Results 1 to 40 of 48
    Veteran Member Three Rings 02A4TURBO's Avatar
    Feb 12 2004
    Phila, PA
    VAG Codes for B7 A4
    Tried to search for the answer to no avail. Does anyone know where I can get VAG codes for the B7 A4? Specifically, I'd like the following:
    - 1 touch unlock opens all doors
    - Eliminate seatbelt sensor noise
    - Open/close sunroof & windows w/ keyfob
    I think that's it - unless anyone has done other VAG mods that are worth it. My dealer said he'd be happy to do them if I bring him the codes.
    Can anyone help?
    2017 RS7 4.0T | Daytona Gray Pearl | RS Black Seats | Sport Exhaust | Alu-optic Intakes w Quattro Script | Red Brake Calipers | 21" 5 spokes |
    2017 Q7 3.0T | Ink Blue | Premium Plus | Nougat Brown | 20" 10 spokes | Vision | Warm Weather |
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Seatbelt chime remove
    Address 17 - Instruments --> Recode --> Change xxx5x to xxx0x
    xxx?1: Belt warning
    0 no belt warning
    1 Belt warning Europe NCAP. Optical durable warning, acoustic warning for 91 seconds actively.
    2 Belt warning the USA and Canada old. Optical and acoustic warning for 6 seconds
    3 Belt warning the USA and Canada NAR again. Optical durable warning, acoustic warning every 30 seconds
    4 Belt warning Europe NCAP (incl. front seat passengers). Optical durable warning, acoustic warning for 91 seconds actively
    5 Belt warning the USA and Canada old (incl. front seat passengers). Optical and acoustic warning for 6 seconds
    6 Belt warning the USA and Canada NAR again (incl. front seat passengers). Optical durable warning, acoustic warning every 30 seconds
    No seatbelt chime
    23261 default
    23259 remove seat belt chime
    Windows up/down with key FOB
    Address 46 - Central Convenience
    11820 default
    11884 windows up/down with key FOB *can only close sunroof, not open
    Mike
    Account Terminated Two Rings Wad3 C0uNty32's Avatar
    Nov 01 2006
    2007 A4
    Carol City
    how do you do this? i wannna try it myself lol
    Veteran Member Three Rings Alipor's Avatar
    17 Q7, 04 Allroad 6-speed
    Upstate NY
    Follow the directions above, just select recode in each menu with the vag and your all set.
    Present:
    17 Q7
    04 Allroad Stage 3+ EPL Tuned
    Gone:
    09 TTS EPL- 04 S4 GIAC - 02 A4 APR 2+
    Established Member Two Rings Damned04's Avatar
    Sep 18 2006
    IL
    anybody know where I can download the version that supports the B7, I tried the one of ross tech but no b7 :(
    06 Light Silver Metallic A4 2.0tiptronic 15.827 @ 90.00
    05 TSX - Sold
    97 Sc300 - T61 coming soon
    Upstate NY
    do you have a hex can cable?
    Present:
    17 Q7
    Gone:
    New Member Three Rings
    Feb 05 2006
    A4 2.0T Quattro
    how about the ambers off code? is there aplace i can see all codes? i hear theres also a code to make our light s a few levels highter like the stock a8..
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    The VAG-COM s/w for B6 & B7 are the same. If you are using the eBay cable make sure you use the freeware version ie 409.1, not the latest one.
    Feb 12 2004
    Phila, PA
    Good looks Tanner -- I appreciate it.
    As for the 'no amber' code -- anyone have a pic to show what this would look like? Sounds intriguing.....
    Markham, ON
    No pictures here, but just image your headlights on at night, but no side ambers. They only get turned on when the turn signal is on.
    Last digit changes the behaviour.
    Address 09 - Central Electronics
    1023 default
    1021 enables high beam/fog, Euro parking lights (amber only when blinking)
    For more details see:
    http://en.openobd.org/audi/a8_4e.htm
    Mike
    Veteran Member Four Rings evoic's Avatar
    Sep 16 2006
    06' A4 2.0T Quattro + 05'
    OC
    Mike.....
    Did you mean to link HERE instead ? ?
    Markham, ON
    Whoops, yep, copied the wrong link.
    Mike
    Feb 05 2006
    A4 2.0T Quattro
    that website is a bit confusing..anything easier to underatand
    Markham, ON
    It's not that confusing at all. It's more understanding how the stuff is 'encoded'.
    For example let's look at this:
    Select 46 (Comfort System)
    Coding -> Function 07
    +00001 - 10 Tamper alarms (Great Britain)
    +00002 - Confirmation Anti-theft warning system blinks
    +00004 - Selective Central Locking (SCL)
    +00008 - Anti-theft warning system - activation of AWS
    +00016 - Rear lid release locking via speed
    +00032 - Comfort Locking via speed
    +00064 - Comfort function via remote control
    +00128 - Right Hand Drive (RHD)
    +00256 - Avant bit
    +00512 - Confirmation remote closing (1x blink)
    +01024 - Confirmation anti-theft warning sytem horn activation
    +02048 - Door-/ window regulator logic
    +04096 - Thatcham anti-theft warning
    +08192 - No safe-function
    +16384 - Side windows with insulated glass
    All of the stuff above is represented is actually in binary format but given that we see the coding as a regular old number, we have to 'decode' it to understand what options are turned on and what isn't used.
    For example, if you had a number of 18742, basically to get this number we add:
    16384
    2048
    256
    32
    16
    8
    1
    Then that gets you the options that are used to arrive at 18742. Basically you want to work backwards, take the largest possible number and subtract that from your value. So if you wanted to activate the horn (1024), you basically add 1024 to 18742 getting you 19766 and so on.
    With the other options, it's just a matter of changing a digit.
    Mike
    Senior Member Three Rings SixthGear's Avatar
    Oct 18 2006
    Montreal
    Using Mike's example, simply open up Windows calculator on the laptop you're using for the VAG-COM. Then select "Scientific" mode. Here you'll have the option of working in DEC (decimal 0 to 9) or BIN (binary 0 to 1). The cool part about binary is that the 1s and 0s are like ONs and OFFs.
    If 18742 were your default VAG-COM value, simply switch to DEC mode (default), enter the number, and then switch to BIN mode. You'll get:
    100100100110110
    If you don't have the same number of options in the list as you do 1s and 0s, simply add 0s to the LEFT of the number to fill in the blanks. Here we have all 15 so it's OK.
    Basically the 0 on the far right is the first item in Mike's example (10 Tamper alarms) and the 1 on the far left is the 15th item on the list (Side windows with insulated glass).
    All this is in the VAG-COM pop-up window when you mouse-over the number.
    So if we look at the number and make "right to left" instead be "up to down" we have 100100100110110 becoming:
    0
    1
    1
    0
    1
    1
    0
    0
    1
    0
    0
    1
    0
    0
    1
    And matching that to the list:
    0 - OFF - 10 Tamper alarms (Great Britain)
    1 - ON - Confirmation Anti-theft warning system blinks
    1 - ON - Selective Central Locking (SCL)
    0 - OFF - Anti-theft warning system - activation of AWS
    1 - ON - Rear lid release locking via speed
    1 - ON - Comfort Locking via speed
    0 - OFF - Comfort function via remote control
    0 - OFF - Right Hand Drive (RHD)
    1 - ON - Avant bit
    0 - OFF - Confirmation remote closing (1x blink)
    0 - OFF - Confirmation anti-theft warning sytem horn activation
    1 - ON - Door-/ window regulator logic
    0 - OFF - Thatcham anti-theft warning
    0 - OFF - No safe-function
    1 - ON - Side windows with insulated glass
    Then it's simply a matter of switching whatever you want ON or OFF by replacing the 1s and 0s with the value of your choice, then just re-input the 1 and 0 BIN number into the calculator and switch to DEC mode for the number you need to put back in the VAG-COM box. This sounds long explaining it, but when you do it it's so much quicker.
    So if we wanted to turn on the "Comfort function via remote control" we simply change the bit from 0 to 1 and end up with 100100101110110 which is 18806 when you switch it back to DEC.
    Hope that wasn't too confusing...
    2010 A5 S-Line 2.0T Quattro 6MT
    Unitronic Stage 1+, HyperShift Short Shifter, H&R Spacers 15mm/20mm, H&R OE Sport Springs
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    this is interesting stuff, reprogramming the computer to do diff stuff, if these options were available from the factory, why were they not enabled in the first place?
    Sep 18 2006
    GTA Canada
    Different countries, different regulations.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Veteran Member Three Rings mrponline's Avatar
    Sep 18 2006
    2008 Audi S5, 2007 VW Golf R32
    Sydney Australia
    Thats right, the Audis we get in Australia come factory preset with the following
    - No Amber light (only when signaling)
    - 1 touch unlock all doors
    - No seatbelt chime
    - Sunroof and windows with keyfob
    2008 Audi S5 6MT
    Phantom Black, 20" Forged DPE 3 Piece Wheels, Nitto Invo 285/25 Tyres, H&R Suspension
    2007 VW Golf R32 6MT
    2006 A4 2.0T Quattro 6MT Sline - SOLD
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Re: VAG Codes for B7 A4
    Are those codes the same for a B6? I would like to try a couple of things mentioned above. If the codes are the same. Is there a way to turn the daytime running lights off? In Canada they have to be on all the time and that means I have this stupid little green thing on my dashboard the whole time. I drive with my xenons on anyway so I never use daytimes. Thanks.
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Active Member Two Rings ebah's Avatar
    Feb 06 2007
    toronto
    good stuff.....how people get it~~~anyway...nicccce
    07--B7 2.0TFSI Q 6sp
    05--C6 3.2 FSI Q tiptronic
    Registered Member Two Rings
    Sep 16 2007
    Wappingers Falls, NY
    Quote Originally Posted by Tanner View Post
    1023 default
    1021 turned the DRL's on. I used 1031 and now I can rock city lights and fogs and now with the addition of my bixenon upgrade, I no longer have city, HID, amber creating a christmas tree effect. VAG COM rocks! Anybody near Wappingers Falls, 12590 I can help you out with it.
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    I tried to turn the ambers off in my B6 last weekend and I couldn't manage to do it with the standard US housings. It seems possible with the ecodes but the codes didn't work for me when I tried setting the value to 'Rest of the World'
    If somebody has better luck, please post cause I'd love to be able to get rid of that amber bulb.
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Sep 16 2007
    Quote Originally Posted by Shak View Post
    The code I had to change to get this to work was 00003 by default(I believe it is the first box). I changed it to 01031 and now it is all good!
    Sep 18 2007
    Los Angeles, CA
    I have a 2007 A4 Cabriolet and my default code is 21023 and I have tried all different codes and combinations. I get the turn signal lights to turn off, but then the rear signal lights do not work. As if the lights were out and I get the fast signal indicators.
    What can I do?
    Someone please help.....I don't want my car looking like a christmas tree. Just the clean xenon look.
    Veteran Member Three Rings clumpymold's Avatar
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Quote Originally Posted by SixthGear View Post
    100100100110110
    0
    1
    1
    0
    1
    1
    0
    0
    1
    0
    0
    1
    0
    0
    1
    1 - ON - Avant bit
    Super old but I must say it was THIS post that actually helped me figure out what I did wrong with the "Convenience Codes".
    I'm going to have to paste this in the current thread. With credit given to you, of course.
    Senior Member Three Rings JohnUSMC's Avatar
    Jan 13 2009
    07 B7 A4 2.0T Quattro
    Dallas, TX
    holy thread revival, BATMAN!!
    Oct 18 2006
    Montreal
    I'm glad someone's putting it to good use! :)
    Thanks man.
    Dec 18 2008
    06 A4 2.0T
    Halifax/Nova Scotia/Canada
    I'm trying to figure out the amber off except signalling code, but my original value is different (1014). I tried 1011, 1031, and 1021, but none seemed to work... Anyone have any suggestions?
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Quote Originally Posted by thanatos View Post
    Well, with mine, I actually accidentally deleted the original value and just put in the number I wanted (I had no idea what I was doing originally). I then started over and just checked off the features I wanted and added them all up. Ended up with 28282 and everything works great! You could try that too and just do trial and error?
    Dec 18 2008
    06 A4 2.0T
    What did 28282 end up giving you?
    All for the trial and error, hasn't broken things yet (crosses fingers)
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Here's a thread I posted in quite a bit (see post #525):
    http://www.audizine.com/forum/showth...=158766&page=6
    But, to get to that value, I added the following numbers (see that list for corresponding options):
    2, 8, 16, 32, 64, 512, 1024, 2048, 8192, and 16384.
    I think if you've got a similar car (i.e., no avant or right-hand drive), you should be okay.
    Sep 18 2006
    GTA Canada
    1014 is Halogen with DRL / Canada without Bi-Xenon. Try 1012.
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###XY, where:
    X = DRL
    0 – Halogen without DRL
    1 – Halogen with DRL
    2 – Bi-Xenon with DRL
    3 – Bi-Xenon without DRL
    4 – Bi-Xenon with DRL / tail light / license plate light
    Y = Locale
    1 – Rest of World / Nordic Countries / Denmark / Croatia / Baltic Countries with Bi-Xenon
    2 – Nordic Countries / Denmark / Croatia / Baltic Countries without Bi-Xenon
    3 – USA / Canada with Bi-Xenon
    4 – Canada without Bi-Xenon
    5 – Special Vehicles
    2nd Ring: 2006
    4th Ring: TBD
    Sep 04 2009
    Massachusetts
    I have a 2008 a4 cabrio and I did the fog light mod with no parking lights just city and that was nice and easy but I have tried to do the seat belt chime delete and the windows up down with unlock but no luck. section 46 wont even open up on the vag and 17 for the seat belt has no section to re-code just 05 which asked for a 3 digit number 00-255. What the hell do I do
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by B7cabrio View Post
    1) Cab codes are different.
    2) If you are looking at a 3 digit 00-255 screen, seems like you are doing it wrong. Seems like you are in adaptation instead of recode. Reread instruction.
    2nd Ring: 2006
    4th Ring: TBD
    Senior Member Two Rings KiddEng's Avatar
    Jan 29 2009
    Jersey
    11820 default
    I used code 11896 to enable the window feature w/ FOB and combo 1 click lock/unlock.
    Lately i've noticed that when I click to roll Down w/ the FOB, doors unlock but the windows won't roll down no matter how long i hold the button down. Has this happen to anyone else? I will have to re-press the unlock button and hold a few times before the window's roll down.
    maybe my fob battery is going dead?
    '93 Civic Hatch :: 390hp/275ftlbs :: Stolen and Stripped
    '06 Arctic White Avant 6MT :: 034, APR, AWE PowaH :: RS4 Sway / H&R / Bilstein :: Gold/Polished LM reps ::
    Dec 18 2008
    06 A4 2.0T
    Quote Originally Posted by KiddEng View Post
    Yeah I've noticed the same thing sometimes, I assumed it was because the car needs to read the button as being held but if the signal is weak or interrupted briefly, it doesn't work and i have to repress.
    Veteran Member Three Rings Msu2312's Avatar
    Jan 17 2009
    scooter?
    Quote Originally Posted by 02A4TURBO View Post
    ill post one tonight for ya i love it this way
    ...2008 A4 2.0T S-Line...
    Neuspeed flash upgrade/Forged diverter/spacer/AEM intake/VMR Test Pipe/19'' black ultraleggeras/Magnaflow Unresonated Exhaust
    ...All wrapped in Double limo...
    Feb 12 2004
    2005 Yamaha R6
    San Francisco, CA
    Quote Originally Posted by Msu2312 View Post
    Ditto! It makes those ugly ambers less obvious at night. During the daytime, however... I'll have to get around to removing them altogether eventually.
    Jan 17 2009
    scooter?
    ok mabye its better i not post these pics, haha my iphone pictures came out really bad so i apologize in advance, but youll get the idea...
    ill take pictures again tonight with a real camera lol
    Established Member Two Rings quattrojedi's Avatar
    Jul 17 2007
    03 RS6, 04 Allroad 4.2, 94 Cabriolet, 91 Alfa 164S, 97 Ram 1500 SLT Laramie
    Booozrah Southeast CT
    anyone know the coding for fogs w/ out headlights?
    03 RS6
    04 Allroad 4.2
    94 Audi Cabriolet
    91 Alfa 164S
    85 Porsche 944
    97 Ram1500SLT
