Results 1 to 12 of 12
    Nov 10 2006
    2007 RS4, 2006 A3, 2004 A4
    Arizona
    How to keep exhaust tip shiny?
    One month with my RS4 and my tips are already charred. What's the best way to clean them?
    I'm thinking Simple green might do the trick. Any other suggestions?
    Thanks.
    '07 RS4 - Avus Silver/Silver leather
    '06 A3 - Lava Grey/Grey leather
    '04 A4 - Black/Black leather
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 23 2004
    Wash them and then use Adam's Metal polish 1 and 2 on them and it should be good. Regular maintenance is a must.
    Let me know if you need some.
    Nov 10 2006
    Arizona
    Shoot. I guess I should have ordered some with my last purchase. I guess I'll get some when I get detail spray refill.
    I'll try to keep them relatively clean until then with simple green I guess.
    Thanks.
    Junior Member Two Rings
    Oct 27 2006
    Parents
    Richmond Hill - Toronto
    Are they aluminum?--- I'm not sure.
    But I would stay away from Simple Green because it's been well documented to 'whiten' aluminium, and 'dull' the sheen and gloss of metals over time with repeated use.
    Good luck!
    Gabe
    Automotive Detailer
    Richmond Hill Toronto
    Nov 10 2006
    Arizona
    Thanks for the response. I'm glad I checked before using simple green. I haven't even received my first adam's shipment yet, and I already have a new list building.
    Aug 26 2005
    Use a good metal polish, made for chrommed metal, or stainless/aluminum as the case may be.
    Vorsprung durch Technik
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    I used to be an avid fan of simple green. After researching it on autopia.org, I now only use it under the hood or in the wheel wells.
    I've used eagle one's never dull with great success on exhaust tips. Just be careful that the wadding doesn't have any contaminates in it.
    Senior Member Three Rings |ninja|'s Avatar
    '06 A4 2.0T sline
    i use soft steel wool
    Veteran Member Three Rings alco1777's Avatar
    Feb 12 2004
    What if you have no idea how long your tips have been charred? I got mine like that. Any way to restore it to brand-new looking without buying a... brand new exhaust?
    02 Imola S4
    VA
    try any metal polish. mothers and never dull can both be found at your local auto store.
    Feb 12 2004
    It won't strip off the finish or anything crappy like that?
    02 Imola S4
    VA
    nope. Read the directions on the box or container. It's quite simple.
