Results 1 to 14 of 14
Thread: Rubbing Issues
    Senior Member Three Rings Ara's Avatar
    Dec 11 2006
    Rubbing Issues
    I just had my Stasis street sport kit installed today, and i'm having some rubbing issues with my current setup. The ride height was set to 25" all the way around, exactly as reccommended. My car has 19x8.5 Champion RF62's, I believe the offset is 35mm. It is rubbing when I go over expansion joints on the freeway, and also when I go in and out of driveways and such. Anybody else have this problem? Any solutions? Thanks in advance.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Re: Rubbing Issues
    I can't offer much in the way of help. I get some slight rub on mine when hitting harsh dips at speed. It seems to be against the fender liners, and not the fenders themselves, so I'm not too concerned.
    Seems like your install shop should've caught this, though. Did they do a test drive? Worse, if yours is anything like mine, the ride height will actually decrease as the suspension settles. I'd recommend asking your shop for some assistance. Good luck...
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Buncha motorcycles
    Memphis, TN
    Re: Rubbing Issues
    my stasis SS hit that damn screw in the fender liner a little bit but its still pretty black, it hasnt rubbed all the paint off and they havent settled really at all from what i can tell.... im taking the wheels off next weekend to paint the calipers and i will see how much they have been rubbing!!!!!!
    APR Stage 2/AWE Intake
    Jan 03 2007
    SF Bay Area, CA
    Re: Rubbing Issues
    Ara, any updates on this? If I remember right from your B7 post you were considering going even lower?
    Dec 05 2006
    So. Cal.
    Re: Rubbing Issues
    What size tires are you running?
    Dec 11 2006
    Re: Rubbing Issues
    It still rubs sometimes. My wheels are 19x8.5. Tires are 235/35 Michelin PS2's. Dont know if i'm going lower with it, but i am changing to the Stasis Ohlins setup. I'll update again when those are installed.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Re: Rubbing Issues
    Quote Originally Posted by Ara View Post
    25" from ground to fender lip is too aggressive. We'd suggest around 25 3/8" at the most aggressive.
    Your wheels are causing the rubbing issues. We run a 19x8 35et on our own Avant and are right about 25 3/8" and we don't rub, save for the curves/big dips at speed (with a fully loaded car) as VrooomVroooom states. But going 0.5" wider with the wheels will certainly cause rubbing.
    PS--Nice upgrade to the STaSIS MotorSport/Ohlins. YOU WILL LOVE THEM!!!
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Dec 05 2006
    So. Cal.
    Re: Rubbing Issues
    I guess that I can look forward to rubbing also as I am running 19x8.5 +32 BBS LM's shod with 245/35/19 PS2's. The car isn't lowered but I wanted to install the Ohlins also.
    Can it be done?
    May 27 2004
    Portland, OR
    Re: Rubbing Issues
    Can it be done?
    32et is sticking out farther.
    What model do you have (I assume it's not the Nissan).
    Jeremy Williams
    Dec 11 2006
    Re: Rubbing Issues
    Well, I had the Ohlins installed yesterday, and 95 percent of the problem is gone. I think they also trimmed the inner fenders which helped. Havent measured the ride height, but the car looks to be about the same height.
    May 27 2004
    Portland, OR
    Re: Rubbing Issues
    Jeremy Williams
    Veteran Member Three Rings WantAvant's Avatar
    Oct 12 2006
    04 A4 Avant 1.8T
    Sioux City, IA
    Re: Rubbing Issues
    We need some more pics, your car is badass!!!
    Dec 05 2006
    So. Cal.
    Re: Rubbing Issues
    Quote Originally Posted by jeremy@matrix View Post
    I know it does. Who said it didn't? Not only am I pushing the wheel out another 3mm from the the 35 offset, I am also pushing out an additional 1/4" due to the wider wheel.
    May 27 2004
    Portland, OR
    Re: Rubbing Issues
    No one did, but expect rubbing for sure.
    Jeremy Williams
