Results 1 to 9 of 9
    Oct 16 2006
    Portland, OR
    Quick Question...
    My roommate has a 95 90-s sedan and his alarm randomly goes off, even when driving... What could be the problem? does this sound very common? anything would help, Thanks!
    Veteran Member Four Rings Blk20V's Avatar
    Mar 08 2006
    Re: Quick Question...
    Never heard that problem before, is it an aftermarket alarm?
    -Bruce B.
    13 Premium Plus Q5 2.0T| HPA K04 | HPA DP | HPA Stage 3 ECU tune
    Fort Collins Drinking Team Member #3
    "For Today I Live, For Tomorrow I Die"
    Oct 16 2006
    Portland, OR
    nope. weird huh
    Oct 16 2006
    Portland, OR
    is there a way he could just disconnect the alarm? I mean, nobody in this town is gonna break into it or anything lol
    Mar 08 2006
    that is weird......is there a fuse for the alarm in the box?
    -Bruce B.
    Mar 08 2006
    it could even be the ECU acting up. It might be best to take it to a wrench or electrical repair place
    -Bruce B.
    Oct 16 2006
    Portland, OR
    yeah i think that will be a last resort. If he only had a B5... i could fix such problems. Where is the ECU in these things. I havent looked under good light, but it looks alot different than my car. Maybe take out the ECU for a bit and put it back in? how would we find the alarm fuse in the box? Thanks for the help
    Mar 08 2006
    Im not sure where it would be in the '95, but my ECU is tucked up under the passenger side dash, right above where the carpeting starts. It might be the same on the later 90 model, you might check there. And before replacing the unit or having it serviced you should probably have a VAG scan to see if there are any fault codes that can be cleared to fix the problem
    -Bruce B.
    Veteran Member Two Rings
    Feb 16 2004
    Long Beach, CA.
    Most 90 models had the alarms in the trunk. Check the wires in the trunk lid. Notorious for breaking, due to opening and closing the trunk. This affect all sorts of other electrical systems in these cars.
    Greg w.
