany
    err, I have a regulator valve. Not sure what gasket or valve cover they are talking about. However I have never noticed abnormal boost pressure. Mine is always consistent. I hit 21ish and then taper to 16ish at redline w/ my k04
    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    Quote Originally Posted by nadroj81 View Post
    das cause yo turbo is to small homie
    2010 ibis white s4
    CTS Turbo intake
    Jul 21 2004
    South Florida
    Those guys are not supplying proper information. All of our US model cars already have that upgraded pressure valve. The pump is what is needed.
    cheers! Mike
    2018 Audi S5
    Gone-
    Feb 16 2006
    NY/FL
    bhvrdr what is wrong with what i posted? Also my car is going probably going to be the first Stage 3 Audi built by APR used for the picture guide to build the car kit.
    Jul 21 2004
    South Florida
    I was supplied information on upgraded fuel pressure relief valves by a company in europe about a year ago and discussed it with APR. They advised at that time they were also looking into these valves and were supplying them with the k04kits. I had the valves at that time and as I looked into it, I found that all US model cars we could find including early build date B pump equipped 05.5 cars already had the upgraded valve. What is needed is the pump and injectors.
    cheers! mike
    2018 Audi S5
    Gone-
    Feb 16 2006
    NY/FL
    ok cool man thanks.
