Results 1 to 11 of 11
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    one quick question about the stoptech 355 BBK
    i just bought the stoptech 355 BBK, and i have a 19x8.5 wheel, and the offset is +35, i just want to ask you guys that is it gonna fit the rotor and caliper?
    and what minimum offset do you need for 355mm BBK?
    thx in advance.
    aLeX
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Mar 27 2005
    The Cold North
    Re: one quick question about the stoptech 355 BBK
    there is more to it than offset. the shape of the spokes has to be just right to clear the caliper. You can print off a template from the Stoptech website to fit into your wheel to see if there is enough clearance. Here is the link to the 355mm Stoptech template. Make sure you print it out at 100%
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i did that last night and it touch the spoke. just a little bit, my spoke was at 36.0 and the cardboard i cutted was 45.10.
    i will take a picture now.
    dono if i need to buy new wheels or add spacers will do the trick.
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Mar 27 2005
    The Cold North
    if it touched the spoke you are most are probably going to need a spacer or new wheels. Did you try to fit the 332mm kit? It might fit better. or do you need the added heat disappation of the 355mm kit?
    2020 Chevy AEV ZR2
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    It's not only the offset that you have to consider. It's also the design of the wheel.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    Quote Originally Posted by EBG 18T View Post
    i haven't try the 332kit, but i already bought the 355 kit.
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    Quote Originally Posted by ed@audiyo View Post
    whats the max i can go for spacer for the front on quattro, and also do i have to add spacer to the rear?
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    That depends on the tire size you'll be running.
    Quote Originally Posted by aLeXliu911 View Post
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    how about 235/35/19?
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Feb 18 2004
    Rosemead, Ca
    what kind of tires are you running
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    Hankook Ventus Sport
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
