Results 1 to 10 of 10
    Veteran Member Four Rings neoprufrok's Avatar
    NOR CAL
    Just lowered my A8 about 3/4" with Vag-Com.. Writeup inside!
    edit delete
    If there was one thing at the outset that the A8 needed fixed, it was that 4x4 look to it. Even in dynamic mode, it was still jacked up high off the ground.
    So I decided to Vag lower it, before trying anything else. For one, its free. Two, it seemed easy enough. Three, my good friend lawong loaned me his vag cable.
    So I downloaded the Ross-Tech software onto my MacBook Pro Windows side of things and went to town.
    Of note.. I had one adaptation go awry because Vag com just crashed mid adaptation. Needless to say my car went into limp suspension and the headlights gave a warning that it could not level. Luckily I just went right back into the adapation and redid it and it worked fine.
    I'm just going to paraphrase Der Kimbo's excellent writeup with some tips of my own.
    So I first parked the car in the garage on level ground. Turned the ignition on and inserted the Vag cable into the obd2 scan port under the driver's left side knee cover area. I made sure to connect the cable to the car first, then snake the cable out of the driver's side window where my laptop was. I then connected the cable to the laptop.
    Started up Ross-Tech's Vag Com software, selected the select control module buton. Then I clicked on the chassis tab at the top row of tabs. In this menu, I selected controller 34 - Level Control. The stock code read like this:
    0015510
    the only numbers that matter are the two fives. Each integral drop in number corresponds to a 5mm drop. For example, I wanted a 20mm front and 15mm rear drop so I entered:
    0011210
    After entering and saving I closed the Vag com - removed the vag cable and turned off ignition. I restarted the car (engine turned on) and reconnected the cable to the obd2 port.
    I then went back to controller 54 - level control. Over on the right side of buttons on the Vag-Com panel, there's a button called security access - which I clicked. I then entered the number 31564. Important: Once you enter this, you need to complete the adaptation from beginning to end or else the car will not adapt to your new settings and it will go into a limp mode for the suspension.
    After entering the security code, I went to teh adaptation button. There are five channels:
    01 Front Driver
    02 Front Passenger
    03 Rear Driver
    04 Rear Passenger
    05 Save
    First select 01. Press return. The car will then lower and raise its suspension. After its complete and the vag-com status windows says okay to enter - go to the test value window on the left side of the test button. Measure the center axle to the bottom of the fender lip - make sure to measure in millimeters. Enter this value in the test value window and press enter. Then click on save. Do this same thing for channels 02, 03, and 04. When you are done, go to channel 05 and enter 1. This saves the adaptation. Exit out of the Vag-Com.
    Now get into the car and then drive back 15-20 feet and drive forward back to teh same spot you were before. Repeat the adaptation and you should notice that the values in the read section should be fairly close to what you measure. If not, continue to adapt until its right.
    I have to measure again, but my car went down about 20mm in the front and 15mm in the back like I wanted to... but I'm still adapting. I'll do it again tomorrow to make sure its right.
    Thanks to Der Kimbo for a great writeup and to lawong for his vag cable.
    Currently:
    2018 GT3 Touring - Graphite Blue Metallic
    2016 McLaren 675LT - Mexico Blue with Roof Scoop
    2019 BMW M4 Convertible - Yas Marina Blue Competition Package
    Will be missed: 2001.5 Audi S4, 2004 Audi A4, 2004 Audi A8, 2008 Audi RS4, 2016 Porsche Cayman GT4, 2018 Porsche GT3.2, Mercedes C63 Black Series, McLaren 12C Spyder
    Podcast and Instagram: The Throttle Dogs
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    Re: Just lowered my A8 about 3/4" with Vag-Com.. Writeup inside!
    wow i wish mine was that easy, have any pics ?
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    NOR CAL
    Quote Originally Posted by ExpLlclT View Post
    I was so excited to do it, I didn't take pics. I'll take some after pics tommorow hopefully.
    Currently:
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    thats maxed out as low it can go? i mean did u try playing with the codes u entered to see if it will drop any lower?
    makes me want a a8 even more...
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    Veteran Member Three Rings BING's Avatar
    Sep 18 2006
    01' A4 2.8QM ,99' A8Q,93' //S4
    comin up fast on your left !
    I hooked up teh vag yesterday to reset codes after replacing the N80 purge valve,I did go into my chassis tab along with every other tab(peeking for other fault codes) there was and "no" adjustment is available for my 98'...... :(
    03' VW TDI in GTI clothing
    93' //S4 GT30/40R,VEMS,6MT(sold)
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    02.5' VW Passat Wagon 1.8t
    110 valves =;^)
    Oct 30 2007
    Germany
    Can that be done on a 2000 S8? I'm to Audi.
    Veteran Member Two Rings skoTner's Avatar
    Jul 21 2004
    09 A5 3.0TDI S-line MTM
    Andebu, Norway
    Where'd the pics go?
    2009 A5 3.0TDI S-line quattro | Ice Silver | Black S5-interior | Carbon Atlas inlays | Panorama glass roof | MMI 3G | B&O | APS w/ camera | KW Variant 3 | TTS steering wheel | Advanced Key/Keyless | El. memory S5-seats - heated | Hold Assist | Cruise Control | El. sunshade | Xenon plus | MTM 310hp kit | Caractere bodykit
    Feb 24 2008
    New England
    Can this be done to a 1998 A8 Quattro?
    Thankz
    Registered Member One Ring LordoftheRingz's Avatar
    May 08 2008
    '04 A8
    Once you've finalized all your settings, please post your fine numbers/settings?
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Quote Originally Posted by LordoftheRingz View Post
    This thread is over a year old.
