Results 1 to 4 of 4
    Registered Member Two Rings AudiChan's Avatar
    Oct 24 2006
    97' A8, 02' Maxima, 96' Altima
    NC
    Question A8 Headlight (High Beam) fuse problem?
    when i did my state inspection, i found out that my right high beam is not working. strange thing is that it still didn't work after replacing the bulb. could it be the fuse? can anyone help on locating that please?
    much thanks!
    1997 A8 Quattro
    Veteran Member Four Rings ECSPGH's Avatar
    Aug 05 2005
    00 A8L, 91 Landcruiser
    Butler, PA / Cincinnati,OH
    Re: A8 Headlight (High Beam) fuse problem?
    do you have vag-com? you can check your voltages there
    2000 A8L- The Brigadier General Four Rings
    Oct 24 2006
    NC
    what is vag-com? is that some diagnostic tools that i can plug into the car computer?
    Aug 05 2005
    yep, use this link to find someone near you. you should have posted a week ago, I was driving through NC, asheville early in the week and charlotte later in the week.
    http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
