Title: Clean
Hey everyone! I'm looking to sell my 2001 Audi S4. It's Stage 3 car with a rebuilt motor. The chassis has 272k miles, and the engine rebuild was done in 2023. I'm asking $12,500 OBO, and would prefer to move on from it fast as I have other projects I'd rather focus on. Contact me here, or on my cell with any questions: 224-766-1066.
Overview:
I've owned this S4 since 2017, and I originally purchased it as a stage 3 project. I started by swapping the interior to what is seen in the photos, then, in 2022, I had the car repainted as the orginial paint was too far gone for me to save. I purchased some B6 S4 18" AVUS Wheels and had them refinished. Then, in 2023, the timing chain pulley gave out on me. I decided to pull the engine from the car rebuild it. This consisted of me stripping the motor to the crank, and changing all of the following parts...
- Oil Pump
- Crankshaft & Rod Bearings
- Pistons & Rods from 70k Mile Donor Engine
- Remachined Cylinder Heads with New Intake & Exhuast Valves
- Piston Rings
- Rear Main Seal
- Timing Belt & Water Pump
- Main Stud Bolts
- Camshaft Timing Components
After rebuilding the engine, I decided to upgrade the car with some performance parts. Some of the parts were on the car when I had purchased it, and the other I installed myself, including...
- SEP Auto KO4 Turbos
- 710N Diverter Valves
- Wiring Harness from AudiS4Parts.com
- Stainless Steel Brake Lines
- New Parking Brake Cables
- One Piece Aluminum Driveshaft
- Spec Stage 3+ Clutch & 034 Motorsport Aluminum LWFW
- 630cc Fuel Injectors
- 034 Motorsport Stage 3 Tune
- Intake Manifold Phenlic Spacers
- 034 Motorsport MAF
- Red Coil Packs w/ Conversion Kit
- Catless Downpipes w/ XS Power Twin II Exhuast
- Engine & Transmission Mounts
- ST Coilovers
Since then, I've drove the car in the state it's in for the past 2 years. I still changed little things here and there that needed to be changed, including the following; Headliner Repair, A & C Pillar Covers, Hazard Switch, Windshield, Cup Holder, Side Mirros, Arm Rest, Ash Tray Assembly, and the list goes on. I've enjoyed the car for many years, just time for me to move on.
Thanks for reading!
