Results 1 to 3 of 3
    Registered Member Two Rings Dynamic213's Avatar
    Jul 19 2004
    2004 Audi A4 1.8T
    Virginia
    suspension installation
    I posted this under general B6 A4 forum and got no info. Could anyone help?
    "I'm thinking of upgrading my shock and springs this winter from stock(none sport version) to a set of used S4 shocks and springs.
    How hard it would be to do it on my own? My local VW shop qouted me 6 hrs max at $62/hr labor.
    Does anyone have a step by step guide that I can follow?
    What else would I need to replace other than a straight shock/spring swap?
    It's a 02' A4 1.8T Quattro"
    Oct 05 2006
    There's a full write-up in the DIY section of the Tech Forums for installing suspension on a B6. It's not that hard if you have the tools. You can use the hook and bolt spring compressors (rent them at an auto parts store) but it's a lot easier if you have access to a pro spring compressor. The rear is a little tricky to get the springs out and back in but not too bad.
    HW
    Veteran Member Three Rings Coker Rat's Avatar
    06 2.0T A4 w/quattro
    Fort McMurray, Alberta
    Re: suspension installation
    pay for it to be done, I found it to be a MAJOR PITA to compress the rear springs on my B7
    This is where I've been hiding... http://www.600rr.net
