Results 1 to 9 of 9
    Oct 15 2020
    Eagle River, Alaska
    Free key pairing - KW1281Test program
    Follow-up from a post I left on another thread as the KW1281Test program definitely deserves its own B6 thread, Ive not seen it previously discussed here.
    I don't have VCDS to perform key adaptation, I don't really want to buy it and I was thinking it might be possible to use Vag K Commander for key adaptation instead. Here is what I found;
    I previously had a spare key cut and a new virgin RFID chip, wanted to get it adapted to my immobilizer-on ECU. I connected Vag K Commander, read the ECU/Cluster SKC and then tried using the programs KEY LEARNING feature. I first re-paired my original (working) key and then added the new key. It was successful with pairing the new virgin RFID chip to the ECU immobilizer, car would start and run with the new key which previously caused ECU immobilizer to shutoff engine after 2 sec of starting. The gotcha catch is that Vag K Commander does NOT also pair the new key to the clusters (separate) immobilizer! The car will run and drive with just the ECU immobilizer working, but the cluster immobilizer causes the hazard lights to flash and the climate control system to lockup in SAFE mode. Same thing happens if trying to to use the new unpaired key with the ECU immobilizer turned off, there does not seem to be any way I can find to separately turn the cluster immobilizer off.
    I next discovered a free command line program called kw1281test. More on this program at;
    https://github.com/gmenounos/kw1281test/wiki
    https://fiddly.net/mk4/mk4-vw-key-coding.html (key adaptation instruction for muggles)
    https://forums.tdiclub.com/index.php...native.509151/ (5 years of forum postings)
    Bottom line, this free open source program 100% works to pair new keys to a B6 immobilizer system (ECU AND Cluster)!
    Pre-compiled distributions of the program are available so you do not need to mess with compiling it yourself from Github, just download appropriate version for your OS from
    https://github.com/gmenounos/kw1281test/releases/ (I used kw1281test_0.99.9-beta_Win10.zip , works fine on the older windows 8.1 laptop I use for flashing)
    This is a command line program, no GUI (yet) so you need to know the basics of running command line program, changing directory (CD), and entering commands. Pretty good instructions at https://fiddly.net/mk4/mk4-vw-key-coding.htm but note that these are written specific to using with apple OS and for a VW, if you are on windows or linux it will be slightly different. For Windows, you do not need to enter cable SN, just enter the COM port your cable is using (COM2, COM3, or whatever).
    I first tried running the GetSKN command to test and it did not initially work. It communicated with the cluster, just did not work to return the SKC. The suggested command line code I first used that did NOT work was;
    KW1281Test COM3 10400 17 GetSKC
    edit- figured out from https://forums.tdiclub.com/index.php...1/post-5752784
    Using just the the above GetSKC command to cluster works for VW's without encrypted instrument cluster. Our A4 B6 model RB4 instrument cluster is encrypted so the file cannot be read without first putting the cluster into "New Mode". Then, KW1281test can read the SKC (unencrypted) and afterwards you need to put the cluster back into "Adapted Mode" before re-starting the car. This can all is done by running the following 3 command lines, one after another;
    kw1281test COM3 10400 17 ToggleRB4Mode
    kw1281test COM3 10400 17 GetSKC
    This command sequence provides a quick and easy way for pulling the SKC from the cluster, rather than using separate Vag K Commander program to get SKC from the ECU Eeprom as is often suggested.
    KW1281test GetSKC command apparently can find the SKC on the TDI diesel EDC15 ECU (module 1), but the location within ECU EEPROM where it is stored is different for Audi ME7.5 ECU and the command cannot resolve that. Explanation of how to read SKC directly from an Audi ECU EEPROM .bin displayed in a Hex editor can be found within https://sites.google.com/site/imnuts/home , (at .bin address 32 and 33). Similarly for a decrypted cluster .bin, the SKC hex bits can be found at address 46 & 47.
    To read the ECU EEPROM.bin file, Nefmoto command line EEPROM program ME7_95040 can be used to read the EEPROM.bin file from the ECU over the OBDII port
    http://nefariousmotorsports.com/foru...c=1168.0title=
    once you have a read of the EEPROM.bin you can then use a separate program EEPROMTool_04 to display info from the .bin,
    get SKC from ECU, turn ECU immobilize off/on, change VIN and other EEPROM functionality for ECUs and Clusters;
    http://nefariousmotorsports.com/foru...p?topic=6134.0
    or https://github.com/turboat/eepromtool/releases/
    For key adaptation, the KW1281test Key adaptation command that worked perfectly to re-adapt my old key and add one new key was;
    KW1281Test COM3 10400 17 AdaptationSave 21 2 01111
    (syntax is: using cable on windows COM3, 10400 baud rate, module 17 (cluster), writing to module channel 21, it adapts 2 keys, logged in with example SKC 01111)
    My one clarification of the key adaptation instructions for the "Fiddy" website; the key adaptation did not work first time I tried because after I sent the command, I left the original key on and in the ignition for too long, adaptation sequence started before I removed and replaced the first (original) key. It was necessary to send the command and then fairly quickly turn ignition off, remove first key and replace it back in ignition and turn 1 click to run (not start) position. The KW1281Test program takes a few seconds from time the command line is issued to re-connect to the ECU and it expects to have the key removed (ignition off) and then replaced and find it turned back to run position when it re-connects. After couple of seconds, the instrument immobilizer icon will turn off and then you need to remove first key, insert next key (turned to ON) and it will find and adapt it next. There are no program prompts explaining what to do with the keys so no need to wait, just change out key(s) after the previous key has finished and instrument immobilizer turns off.
    KW1281Test has a bunch of other commands available, looking forward to trying out more features.
    Mar 12 2013
    Houston, Texas
    Great info!! Thank you for sharing. This should stickied to the "Tech Archives" for future reference.
    Sep 16 2010
    Central Wash
    Any chance you want to try this on a Rb8 / B7 cluster? Probably a long shot, but querying the ECU for the pin seems like the only way we'll ever get to pair keys on those.
    Oct 15 2020
    Eagle River, Alaska
    It does look as if KW1281test program was developed to work with RB8 clusters.
    Here is one testimonial of RB8 key adaptation;
    http://nefariousmotorsports.com/foru...=20859.0title=
    However, in the following thread from user TR7, they were unable to get KW1281test working with a B7 due to its use of CANBUS rather than K-line. T̶h̶i̶s̶ m̶i̶g̶h̶t̶ o̶n̶l̶y̶ b̶e̶ a̶ p̶r̶o̶b̶l̶e̶m̶ i̶f̶ y̶o̶u̶ t̶r̶y̶ t̶o̶ u̶s̶e̶ K̶W̶1̶2̶8̶1̶t̶e̶s̶t̶ i̶n̶s̶t̶a̶l̶l̶e̶d̶ i̶n̶ a̶ B̶7̶ c̶h̶a̶s̶s̶i̶s̶, p̶o̶s̶s̶i̶b̶l̶y̶ m̶i̶g̶h̶t̶ s̶t̶i̶l̶l̶ w̶o̶r̶k̶ i̶f̶ t̶h̶e̶ R̶B̶8̶ c̶l̶u̶s̶t̶e̶r̶ i̶s̶ i̶n̶s̶t̶a̶l̶l̶e̶d̶ i̶n̶ B̶6̶ o̶r̶ c̶o̶n̶n̶e̶c̶t̶e̶d̶ o̶n̶ b̶e̶n̶c̶h̶?̶ Edit-no, still does not work due to CANBUS of B7 cluster.
    https://forums.tdiclub.com/index.php...1/post-5794657
    KW1281 has a specific command for reading RB4 and RB8 cluster EEPROM. Early version of the software just worked with RB8 and command was "DumpRB8Eeprom" but on newer versions the software author included support for (decrypted) RB4 and changed the command to "DumpRBxMem"
    https://forums.tdiclub.com/index.php...4#post-5625344
    Note the command arguments suggested here for address and file length needed to read an RB8 suggested as;
    KW1281Test.exe COM1 10400 17 DumpRBxMem $10400 $400 (note- I think these arguments might need to be different for an RB4??)
    If you just need to retrieve SKC from an RB8 you probably do not need to do an entire Eeprom dump, the "GetSKC" command is supposed to work on RB8 after decrypting;
    https://forums.tdiclub.com/index.php...1#post-5673364
    Command instructions specific for decrypting and reading RB4 and RB8 clusters are at https://forums.tdiclub.com/index.php...5#post-5752784
    If you need any help getting kw1281test to work, feel free to ask for more clarification. Definitely watch some youtube instructions for running command line programs if you are unfamiliar with that process. The software author also seems to be fairly responsive to answering questions in the TDIClub forum and would be an even better resource for more complex questions.
    As mentioned in my first thread, I did successfully use the GetSKC and Adaptation commands to pair keys to my stock RB4 cluster B6. Unfortunately, I was unable to get it working to read SKC or DumpEeprom directly from the ECU (module 1) instead of from cluster (module 17). This command was developed to work for the TDI EDC15 ECUs but apparently is not supported for gas ME7 ECUs with different storage location for SKC within the ECU EEPROM.
    Oct 15 2020
    Eagle River, Alaska
    Looking at this further, per thread;
    https://www.audizine.com/forum/showt...ighlight=95040
    Not all RB8 clusters use the same immobilizer. RS6 used a RB8 cluster with same immo3 as used in B6 and so can be paired with a B6 immo3 ECU. The B7 cars had immo4 system and is not compatible with immo3 so cannot be used with a B6 ECU, even if you change the SKC to match.
    Oct 15 2020
    Eagle River, Alaska
    One other use for KW1281test program is pinging (and possibly reading?) other chassis and drivetrain modules using command line syntax;
    KW1281Test PORT BAUD ADDRESS COMMAND
    PORT = COM1|COM2|etc. (Windows)
    BAUD = 10400|9600|etc.
    ADDRESS = The controller address, e.g. 1 (ECU), 17 (cluster), 46 (CCM), 56 (radio)
    COMMAND = ReadIdent (connects to the module specified in ADDRESS and returns the module identity)
    possible generic audi module addresses (not all will be present on a B6) you can try to ping are ;
    01 – ECU
    02 – Automatic transmission
    03 – ABS brakes
    04 – Steering angle
    05 – Ignition authorization
    06 – Passengers seat memory
    07 – Control head
    08 – Automatic heat, ventilation, air condition
    09 – Central electronics
    0B – Secondary air heater
    0D – Left sliding door
    0E – Media player 1
    0F – Digital radio
    10 – Parking/steering assist
    11 – Engine electronics 2
    12 – Clutch
    13 – Auto Dist. Reg
    14 – Suspension electronics
    15 – Airbags
    16 – Steering wheel
    17 – Instrument Cluster
    18 – Auxiliary heating
    19 – CAN getaway
    1B – Active steering
    1C – Position sensing
    1D – Driver identification
    1E – Media Player 2
    1F – Satellite tuner
    21 – Engine electronics 3
    22 – AWD
    23 – Brake booster
    24 – Antislip (ESP)
    25 – Immobilizer
    26 – Electrical sunroof
    27 – Control head rear
    28 – HVAC rear
    29 – Left light
    2B - Steering Column Lock
    2D – Intercom
    2E – Media Player 3
    2F – Digital TV
    31 – Engine
    32 – Differential locks
    34 – Level control
    35 – Central locks
    36 – Drivers seat memory
    37 – Navigation
    38 – Roof electronics
    39 – Right light
    3C – Side assist
    3D – Special function
    3E – Media player 4
    41 – Diesel fuel pump
    42 – Driver door electronics
    43 – Brake assistant
    44 – Steering assistant
    45 – Interior monitor
    46 – Central convenience
    47 – Sound system
    48 – Rear seat drivers side
    49 – Auto light switch
    4B - Multifunction Module
    4C – Tire pressure 2
    4D – Data transfer
    4E – Control head right rear
    4F – Central electronics 2
    51 – Electric drive
    52 – Passenger door electronics
    53 – Parking brake
    54 – Rear spoiler
    55 – Xenon range
    56 – Radio
    57 – TV tuner
    58 – Auxiliary fuel tank
    59 – Tow protection
    5C – Lane assist
    5D – Operations
    5E – Control head left rear
    5F – Information electronics
    61 – Battery regulator
    62 – Rear left door
    63 – Entry assist driver
    64 – Stabilizers
    65 – Tire pressure
    66 – Seat & mirror adjustment / seat rear
    67 – Voice control
    68 – Wipers electronics
    69 – Trailer
    6C – Rear view camera
    6D – Trunk electronics
    6E – Control hear roof
    6F – Central convenience 2
    71 – Batter charger
    72 – Rear right door
    73 – Entry assist passenger
    74 – Chassis control
    75 – Emergency call / Telematics
    76 – Parking aid
    77 – Telephone
    78 – Right slide door
    7D – Auxiliary heater
    7E – Control head dashboard
    7F – Information electronics 2
    8107 - Antenna
    811E - Burglary Protection FL
    811F - Burglary Protection FR
    8120 - Burglary Protection RL
    8121 - Burglary Protection RR
    82 - Heads Up Display
    8C - Hybrid Battery
    91 – Engine
    92 – Transmission
    93 – Immobiliser
    94 – Airbag
    95 – ESP
    96 – Instruments
    97 – Trip recorder
    98 – Tire pressure
    99 – Ignition switch
    9A – Central locks
    9B – Driver door
    9C – HVAC
    9D – Auxiliary heater (fuel)
    9E – Auxiliary heater (electric)
    9F – Stationery heater (water)
    A0 – Radio
    A1 – Navigation
    A2 – CD changer
    A3 – Telephone
    A5 - Front Sensor Driving Assist
    B0 – Roof display
    B1 – Upper console
    B2 – Park assist
    B3 – Trailer module
    B4 – Central electronic
    B5 – Special function
    B6 – Steering wheel
    BD - Hi-voltage battery charger
    C6 - Battery Charging
    D6 - Light Control Left 2
    D7 - Light Control Right 2
    Oct 15 2020
    Eagle River, Alaska
    Full list of all available KW1281test commands with a few B6 useage notes from me;
    Usage: KW1281Test PORT BAUD ADDRESS COMMAND [args]
    /dev/ttyXXXX (Linux)
    AABBCCDD (macOS/Linux FTDI cable serial number)
    COMMAND =
    ActuatorTest
    AdaptationRead CHANNEL [LOGIN]
    CHANNEL = Channel number (0-99)
    LOGIN = Optional login (0-65535)
    AdaptationSave CHANNEL VALUE [LOGIN]
    VALUE = Channel value (0-65535)
    AdaptationTest CHANNEL VALUE [LOGIN]
    AutoScan
    BasicSetting GROUP
    GROUP = Group number (0-255)
    (Group 0: Raw controller data)
    ClarionVWPremium4SafeCode
    ClearFaultCodes
    DelcoVWPremium5SafeCode
    DumpEdc15Eeprom [FILENAME] (Only works with TDI diesel EDC15 ECU)
    FILENAME = Optional filename
    DumpEeprom START LENGTH [FILENAME] (Only works on the B6 encrypted RB4 instrument cluster after running command ToggleRB4Mode to decrypt)
    START = Start address in decimal (e.g. 0) or hex (e.g. $0)
    LENGTH = Number of bytes in decimal (e.g. 2048) or hex (e.g. $800)
    DumpMarelliMem START LENGTH [FILENAME]
    START = Start address in decimal (e.g. 3072) or hex (e.g. $C00)
    LENGTH = Number of bytes in decimal (e.g. 1024) or hex (e.g. $400)
    DumpMem START LENGTH [FILENAME]
    START = Start address in decimal (e.g. 8192) or hex (e.g. $2000)
    LENGTH = Number of bytes in decimal (e.g. 65536) or hex (e.g. $10000)
    DumpRam START LENGTH [FILENAME]
    DumpRBxMem START LENGTH [FILENAME]
    START = Start address in decimal (e.g. 66560) or hex (e.g. $10400)
    FindLogins LOGIN
    LOGIN = Known good login (0-65535)
    GetSKC (Only works on the B6 encrypted RB4 cluster after running command ToggleRB4Mode to decrypt, does NOT work for ME7 ECU EEPROM)
    GroupRead GROUP
    LoadEeprom START FILENAME
    FILENAME = Name of file containing binary data to load into EEPROM
    MapEeprom
    ReadFaultCodes
    ReadIdent
    ReadEeprom ADDRESS
    ADDRESS = Address in decimal (e.g. 4361) or hex (e.g. $1109)
    ReadRAM ADDRESS
    ReadROM ADDRESS
    ReadSoftwareVersion
    Reset
    SetSoftwareCoding CODING WORKSHOP
    CODING = Software coding in decimal (e.g. 4361) or hex (e.g. $1109)
    WORKSHOP = Workshop code in decimal (e.g. 4361) or hex (e.g. $1109)
    ToggleRB4Mode (flips status of RB4 instrument cluster EEPROM, run first before reading or dumping cluster, then run again to reset to Adapted (encrypted) mode)
    WriteEdc15Eeprom ADDRESS1 VALUE1 [ADDRESS2 VALUE2 ... ADDRESSn VALUEn]
    ADDRESS = EEPROM address in decimal (0-511) or hex ($00-$1FF)
    VALUE = Value to be stored at address in decimal (0-255) or hex ($00-$FF)
    WriteEeprom ADDRESS VALUE
    VALUE = Value in decimal (e.g. 138) or hex (e.g. $8A)
    Junior Member One Ring
    Dec 22 2024
    Colorado
    This is very interesting. Let me make sure that I'm following correctly.
    Does this mean that using kw1281test would enable me to use a purchased key from anywhere? Does it have to be cut to my car before I pair it?
    Seems too easy, what's the catch?
    Oct 15 2020
    Eagle River, Alaska
    Spitnik-
    kw1281test basically just replaces the need for having VCDS to adapt the key, with additional benefit that it can also read the SKC (from cluster) which VCDS will not perform.
    An uncut key blank will not insert into the ignition, the cut slot is needed to allow it to insert so you would need to get a key blank cut first before running the adaptation. What the adaptation does is to perform the first one-time pairing of the new/virgin IP48 RFID chip to the immobilizer. Used keys previously adapted to a different immobilizer cannot be adapted to work with another car.
    For $18 you can get an uncut key blank, virgin ID48 RFID chip and new plastic case;
    https://www.amazon.com/NPAUTO-Replac...BDFS56CC&psc=1
    Get the key blade cut at a locksmith and the chip adapted to your car with kw1281test and you will have a spare second key that will start and run the car without setting off the ECU or cluster immobilizers.
    The slight catch is that 2003-2005 B6 needs a FOB remote to lock/unlock doors with part number; 8Z0 837 231 F, the cheap amazon FOB (above) unfortunately is 8Z0 837 231 E and will not work to remote open doors on a B6. (2002 used an entirely different FOB). I searched for a reasonably priced new replacement 8Z0 837 231 F FOB but I was unable to find one that was < $100. Unlike some of the other VAG FOB numbers, 8Z0 837 231 F seems to have minimal aftermarket support for replacement options. Rather than buying a new OEM FOB, I just went on EBAY and for less than $20 I bought a used 8Z0 837 231 F key & FOB. Snap it apart, throw away the top half with used key and immobilizer chip, snap the used FOB bottom half to the new top half key & IP48 chip to make a functional door FOB and ignition key assembly. Note that pairing the FOB door remote transmitter is a completely separate and electronically unrelated process from adapting the key and ID48 chip to immobilizer. Amazon also list replacement FOB case shells and key blanks without the "E" door remote transmitter electronics board included for slightly less cost but these do not include the ID48 chip needed for immobilizer so easier to just order the cheap but wrong "E" transmitter board and then replace it. (Or order the ID48 chip separately)
    Rather than sourcing the 8Z0 837 231 F door FOB for the B6, another pathway to a new key would be to use a compatible A4 B7 FOB per thread;
    https://www.audizine.com/forum/showt...ob-for-B6-DIY/
    Either get a new B7 FOB with a virgin ID48 chip and blank key blade, or buy a used one and replace the IP48 and key blade. The A4 B7 remote that works to with the 2003-2005 B6 CCM module is audi part 8E0837220R, FCC ID MYT4073A. I cannot tell if the B7 key ID48 chip is identical to the B6 chip, so you might need to source a new ID48 chip either way.
