    Junior Member Two Rings
    Mar 20 2010
    Delaware
    E30 Tunes? 034? IE?
    I’m currently enjoying running E30 fuel mix in my B9 SQ5 and want to pull the trigger on a full ECU/TCU tune while both 034 and IE are having sales.
    I can’t find any definitive info on E30 tunes from either, ChatGPT says IE has one but I can’t find it.
    Anyway, can anyone shed some light on this?
    I know this isn’t the correct forum, but it gets a lot more eyes than the B9 SQ5 one.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    soooo you are running e30 without a tune? thats a bit risky. not sure the OEM calibration can correct that much leanness going on.
    i havent seen either of them run an e30 tune, its either full corn or e60, which is what im running.
    RS6 hybrids and corn
    Established Member Two Rings carterferguson's Avatar
    Nov 03 2017
    Minnesota
    iE supports any blend from E0 to E100 with their TrueFlex kit.
    Mar 04 2025
    Pinehurst, NC USA
    E30 Tunes? 034? IE?
    IE probably the move w/ flex fuel & ethanol blends based on the research I’ve done.
    I’m occasionally running an e30 blend w/ JB4 custom tune on map 6.
    Mar 04 2025
    Pinehurst, NC USA
    Quote Originally Posted by bigern45 View Post
    JB4 can do e30 but I wouldn’t go more than e20 (~2gal e85) without a tune or at least piggyback
