What is your 2.0T FSI engine code ?
You can locate your engine code on a sticker which is affixed to your timing belt cover. It is also included on your vehicle data plates / vehicle data sticker inside your service manual.
Ive been doing some research on this and have found that the 2.0T FSI engine comes in 7 varients.
I assume that most peoples engine code will be BPG but wanted to run a poll to see if this indeed was the case.
I have BWE which seems to have a rare Engine / ECU combination. This is why APR have to develop new software for my ECU.
Some differences in the engines:
- BWE 280Nm at 1800rpm / compression ratio of 10.3
- BPG 280Nm at 2000rpm / compression ratio of 10.5
- BUL (DTM engine) has an output of 162KW and the same ratio as the BWE.
Can someone explain what the benefits of having a 10.3 compression ratio engine to a 10.5 ? As my engine and the DTM engine share the same compression ratio.
