    Jul 21 2004
    South Florida
    Official Vag-Com Datalogging Reference Page....
    To begin the data logging process, plug the vag-com cable into the OBDII port in your vehicle. This port is usually located under the stearing column near the hood release latch. Then connect the other end of the controller to your computer.
    After having downloaded the software onto your computer you will find the vag-com icon located either on your computer's desktop or you may access it through the start menu. The following is a screenshot of the vag-com item as well as a shortcut folder that was created where the data logs will be stored for easy access.
    In order to create a shortcut folder for easy access to your data logs, first click on the "My Computer" icon and locate the computer's hard drive in which the "Program Files" are located. Usually this means clicking on the "Local Disk C:" drive and then click on the "Program Files" folder. Inside the "Program Files" folder will be the vag-com folder titled appropriately "Vag-Com". Click on this folder and locate the folder titled "Logs". This is the folder where the data logs are automatically stored after a logging session. It may be convenient to right click on this folder and highlight the "send to" option and choose from that menu "Desktop (create shortcut)". This will create an easy to access folder on your desktop as pictured in the above screenshot. Otherwise you will have to proceed through the above directions to access your logs each time you conduct a data logging session.
    Once you have created your shortcut folder you will be ready to begin the data logging process. Begin by clicking the "Vag-Com" icon located on your desktop. The following screen will appear...
    From the above opening screen, select the upper left hand button titled "Select" located under the heading "Select Control Module". The following screen will now appear...
    Next, select the "01- Engine" control module located in the upper left hand corner of the common control modules screen. Once you have selected the "01" control module, the following screen will appear...
    Select the button located on the left side of the screen titled "Meas. Blocks - 08". The items on the vehicle you will be logging or measuring are located in informational groups referred to as "measuring blocks". Sometimes the measuring blocks are also referred to as channels. The following is the screen you will see once you have clicked on the "Meas. Blocks -08" icon...
    The above screen is used to select what information you would like to be measuring on your vehicle. Study the screen and take note that it is possible to log three groups of measuring blocks simultaneously. Each group has a three digit box that displays the measuring block you will be recording. You can toggle through the measuring blocks using the up or down buttons or if you already know which measuring block you would like to select, you can simply drag your curser over to that box and type in the measuring block number you desire to record. Take note that while it is possible to measure three blocks simultaneously, the more blocks you measure together the less data rate will be used and therefore less points of data will be collected across the rev band as you record the data. One action you can take to improve the data rate and one that is highly suggested each time you data log is pressing the "Turbo" button located on the top right of the page. You can press this button any time throughout this selection process prior to actually starting the log. Once the button is depressed, you will see the turbo button turn into the title "9901".
    In the above screenshot, the user has elected to record measuring blocks #34, #20, and #115. The user has not yet pressed the turbo button in that screenshot but will do so prior to logging. Once all the channels are selected for logging and the turbo button is pressed, click on the "Log" button located on the lower right side of the screen. The following is the screen that will appear...
    The above screenshot has changed from the previous in a couple significant ways. First, notice that the boxes that contained the measuring block numbers you selected are now shaded and you are unable to toggle back and forth to select a different block. This is because the measuring process is now locked and ready to go. Also note towards the bottom of the screen is a box titled "File Name:" and inside that box is the location and title of the data log you will be accessing later to read the data from. The file name for this log is expressed as "LOG-01-034-020-115.CSV". Notice that the default file names correspond to the channels this user has chosen to record...channels 34, 20, and 115. While still working within this screen it is possible to change the filename to whatever you prefer. Just remember to keep the extension ".CSV" on the end of this file. Once you have your car posistioned properly and ready to begin the logging process, press the "Start" button located under the file name. This will begin the recording process and logging has thus officially begun. The following screen will appear once the start button is depressed...
    You're probably noticing a lot hasnt changed in this screen once you have pressed the "Start" button. That is true. The only change that has occured is that the button that once was titled "Start" has now changed to read "Stop". Once you are done recording the information you desire, click the "Stop" button and the recording process will terminate. The following is the screen that will appear once the "Stop" button has been depressed...
    Again, not much has changed. But notice that the "Stop" button has now taken on the title "Resume". At this point you may choose to continue recording this group of measuring blocks (perhaps you had to stop the car for a moment and wanted to pause the measuring process) or you can choose to terminate the logging process by selectng the button titled "Done, Close". Once you have selected the "Done, Close" button you have now ended that logging session and the data from the session is instantly downloaded to your "Logs" folder in the form of a Microsoft Excel document. You may now exit out of vag-com if done logging for this session and locate your log of information by opening the "Log" folder and locating your filename. The following is a screenshot of the "Log" folder opened up...
    You might have noticed that the files located in the above screenshot do not include the log of block 34, 20, and 115 as none of the titles match up with these measuring blocks. That is only because for this article, that file was deleted (sorry) but under normal circumstances the file name "LOG-01-034-020-115" would be present.
    You have now finished the collection phase in the data logging process. Congratulations! You are now a data logger. If you have found this page helpful or would like to make a suggestion, please let us know by contacting us using our "Contact Us" page. And be sure to refer a friend.
    The next step involved in data logging is to intepret the data you have collected during your session. The following link is a measuring block interpretation page of common blocks...
    http://www.audizine.com/forum/showthread.php?t=115367
    2018 Audi S5
    Gone-
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    what happen to the pics??
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Three Rings quattro guy's Avatar
    Nov 30 2014
    06 audi a4 quattro 2.0 6sp
    rockford il
    ^^^^x2
    02 audi a4 Quattro 1.8 6sp, milltek exhaust, Motoza e85tune,f21 @26psi,stage 2 ra4 clutch, hyperboost diverter valve, 18z brakes, rear s4 brakes, TR11 FMIC, je pistons,ie rods 2.0 coil convertion kit (best 1/4mile time on stock engine at 21psi 13.4 @101mph)
    06 audi a4 quattro 2.0 6sp, gfb diverter valve, 2.5" test pipe, apr stage 2, r8 coil packs, s4 front brake
    05.5 a4 2.0tq 6sp, r8 coils, motoza e85 tune. S4 front brakes.
    Apr 15 2014
    Ottawa/Gatineau Canada
    X3
    ( bring on the xQuattro!!!!)
    Jul 28 2014
    SACRAMENTO
    this is a better way, very technical though "imnuts" told me about it
    http://www.audizine.com/forum/showth...raph-Logs-****
    04 B6 A4 USP 2.7t
