Results 1 to 11 of 11
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    MY06 Engine Cover Mods...
    Finally got some time to install the engine covers that Audi pimped me out of on my '06...
    1. Added right OEM engine cover.
    2. Added left OEM engine cover over passenger shock tower area...
    Modified it to adapt to the Stratmoshpere CAI Bulkhead.
    Well here are some quick snapshots...
    Engine Bay BEFORE
    Engine Bay AFTER
    Left Engine Cover Mod:
    Cut OEM engine cover with my table saw to fit snugly next to the Stratmosphere bulkhead.
    Added angle bracket and drilled holes for a clean pop-rivet attachment.
    CloseUps of Modded Engine Cover Left:
    BEFORE
    AFTER
    OEM Right Engine Cover Pics:
    Cover
    Required OEM hardware for mounting
    I really like the finished look alot better...
    Thought I'd just share.
    Enjoy:)
    BTW, Here are the part Audi OEM Part Nos.:
    (1) - Cover: 8e0-103-928-g-01c
    (1) - Cover (fluids): 8e0-103-927-e-01c
    (2) - Grommet: 078-129-669
    (2) - Spacer: 078-129-734
    (1) - Bushing:8e0-103-541
    (1) - Bolt: n-105-538-01
    (1) - Bolt: Reuse from windshield refill location to the new holder
    (1) - Holder: 8e0-899-803
    (2) - Rivet: n-909-766-01
    I know in the pic above, I show some additional hardware pieces, but I ended up not needing them. I however, did not / could not find one of the hardware pieces needed to mount the right cover at the 3rd mounting location (I basically bought all the hardware that was indidated on the ETKA). It's the location where a screw/bolt with a ball head mounts on the radiator refill tank. By my inspection though, the cover holds secure even w/o it.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Veteran Member Three Rings UBERS4's Avatar
    Sep 18 2006
    2005 Arctic White S4
    Earth
    Very well done!!! You could sell those to the non-do it yourselfers
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    |Dunlop Tires|DPE Wheels|Oettinger|Rotora|Tein|GIAC|Supreme Power|
    Veteran Member Four Rings DolphinV8's Avatar
    Feb 18 2004
    nice
    Nov 05 2004
    Detroit/Clarkston
    Thanks.
    Just resized pics for better/faster viewing.
    2006 S4 Avant
    >>> Got Mods?
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Very nice job
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Nice, definitely completes the look of the engine bay. Do you have part numbers?
    2013 S6 | 2006 S4 widebody | 2014 Q7
    Veteran Member Four Rings robots_are_neon's Avatar
    Feb 16 2004
    SoCAL
    awesome dude, so clean
    Current: B8 A4 S-Line Avant
    Previous: B7 S4
    Before that: B5 A4
    ETH
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Eddie Man, nice! Have you looked at trying to re-incorporate that piece you had to cut off or would it be to much trouble? Putting that piece on and hitting the rivets with some black paint would look totally OEM . BTW, props to you on your very informative signature. I really like how you've provided all the helpfull links to your personal mods. Thanks.
    Nov 05 2004
    Detroit/Clarkston
    Thanks for your props and for recoginizing the sig...
    Glad it helps in any way that it can.
    Regarding that cut-off piece:
    Yea, I guess I did give it some thought and it would look pretty good with it on, but what I was concerned about was a couple things.
    1. The look of being, kinda tacked-on. It's kind of a small piece and though it may continue the flow of the trim piece, I think that look maybe just "trying too hard".
    Just my opinion though.
    2. The mounting: Though it can be mounted secure and OEM looking, it needs to facilitate a direct way for removal. Though pop-rivets are good, they are somewhat permanent. Screws/Bolt are good too, but access is key. A tab w/a clip would prolly be the best method, but that is not an option for atleast this DIYer.
    Well anyways, good thoughts though.
    Thanks...
    I added the part numbers back up top to the head-end of my/this thread.
    2006 S4 Avant
    >>> Got Mods?
    Sep 17 2006
    Houston, TX
    Originally posted by Eddie Man
    Thanks...
    Thanks! This is something I'll probably do to stave off the modding bug.
    Nov 05 2004
    Detroit/Clarkston
    NP...
    Since you have the part numbers now, you may wanna try to utilize the Impex Part route to save on some $, rather than the stealership parts counter.
    My be worth a try to see if save any $ but you do have to pay shipping >>> World Impex
    2006 S4 Avant
    >>> Got Mods?
