Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 172
  1. #81
    Veteran Member Four Rings PSYC0TIC ONE's Avatar
    Oct 19 2005
    2022 Mazda CX-5, 2013 HD FatBoy Lo
    Virginia
    Re: 5 Minute DIY CityLight w/Fog Mod (Props to "FatAuto" on AW)...
    Quote Originally Posted by baungS4 View Post
    I got mine from [email protected] .
    yep, sent him an email... gonna do this hopefully next week if my damn e-codes ever get here!
    -Cliff
    Current:
    B9.5 //S4-Prstg-Turbo Blue on Gray-30% Tint
    B8 //S4-Prstg-6MT-Ibis on Blk-Sprt Diff-35% Tint-H&R OE Sprngs-AWE CatBack
    B6 //S4 Nogy on Nogy-19" OZ SLs-FI NonRes CatBack-Hardwired V1 w/ LIS4 Display & LaserMask-30% Tint-RS6 Pedals-BiXenon ECodes
    B5 //S4 Cactus on Black-Sport Pckg-18" Flik Justices-JHM Shrt Thrw-APR Stg1
  2. #82
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Eddie,
    I just realized I never updated on this. After getting VAG'd rest of the world, the mod works great.
    Steve
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
  3. #83
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Quote Originally Posted by S4J View Post
    Eddie,
    Steve
    That's some good news...
    I know some B6ers are finding out that this mod doesn't work for them and looks as if you've found the answer.
    Kudos to you :)
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
  4. #84
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    I did this about a month ago. It works great.
  5. #85
    Oct 19 2005
    Virginia
    Quote Originally Posted by Eddie Man View Post
    Kudos to you :)
    Eddie, FatAuto's Write up on AudiWorld (that you linked in your original post, lol) states the VAG-COM portion of the install as the very first step...
    -Cliff
    Current:
  6. #86
    Veteran Member Three Rings BenGieCruz's Avatar
    Dec 25 2006
    '15 A3
    Oklahoma
    i just tried this mod, and it did werk like a charm, here are the quick splice connectors i used just in case any one out there wants to use the same ones......props and thanks to eddie man and fatauto....
  7. #87
    Oct 19 2005
    Virginia
    Quote Originally Posted by bz0n3 View Post
    you are the man... thanks, I printed the picture so I can take it to radio shack tomorrow for the correct parts! Thanks buddy!!!
    -Cliff
    Current:
  8. #88
    Dec 25 2006
    '15 A3
    Oklahoma
    glad it helped!!!
  9. #89
    Veteran Member Four Rings gpxluke's Avatar
    Feb 14 2006
    Vancouver
    For those who retrofit the projector headlight on their Halogen headlight B7, this mod doesn't work on our setting....Thanks for the sharing though
  10. #90
    Jan 31 2007
    Westchester Co, NY
    i have a 05.5 s4 & tried this mod with no luck....fogs work fine in the normal position but do not come on with the city lights...checked the wiring numerous times....any thoughts?
    2005.5 S4 Sprint Blue, Nav, CF trim, 18" Black Ultraleggas, piano black window trim, CF rear valance, piano black rs4 grill w/color matched emblems....let the modding begin
    2009 A3 2.0T AWD meteor gray, s-line, titanium pkg
  11. #91
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    ^^^Try VAGing to RTW
    Cool stuff with a little growl!
  12. #92
    Jan 31 2007
    Westchester Co, NY
    stupid question....after doing this mod do you still have to pull the switch out to activate the fogs or are they supposed to automatically come on with the city lights? bc if you have to pull the switch out then it worked....
  13. #93
    Feb 03 2008
    Ridley Park, PA
    Mod didn't work on my '04 A4 1.8T. Think I should get vagged to RTW? No city lights, just parking lights.
  14. #94
    Oct 19 2005
    Virginia
    sprint, yes you will still have to pull the knob to activate the fogs, the ONLY thing this mod does is allow you to use your fogs WITHOUT your low beams on... that is it.
    phoenix, yes, you need to VAG your car to RTW in order for this to work...
    -Cliff
    Current:
  15. #95
    Jan 31 2007
    Westchester Co, NY
    excellent thanks psycotic....knew i did it right...always nice when i get to put my engineering degree to good use
  16. #96
    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    Quote Originally Posted by PSYC0TIC ONE View Post
    Turn the Headlight switch to just CCW from "Auto"
    Push the moveable part of the switch in and turn CCW again
    Then the whole thing should just lift out...
    Is this correct?
    You are correct, Sir. :)
    and im assuming to reinstall the switch you just push back in and turn clockwise? im doing this mod this weekend
  17. #97
    Oct 19 2005
    Virginia
    Quote Originally Posted by XCELR8 View Post
    yep, thats all you need to do...
    -Cliff
    Current:
  18. #98
    Jan 23 2008
    NW Indiana
    im assuming you need to take off the trim and other dash pieces for the switch to just pop out. cause man, i pushed in and turned ccw and its isn't moving.
  19. #99
    Feb 18 2007
    San Diego, CA
    That should work on the B7's. You don't need to take any trim/dash pieces off.
  20. #100
    Jan 23 2008
    NW Indiana
    did the mod last night and it worked great! thanks for all the assistance everyone!
  21. #101
    Registered Member Three Rings Colt556's Avatar
    Dec 16 2007
    03 A4 Avant, 03 Getta 24v GLI,
    Indianapolis
    Sounds good. I'm new to Audis and asked if this could be done like my VWs and got no response. Can you do this to a B6 Avant with halogen lights? I guess it would work with the parking lights? If not I have Ecode HIDs coming from ECSTuning SOMEDAY!!!!!! Good write up an appreciate any info.....
    It's an Avant Thing...
    03 A4 Avant 1.8TQ Tip, APR 1+, APR exhaust, Carbonio, Eibach Pro Street, Hotchkis swaybars, OEM E code HIDs, Aero Wipers, 20% Tint, B5 S4 Calipers with Cryo Power Slot Rotors, 18x8.5 BBS CHs, More to come....
  22. #102
    Veteran Member Four Rings Jrunr's Avatar
    Oct 27 2004
    2007 Audi S4, Phantom
    El Paso, TX
    Does this allow the fogs to work with the high beams as well? or will they still turn off when you turn your high beams on?
  23. #103
    Dec 25 2006
    '15 A3
    Oklahoma
    Quote Originally Posted by Jrunr View Post
    i haven't even tryed yet, i'll let u know this afternoon!!
  24. #104
    Senior Member Three Rings va-terps4's Avatar
    Feb 11 2007
    NoVA
    The RTW setting will allow the fogs to stay on with the highbeams. That works regardless of the wiring modification.
    2016 SQ5 Prestige - Glacier White/Black Milano/Carbon Atlas
    2013 Q7 S-Line ... 2008 S6 Sedan ... 2007 S4 Avant ... 2002 allroad
  25. #105
    Oct 27 2004
    El Paso, TX
    What is the RTW setting?
  26. #106
    Nov 05 2004
    Detroit/Clarkston
    Rest of The World (RTW) lighting setting on teh VAG COM codes.
    2006 S4 Avant
    >>> Got Mods?
  27. #107
    Veteran Member Four Rings lunamarA4's Avatar
    Feb 25 2004
    lots of tools and spare parts
    San Diego, CA
    OMG this is AWESOME!!!!!!!!!!!!!!!
    I can control the fogs when I want and turn the side markers on to mark the edge of my car
    (2004 B6 A4)....finally you guys outsmarted the US programing....I did everything to get independent fogs...finally a OEM/ clean solution
    many thanks to both of you guys!!!!!!!!!!!!!!!!!!
    4 SALE B6/B7 parts
    RafE |2004 BT White A4 Avant|
    |2002 S8 6spd - fully overhauled + 6 spd|
    |1988 E30 S52 Pandem Kit|
    |1991 E30 M20 Touring|
  28. #108
    Established Member Two Rings FatAuto's Avatar
    Feb 06 2007
    Greenwich, CT
    Cheers....
  29. #109
    Veteran Member Three Rings nycmalu's Avatar
    Apr 16 2008
    Rockland County, New York
    First and foremost, to FatAuto for figuring this out and Eddie Man for putting it up on this forum...
    I just did this mod after VAGing my car to RTW (B7 A4) and getting rid of that infernal seat belt chime and activating the remote windows.
    I also had some difficulty getting the headlight switch out and I didn't want to break anything. I remembered someone saying that you can access the harness through the side panel where the fuses are... sooooooooo what I did was, put the switch in the position where you can pull it out, but while pulling, I applied pressure from behind after removing that little panel on the side... worked like a charm.
    I'm sure XCELR8 has figured out a way to do it by now, but this is just for those who would like to try it in the future, it makes it a great deal easier when you don't have to worry about breaking something. I have no idea why mine didn't pop out as easy as some of you described.
    Also, the main reason I tried this is because I happened to have those quick connect things sitting around and they didn't do squat for me... I ended up hard wiring it and electrical taping that sucker because the wire tap probably didn't have a good connection or the male quick connect wasn't properly attached... Either way, it works great now and I can drive around with my fogs on to my heart's content
  30. #110
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I know this is a repost but I wanted to put my spin on it...
    First of all, HUGE props to "FatAuto" for figuring this out. For reference >>> FatAuto's AW Link
    Here's how I did it and I've just include lotso pics for people who like pics
    w.audizine.com/gallery/data/500/4066DSC05051.JPG[/IMG]
    8. Done, in 5 minutes time. Fogs w/CityLights Mod...
    Whooot !!!!
    sick mod dude, thanks!
  31. #111
    Established Member Two Rings stifler474's Avatar
    Mar 15 2008
    Santa Barbara, CA
    how come my turn signal lights are on after completing this mod? there on with the city and fog lights....
    Silver B7 2007 A4 2.0T Quattro
    30% Tint
    De-badged
    Hoen Xenonmatch lights
    Clear Corner Mod
    Carbon Fiber B Pillars
    Colormatched Sidemarkers
    (H&R springs, and 19" rims soon to come...)
  32. #112
    Feb 15 2007
    Quote Originally Posted by stifler474 View Post
    please read through the thread! Hell, read the couple of posts above! You need a VAG to change settings to RTW (REST OF WORLD)!!
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
  33. #113
    Senior Member Two Rings 220013047's Avatar
    Apr 12 2007
    I am new to this, but how do you do a VAG (RTW)? Since this did not work on my 2002 A4 B6. Can the dealership change to RTW?
    Thanks
  34. #114
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    So whats the trick to get the knob out.. i push it in and it wont turn at all... im confused.
  35. #115
    1. Put the knob in the auto position and push in with a bit of force and begin turning the knob COUNTER CLOCKWISE, once the switch is in between the "O" and "Auto" position, you will hear/feel a slight click and the knob will go in slightly
    2. While still turning COUNTER CLOCKWISE and pushing in slightly, move the knob all the way to the "O" position and push a bit harder, the knob will then push in a bit more
    3. while still pushing in on the knob (at its second "pushed in" position) begin moving the knob back towards the "Auto" position or CLOCKWISE, the knob should stop in between the "O" and "Auto" positions, then just pull out, the whole assembly should come out...
  36. #116
    Quote Originally Posted by 220013047 View Post
    Thanks
    Find someone on the boards with a Vag-Com cable. There are plenty of people more than willing to help out. The dealer will probably charge you an hourly rate to do this.
    Where are you from?
  37. #117
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    Does the VAG have to be RTW, will the Euro Setting work with this mod?
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
  38. #118
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    Quote Originally Posted by vinny.dtw View Post
    It does work on B6's...I've done this mod like a year ago...no problems whatsoever. You can keep your coming home feature. Everything works like normal
    i hooked up the #2 wire and the #1 wire. Left the other end of #2 chillin all taped up. and this still doesnt work.. i gota b6. am i doing sumtin wrong??????
  39. #119
    Active Member Two Rings ERICHCS's Avatar
    Sep 28 2008
    2013 S4, 05 S4 (Gone)
    Lenox MA
    I finally did mine tonight. Works great car is Vag-commed already to rest of the world for lighting settings.
    Only slight modification from the DIY was instead of taking out the switch i just opened the fuse access panel and reached in and disconnected the wiring for the headlight switch. And if my big hands can do that anyone else should be able to.
    Senior Member Three Rings slakr4's Avatar
    Sep 04 2007
    08 Brilliant Black A4 2.0T 6MT
    This worked for me also...BUT had a small problem. My right side xenon light keeps flickering. I have the ecode xenon headlights from Jens(lowesta4). Anyone know what the problem is??? They way I connected wire #1 and #2 was with an additional wire just tapping into each one (So nothing was cut, just the insulation was taken off a little on each wire #1 and #2). TIA
    N.E.R.D
    REVO Stage 1, 19" DPE's, Stasis SS, RNS-e, carbonio, ecode bi-xenon w/ cc, Podi, Hardwired RX65, 35% Tint, s4 matte mirrors & door blades
    F.S: OEM Sirius receiver, OEM Ipod integration kit, Revo select switch *PM ME*
    WTB: AWE Exhaust *PM ME*
