So I just got my 3071r put on, on idle and accelerating it’s not smoking at all but on decel it’s smoking like hell. It’s got a hood dump and screamer pipe facing the ground, for the hood dump I used a piece of autozone pipe, at first I thought it might’ve just been whatever coating is on the pipe but that doesn’t really make sense to only be smoking on decel. I also used some copper silicone exhaust gasket sealant on the turbo to hood dump connection so maybe that’s causing it to smoke?
Before this I had an F21 with a messed up compressor wheel and a good bit of play that smoked a tiny tiny bit on decel, this 3071r is used but it has hardly any play
It’s got a rebuilt AWM head with super tech valve seals which I heard could go bad early on so maybe it’s that?
Also the PCV valve at the valve cover broke right before I finished so it just has a hose running from where the valve would be that dumps under the driver side engine mount.
I deleted the SAI and n80 valve. For the time being just to get the car driving I have a bolt in the 2 hoses that the n80 and hardline are in between and for the SAI I put a bolt in the small lower hose coming off the back of the head and a hose plug on the bigger pipe just above the small one.
Any advice and input is appreciated
