Results 1 to 7 of 7
    Junior Member Two Rings
    Dec 09 2014
    Norwalk, CT
    2006 B7 S4 Avant Sprint Blue 130k mi, $3k, needs an intake manifold, in CT
    Owned since new, ordered fully optioned, RNS-E, carbon trim, rear air bags and window shades, etc. Full service records. Timing chain guides have not been done, but no chain rattle on cold start, oil changed every 5k miles, recently more like every 2-3k miles, doesn't burn oil. Recently developed misfires on bank 1, compression OK, camshaft adjusters OK, boroscoped and "everything looks decent for 130k some carbon build up," shop finally figured out manifold has a hole/is damaged at the injector for cylinder 1, they will not install a used manifold and want to order a new one from Germany at $4.5k (I think a new one can be had over here for $3350, ECS shows they can get one, and there are some used ones that don't look too bad for a few hundred dollars on eBay). Top of engine gaskets were done at 122k miles, valley pan, check valves, etc., also plugs, accessory belt and tensioner/pulley, snub mount, new headlights (clear corner) from Europe. Summer tires on factory (18", BBS I think) rims were new last summer and have about 1k mi on them, winter tires and rims (17", after market RS6 replicas I think) not as new but lots of tread left. I took a bunch of photos in case trip to the shop was the final trip for this guy, link below. This has been a great car, hoping someone wants it. Could probably part it out for more than $3k, but more than I can deal with. I did lob info in to Cars and Bids to see if they would run an auction for it, TBD. If no one wants it I am afraid it is going to a junk yard!
    https://mgb.smugmug.com/2006-S4-Avant
    May 20 2010
    Sent you a PM
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Feb 19 2012
    Methuen, MA
    Not sure if my pm went through. Call or text me at 978-857-7190, very interested and local.
    Feb 19 2012
    Methuen, MA
    Got the green light from the wife get back to me
    When you get a chance!
    Dec 09 2014
    Norwalk, CT
    Thank you for the interest. Car has a new home.
    Dec 04 2024
    Montreal quebec Canada
    wow she a beuty, if it wasent so hard to get it to Canada i would buy this in a heart beat
    Veteran Member Four Rings EvoRam's Avatar
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Bummer…I would’ve scooped this up I a heart beat…
    Jackal Tuned / BMC Panel Filter / Tweetler 93mm TB Adapter / SAI Delete / JHM IM Spacers / AWE 2.5" Downpipes / Corsa RSC / JHM SSB / 034 Zero-Gap Snub / 034 FSB Links / SD Mounts & Diff Inserts / 034 RSB & Links / Bilstein Sports / Neuspeed Springs
