Hybrid View
    Veteran Member Four Rings Elberoth's Avatar
    Feb 18 2004
    1990 Ferrari Testarossa
    Warsaw, Poland
    17544 - System too Lean Code. WTF ?
    I just got the following code:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 001 - Upper Limit Exceeded
    I logged for long term fuel trims (Block 032) and 1st field is 6,4% and the 2nd one -18,8% (negative).
    Any ideas what may have happened ?
    Vaccum leak ? Fuel pump ?
    I have recently installed TP (got code for that, too), TIP and a new MAF.
    Car feels normal.
    2021 Audi R8
    2012 Porsche Cayenne
    2010 Audi S5 - facelifted F & R (sold)
    2010 Audi Q5 2.0TDI facelifted F & R (sold)
    2002 Audi A4 1.8T Sportec K04 Stage II (sold | will be missed)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: 17544 - System too Lean Code. WTF ?
    Code P1136 is usually associated with an air leak somewhere in the intake system. Check for vacuum hose leaks or leaks around the intake manifold. Take a real close look at the 1/8" hose coming out of the end of the intake. More often than not that is the problem.
    Mar 27 2005
    The Cold North
    i throw the same codes occasionally. But it is only when i am at full throttle and over 9500' elevation in the mtns. I am thinking my issue is altitude related. It never happens around town or at lower elevation.
    When you find out what is causing your issues update this post.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 18 2004
    Warsaw, Poland
    Thanks guys. I think I will check the vac lines first.
    I will update this thread when I solve this problem.
    2021 Audi R8
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    3rd or whatever on the vac lines...esp. the one running out of your intake manifold...the 2002-2003 use a braided cloth covered line versus a solid rubber one...and they often crack because of the funny angle they hit the manifold at coupled with the fact that they are cut dreadfully short.
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
