Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 145
  1. #81
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    Re: B5 A4 Easter Eggs! Features not found in the owner's manual.
    What's the little speaker on the drivers door just under the armrest? I've never noticed it before and the other door doesn't have it.....99.5 btw.
  2. #82
    Veteran Member Three Rings auditi's Avatar
    Nov 19 2007
    Burlington, WA
    its the speaker for a speakerphone on models that came with a car phone, thats what the rj-45 jack is for inside the armrest too...
    -'11 VW Golf 2dr TDI 6-speed manual
    -'59 VW Bus
    -'05 B6 A4 1.8T Quattro USP - Arctic White/Black, 6MT, unk chip, S4 brakes/SS lines, S4 grille, tint, PODI gauge, forge dv, Bose w/ Aux & Sub - sold
    --USP Club Member #212
    -'01.5 B5 A4 1.8TQMS - Silver/Black, tint, M3 lip spoiler, Bose+sub, 1.3 bar custom Neuspeed p-chip, Evo MS CAI, 710n, H&R sports, S4 shocks, short shift, 19mm Neuspeed RSB, poly snub, Blitz dtt w/ red led's - sold
  3. #83
    Sep 28 2006
    Lexington
    I'm having some problems with holding the unlock button and rolling down the windows?
    Any help?
    Also my little speakers for the phone I guess is cliped on my middle visor is that what your talking about?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
  4. #84
    Veteran Member Three Rings hernandez3011's Avatar
    Mar 21 2008
    United States
    Quote Originally Posted by AudiTurbo View Post
    Any help?
    You need to change the settings with Vag-Com
  5. #85
    Sep 28 2006
    Lexington
    Any more secerts? Does the bose thing not work on the concert radio?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
  6. #86
    Sep 28 2006
    Lexington
    Re: Easter Eggs...Features Not In The Manual
    Quote Originally Posted by jbrentd View Post
    It's mostly climate control diagnostics, but there is some engine data there. Here's an AW tech article.
    http://www.audiworld.com/tech/int6.shtml
    What year does this work on? It didn't work on my 98
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
  7. #87
    Sep 28 2006
    Lexington
    Quote Originally Posted by sean1.8t View Post
    here is the trick to unlocking the "secret EQ"
    To access the EQ all you have to do is turn off your car and remove the key. Then hold down the number '5' on your CD changer/Radio preset control and power on the head unit.
    You will see '55555555' if your radio is in stock form. These numbers represent 4 EQ settings each for front and back. They are, in order from left to right (courtesy of LCP on the AudiWorld forums):
    1. Front low bass
    2. Front mid bass
    3. Front midrange
    4. Front treble
    5. Rear low bass
    6. Rear mid bass
    7. Rear midrange
    8. Rear treble
    To adjust the settings, use your volume knob to change the flashing digit to a value from 1 to 9 (1 being the lowest level, 9 being the highest) and press P.SCAN to go to the next digit. When you get to the end it will wrap back to the first digit.
    The most popular settings for bose seem to be 88698869, however after a bit of testing with my favorite music, I found that to sound boomy and hollow and have since gone with 76567656. My next task will be to increase the directional (midrange and treble) sound on the front speakers only to bring the Bose sound stage back towards the front without sacrificing bass out of my rear speakers.
    The best setting that I have heard for the non-bose system is 38679657. It still doesn't sound like bose, and certainly not like a good after-market setup, but it's a major improvement for those that wish a simple change to improve their overall sound and reduce distortion.
    I have tried this on my buddies b6, but Don't know what buttons to push cause everyone says different ones. So which one work for the b6 sympathy stereo?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
  8. #88
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    Quote Originally Posted by Tifun View Post
    Thats a speaker of the OEM Cellphone.
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
  9. #89
    Sep 28 2006
    Lexington
    My speaker are on the b pillars, and i have the other mic hooked to the middle sun visor. I want to cut out the black box that is under my arm rest which holds the phone jack. Has anyone does this before?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
  10. #90
    Active Member One Ring mattyt's Avatar
    Jul 18 2007
    Arlington, WA
    B5 A4 Easter Eggs: Override Climate Control?
    Is there any way to override the climate control so you can have the A/C on whenever you want? I live in the Seattle area and so it's common for it to be in the upper 30s (F) and raining. De-frosting the windows is (obviously) much more effective with the A/C.
    [rant]
    WTF is up with this anyway? Why do those presumptuous Krauts think they know better than me when the A/C should be on?
    [/rant]
    -Matt
  11. #91
    Sep 28 2006
    Lexington
    We need more things!!
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
  12. #92
    Jan 15 2009
    Phoenixville, Pa
    do you know what code is needed to do this with vag?
  13. #93
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    not too exciting but...
    when car is locked, stick key in door and turn once to unlock only drivers door, turn a second time to unlock all doors
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
  14. #94
    Nov 11 2008
    Oxnard, Ca
    Quote Originally Posted by a4mafia(Red) View Post
    and......
    the windows roll down, well at least it does in my 01' 1.8tq
    Speedtuning, 2.5" custom exhaust to a Magnaflow, K&N pannel, Forge Splitter, VDO Boost Gauge, Neuspeed Race springs, KONI adjustables
  15. #95
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by Rosati View Post
    10. Every piece of moving glass in your car has pinch protection, even the sunroof. (I tried it)
    WARNING! not true for all b5s, good thing i tested this with a pencil and not my finger
  16. #96
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by nova_ss672001 View Post
    and......
    yeah it does if you hold it, but i'm saying for when you wanna unlock all the doors so everyone can get in....
  17. #97
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    To clear service interval indicator from LCD:
    Hold right button on dash, then turn car on accessory, then press the left button.
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
  18. #98
    Veteran Member Three Rings PSI NRG's Avatar
    Feb 24 2008
    For tip cars.... I noticed that when in tip mode when you push the pedal all the way to the floor it doesnt shift until redline or unless you lift your foot from WOT or shift with the tip
  19. #99
    Registered Member Two Rings nyca4tq's Avatar
    Mar 14 2008
    My car sat for a year, the battery died and now my radio wont come on. Is it broken or is there some sequence of things to do to get it to work????
    F N G here....
    Everything is relative.
  20. #100
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    Hey guys, when you go into the Engine DTC codes through the A/C climate controle screen
    I found that everyone only knows codes through like 32.
    What about everything past 32? Mine goes to 72 and has readings for each one....
  21. #101
    Senior Member Two Rings prospero's Avatar
    Apr 13 2009
    Denver
    I found a mod to change dual-climate controls to sync so when you - or + on one side it does it on both, but now I can't figure out how to unsync them.... anyone?
    It was hold Auto and + for 3 seconds, but it doesn't do it reverse.
    current // 06 a4 2.0t quattro 6sp | brilliant black | dtm rear lip | euro cupra front lip | K&N | greddy tt | hoen xenonmatch fogs | vag'd' | 30% tint
    soon // unitronic stage 1 | rs4 rear sway | oem rev 'D' dv | awe vent boost gauge
  22. #102
    Apr 13 2009
    Denver
    I know why it was in the B6 thread oops :)
  23. #103
    Apr 15 2009
    Middle TN
    Quote Originally Posted by JPJ2007 View Post
    Anyone know?
  24. #104
    Senior Member Three Rings mexican47's Avatar
    May 13 2009
    F4i, Hardbody
    Sequim Wa
    Anyone know?
    Yeah i was wondering the same thing!!
    could any of those be like MPG/ or miles to empty??? <that'd be awesome!!
    lets get this thing goin again...
    DÌEGØs AÜD!CTIØN
    MySpAcE.com/AUDICTD & FaCeBoOk!
    BOOSTED E30 coming soon
  25. #105
    Apr 15 2009
    Middle TN
    Finally someone else who is as interested as I am. lol
    That would be awesome, I would love to know.
    We need to do more research and continue to ask around.
  26. #106
    May 13 2009
    F4i, Hardbody
    Sequim Wa
    lol i know its time to bring it back!!
    I'll be lookin around the web and pushing buttons lol
    DÌEGØs AÜD!CTIØN
  27. #107
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Not sure if this is in the thread already I didn't read the whole thing but...
    LED's up by the sunroof dial/cabin lights that shine down on the shifter. Really useful if you need to see something at night but don't want to blind yourself with the cabin light!
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
  28. #108
    Apr 15 2009
    Middle TN
    I still have not been able to find these LEDs you guys speak of...
  29. #109
    Deactivated Two Rings
    Aug 01 2008
    97 Maxima
    PA
    if you shut the car off, then take the key out, adn put it back in, it doesnt make the dinging noise when you open the doors....
    on the concert stereo, when you turn it on, the volume gradually increases to where you left it, (happens quickly, but it does "ramp up" the volume, it doesnt just BLARE it)
    if you have the fogs on, all you have to do is shut off the headlights and all fogs will shut off as well
    if you want the one touch up and down of the windows, from the button on the door, every time you disconnect the battery, you must hold the switch down for 15 seconds AFTER the window is down, then hold it up for the same 15 seconds...this will program the one-touch up/down
    the rears only go auto down from the factory, you must use the speaker wire mod to make the rears do one-touch up too.
    try using single electrode spark plugs instead of dual electrodes ( on the 1.8T it smooths out chipped applications, especially if gapped to .026" or less)
    the little button that shuts off the motion sensor, resets every time you open the doors, so if you press it, then shut the door, but forgot your ballcap on teh seat and you open the door to get it, you must press the button again, to re-dis-able the motion sensor
    the phone jack in the console is an RJ-11, RJ-45 is cat-5 ethernet
    this hint is for all cars, not just audis
    if you dont like the wind blowing in your face when you put a front window down all the way, try putting the rear window on the same side down halfway, this will direct more air in the front, and out the back, instead of blowing it across your face
    ie, drivers window all the way down, drivers side rear window down 4-6"
    jpj2007......
    here is a link to the overhead console....see the 2 little rounds dots below the sunroof switch? those are the LEDs
    http://cgi.ebay.com/ebaymotors/ws/eB...400&indexURL=0
    i will get a pic of mine turned on for you tomorrow, so you can see where they are, but im guessing if you cant find them, your car most likely does not have them
  30. #110
    Aug 01 2008
    97 Maxima
    PA
    there is the location of the LED's
    and here are the LED's illuminated...
  31. #111
    Apr 15 2009
    Middle TN
    Yeah, Mine does not have those. I'll get a pic of what mine looks like.
    I dont have a manual, where could I get a factory 98.5 A4 manual?
  32. #112
    Junior Member One Ring
    May 11 2009
    Minnesota
    Does the 97 delta radio have any accessible custom EQ?
  33. #113
    Jun 21 2007
    99.5 A4, 08 Mazda3
    If you are on the highway cruising and want to have nice airflow but not the noise, tilt the sunroof up and crack the back passenger window about an inch. Great wind flow with minimal noise.
  34. #114
    Account Terminated Two Rings
    Aug 22 2009
    Riverside, CA
    thanks for these information
  35. #115
    Sep 09 2007
    2002 A4 Avant 1.8T Quattro
    North Vancouver, BC, Canada
    Quote Originally Posted by prospero View Post
    to unsync, just hit + or - on the passengers side
  36. #116
    Jun 21 2009
    Topeka, KS
    I noticed on my 01 that when you turn the car off (with the switch on) the headlights shut off but the marker lights stay on. Anyway to have it shut all the lights off?
  37. #117
    Aug 01 2008
    97 Maxima
    PA
    Quote Originally Posted by sgt_g View Post
    YUP
    turn the switch off
  38. #118
    Jun 21 2009
    Topeka, KS
    Quote Originally Posted by m6amba View Post
    YUP
    turn the switch off
    lol i will be sure to do that next time. I tend to turn my marker lights on cause i have all my windows tinted with 5% tint and it makes it kind of har to see my gauges a certin times of the day so i turn on my marker lights and once in a while forget there on when i get out. Guess prior owner killed the chime for it as there is none. I'm going to look into re-wiring the lights on the cluster to a switched power rather then the headlight switch.
  39. #119
    Jun 21 2007
    99.5 A4, 08 Mazda3
    My cluster is lit all the time.
  40. #120
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Yeah, so is mine.
    Anybody know where my lightsaber is? It's purple, and it says " Bad Mother****er " on it.......
