Originally Posted by
GTMRS4
I thought about doing the GMG 2.0 Engine swap anyone done that?
GTMRS4
Did you get your engine from GMG? Stand alone? Fuel Mapping?
What'd you get done and how much? I'm thinking no more than 10k on mods
No I took my current 1.8T, then bored and stroked it with all forged internals, then port/polished and rebuilt the head with all new internals and more aggressive cams. I'm going to run revo BT programming for the time being. I might go with Chris Tapp or custom GIAC tuning down the road. Running 430cc injectors currently. Doing so only because I'm at 5000ft. ECU will compensate for the 2.0. If I lived at sea level, I might need more fueling to keep up with the 2.0. Might need 550cc injectors with 3" maf, or 630cc injectors with 3.5" maf. Maybe also a bosch 044 fuel pump.
Fully built head with labor: new cat 3651 cams, cat springs, new retainers, ferrea exhaust valves, new hydro lifters, new seals and gaskets, port and polished runners on exhaust and intake side done for ~$1600. Got a deal though since he took so long with it. Should be ~$2000 for this work.
[email protected], check out his website but don't go off his rates posted, call him instead.
Internals on the bottom are eurospec knife edged forged crank. Eurospec racing rods, JE 82.5mm pistons with pro rings, new bearings for ~$2250 (retails ~$2700)
Local machine shop (AMS) did the mockup, boring, honing, cleaning, and balancing of the bottom end. They charged me ~$450.
Spent about +/- $800-1000 on audi oem parts like the gaskets, nuts, bolts, Timing belt, water pump, oil pump, TB tensioner, fluids, etc...
So $5K+ at least to get all this done. This is without any labor costs to disassemble and reassemble the engine in the car.
Sorry for the thread jack 20V
