Results 1 to 28 of 28
    Oct 23 2014
    Buffalo, NY
    WTB: Project Car Parts
    I’m looking for a large number of parts and figured before ordering new and destroying my budget, I would ask here to see if anyone has any of these in good used condition or laying around new that I can live with while saving some cash. Please PM me with parts you may have for sale along with your asking price. Please be aware that parts will need to be shipped to 14150 unless you’re within a few hours of Buffalo, NY. I will only pay with PayPal goods and services and won’t reply to contact uncle Vinny he has your part for sale.
    • Exhaust - AWE Twin II, Borla or let me know what you have
    • 01E Master Rebuild Kit (I don’t have to have now but if the price is right) - new preferred
    • JHM Short Shifter Trio - (I don’t have to have now but if the price is right) - new preferred but let me know what you have
    • S4 avant rear bumper or just the lower valance - Pending
    Thanks for looking and for reaching out if you do. Please let me know if you feel I’m missing anything in my requested items.
    Acquired Items:
    • B&W K04s
    • Bilstein PSS9s
    • Hotchkiss Sways
    • Brembo GT 355x32 front brake kit - this turned out to be a stoptech st40 setup - went with an 18z setup
    • GLA45 AMG 350x32 Brembo front rotors
    • Stock Size (256?) Zimmerman blank rear rotors
    • Brembo ceramic pads front and rear
    • PB5 18z caliper bolts
    • New crossover tubes, bleeders, dust seals and pad abuttment plates for the 18z switch around
    • SMICs: Wagner w/ carbon fiber shrouds
    • Bosch Injectors: EV14 630cc - sending them off for ultrasonic cleaning and flow testing at Race City Injector
    • OEM Flywheel
    • LUK RepSet B5 RS4 clutch
    • ESCTuning Clutch install kit
    • CSF Aluminum radiator for a manual car
    • Bi-Pipes - 2005 allroad cast throttle body boot with factory bi pipes
    • 3 Bar MAP sensor
    • MAF sensor - Hitachi 85mm used to my chagrin
    • ETSpec Hitachi MAF pigtail
    • Tuning - Blake at ETSpec stage 3 no anti-lag, no water meth, no e85
    • AEM Wideband sensor and center vent pod - not happy about having to buy this - I don’t want to look at it
    • Bosch Adjustable fuel regulator ETSpec didn’t want it in the equation while tuning sent back
    • 034 end links F&R
    • 034 adjustable rear upper control arms
    • 034 RS4 rep turbo inlets
    • 034 SMIC Silicone piping
    • 034 Adjustable Front Upper Control Arms Camber Correcting/Street
    • 034 Density Line Lower Control Arms
    • 034 Heavy Duty Tie Rods
    • 034 density line motor mounts
    • 034 density line transmission mounts
    • 034 Silicone breather hose/spider hose replacement
    • Fuel Pump - Walbro 450 and “044” dupe from 034 ordered as well just in case
    • Y-Pipe with integrated 85mm MAF flange & Intake - Ideally PB5 or SEP or similar
      - I went with 034’s Bosch billet MAF housing, S4 airbox adapter, and reinforced silicone intake hose instead to keep the stock engine covers and stock y
      I was forced to go with the ETSpec intake tube with integrated Hitachi MAF holder - I hope the stock y and engine covers will still work.
    • G2 custom caliper paint - Porsche Ruby Star Neo
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 31 2022
    Prescott AZ
    I have brand new. 034 inlets
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Matthewest91 View Post
    What’s your asking price?
    °2011 A4 | 6MT
    Junior Member One Ring Cheekie's Avatar
    Nov 07 2017
    Flexico
    I will PM you
    Oct 23 2014
    Buffalo, NY
    All PMs replied - thanks to all who have reached out thus far.
    °2011 A4 | 6MT
    Oct 23 2014
    Buffalo, NY
    Bump. Still looking for many items before I buy new. I haven’t received plenty of messages but mostly for parts I’m not looking for. Please reply with the parts you have that are on my list (updated) and not just with your part out thread link for me to pick through what’s left - thanks!
    °2011 A4 | 6MT
    Oct 23 2014
    Buffalo, NY
    I PMed you and I’m still interested in these inlets.
    °2011 A4 | 6MT
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    I'm near certain that I have a set of almost new ev14 630cc.
    Lemme check my spare parts bin.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by VR6Bomber View Post
    Thank you! I just made a deal with someone for a set last night that is pending but I’ll let you know if it falls through for some reason. I appreciate the reply and will update the OP.
    °2011 A4 | 6MT
    Established Member Two Rings kmikuta's Avatar
    Jul 11 2015
    Laser B5 S4 Project, B8.5 S4, '63 LSX Chevy 2
    Chicago, Il
    As a heads up, the Tial MVI gates are fully unecessary for your application. Doesn't mean you can't run them or shouldn't strive to use the nicest possible parts, they may require some modification to the MVI brackets or your compressor housings. I can't say I've seen them used on a BW k04, so I'm not positive they're simply bolt on. May be more headache than it's worth...
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by kmikuta View Post
    Thank you for the heads up! I was initially looking at these below.
    https://jaeinnovations.com/products/...34518345&_ss=r
    °2011 A4 | 6MT
    May 13 2009
    XXXX
    Quote Originally Posted by bakedziti View Post
    Ok. I did locate my 630cc set if you need them. I'll pm you my info
    Senior Member Two Rings Quattro 13's Avatar
    Sep 01 2013
    B4 90Q, C4 UrS6, B5 S4 (x2), '72 2002, E46 M3
    Buffalo, NY
    Hey man, glad to see you're moving ahead with the project!
    I hadn't reached out before now because your post indicates you'd prefer a new example; but I have a used, OEM B5 S4 dual-mass flywheel that has ~145k miles on it and was in good working order when removed. I would be willing to donate that to the cause if you’re interested in picking it up.
    Regarding the actuators, if your K04s are genuine Borg-Warner, and brand new, I agree there is no need to upgrade the actuators. BW ones are good quality. That said, just to put the correct information out there, the TiAL MVI 2.5 actuators are absolutely compatible with K04s, and can be purchased as a direct, bolt-on solution. Not any more difficult to install on K04s than they would be on any other pair of turbos.
    The freshly rebuilt K04’s that I bought for my ‘winter beater’ build came with a pair of new Mamba actuators installed on them. I wasn’t satisfied with the operation of the Mamba units when I was setting them prior to install, so I got the set of the TiALs that I had bought for my “good” build out of my parts bin to study the differences. After doing so, I was impressed enough with the build- and material-quality of the TiALs compared to the Mambas that I opted to use those TiAL units I had on-hand for my winter build, and purchased a second set for use on my nicer build. I have yet to disect a BW actuator, so I can't speak to the design of those, but anecdotally they certainly seem to hold up well.
    I have no affiliations, nor axes to grind (I buy stuff from both companies regularly); but for what it’s worth SRM also sells a pair of the TiALs with actuator rods designed for the 2.7T configuration, but they “only” charge $379 vs JAE’s $515, so that’s where I got mine:
    https://sillyrabbitmotorsport.com/ti..._2nJBXnM2PHugR
    1972 BMW 2002 - Malaga over Saddle, 4-Speed Manual
    1995 Audi 90 Quattro - Resprayed Laser Red, 5-Speed Manual
    2001.5 Audi S4 - Brilliant Black, Sport Package, 6-Speed Manual (Finally back together, but won't start...)
    2001.5 Audi S4 - Nogaro Blue, Sport Package, 6-Speed Manual (Currently Under Construction)
    2006 BMW M3 - Interlagos Blue, Competition Package, 6-Speed Manual
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Quattro 13 View Post
    Thank you! I’m glad to be getting back to this project as well and hope that this time we can finish it off.
    I appreciate the added information about the tial mvi 2.5s. I also saw the set at SRM but I wasn’t sure if they maybe didn’t come with brackets or something like that but it’s good to hear they’re compatible from either site.
    The new turbos are genuine borg warner K04s directly from Borg Warner, so I’m hopeful the wastegate actuators will be good to go as is at least for now being that I increased my turbo cost 3X from the original set but the piece of mind is worth it.
    I also appreciate the offer on the flywheel. Maybe we can meet up sometime in the near future to take care of that.
    How’s your car situation going? The last we spoke I believe you were in the market for a new B5.
    °2011 A4 | 6MT
    Sep 01 2013
    Buffalo, NY
    Yep, the zinc plated steel brackets shown in SRM's photos are included, and overall fitment was excellent.
    You can't go wrong with BW K04's on these cars, I'm sure you'll be glad you went the route you did.
    If you want that flywheel you're welcome to come by and pick it up, just shoot me a text and we can setup a time. You can see for yourself how my car situation is going (hint: not great lol).
    I'm virtually drowning in car projects and nothing seems to be going right at the moment, as evidenced by the big "Car Won't Start" thread I just started in the B5 S4 general discussion forum, asking for input of what to check next. By all means, give it a look and see if you have anything to suggest!
    Oct 23 2014
    Buffalo, NY
    Oh man, I’ll give your thread a look but I’m sorry to hear you’re having trouble. If I were at home today I would offer to come help although I’d probably just be in the way in the end.
    I appreciate the info on the SRM Tial WGs and coming with the brackets, it’s definitely more affordable than JAEInnovations. I’ll shoot you a text this weekend. I have to head down to the Southtowns already so should be easy to coordinate timing if you’re available. Thank you again!
    °2011 A4 | 6MT
    Oct 23 2014
    Buffalo, NY
    Does anyone know the CB on a 2014 R8 rear hubs? I ask because I bought some Brembo GT 4 pot calipers and rotor hats with hardware but will need to replace rotors. I’d prefer to do a 1 piece design and think the rear rotor from a 2014 R8 may work, PN #420615601J, but I get conflicting results on the CB being 57.1 or maybe 66.6 (hoping 57.1) and the size is sometimes listed at 355mm or sometimes 356mm (hoping 355). Still not sure on the hat offset or anything like that so if anyone has any input for this it would be greatly appreciated! I am aware of the paragon options and they are my second choice or girodisc at #3.
    °2011 A4 | 6MT
    May 10 2018
    MA
    Gen 1 R8 is 57.1. Gen 2 is 66.1
    Brembo GT rear kit only used a 328x28mm rotor and needs their parking brake setup. Don’t see how it would work on a larger rotor tbh, without a different bracket being done. Gen 1/2 rear brakes are 356x32 with their own parking brake. I have R8 front and rear calipers and rotors (brembo front 2 piece) on my car.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by RMode View Post
    I’m thinking the 355x32 rear rotors in the front - I’m not doing the Brembo rears - but again I get conflicting information as to the actual diameter between 355 and 356. Admittedly I still don’t know the hat offset or if it’s anywhere near close.
    °2011 A4 | 6MT
    May 10 2018
    MA
    I can promise the rear is 356mm, not 355, for an R8 rear rotor. Also needs a caliper bracket even if being used up front
    The GT front kit was 355mm. No idea what its front offset was though. I’m sure you could ask brembo directly
    Brembo replacement front rings are part # 09.9306.11 and 21
    Oct 23 2014
    Buffalo, NY
    I have a caliper bracket with the Brembo GT kit and it may be worth getting a new set of brackets for the Brembo kit machined to be able to use more readily available rear rotors up front. I want to use a one piece rotor instead of two.
    °2011 A4 | 6MT
    Oct 23 2014
    Buffalo, NY
    Bump - OP is updated. Please let me know if you have any of the remaining items in by Friday 6/13. After 6/13 I plan to order what remains as new items. I’m heading to Turkey for a few weeks next month and would like everything here for when I get home so I can hopefully knock out this project mechanically and get my garage back before the winter this year for my fiancé and I to use for our dailies.
    °2011 A4 | 6MT
    Oct 23 2014
    Buffalo, NY
    One last bump with OP updated.
    and it was like Christmas in June today with 3 boxes arriving from FCP Euro.
    There’s another coming this week and I still need to find the remaining items in the OP of this thread but working through the parts list and my budget. I know I post the turbos elsewhere but they’re pretty enough to post an image or two again (oh well idc).
    Getting excited to get started in finally reviving this project at the end of July when I get home from Turkey.
    Thank you in advance for reaching out!
    EDIT: does anyone have a suggestion for injector cleaning services and flow testing at a reasonable price? Thanks!
    °2011 A4 | 6MT
    Jan 01 2018
    utah
    Depends on where you're at, but a shop around me charges 20 each to check and clean.
    Sent from my SM-S928U using Audizine Forum mobile app
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by travis_w View Post
    Thank you! I was actually looking for send away services and suggestions because I’d like to go with someone tried and true over a local shop that could maybe do what I need, unless I can find a local specialty shop. Appreciate the input!
    °2011 A4 | 6MT
    Established Member Two Rings chili dog's Avatar
    Oct 26 2018
    Sterling, VA
    Mooresville, NC: http://racecityinjector.com
    I sent out a set of 4, s3 injectors back in 2022, for my k04 B7 a4 from VA. Bought them used here off a forum member and wanted them cleaned and tested before installing. It was around $110.00 at the time which included cleaning, new seals, testing with print out and return shipping. No issues since.
    I’ve got a used walbro 450, another thing I got off here but haven’t tried it out. You can have it for the price of shipping if you’re interested. I can figure out how to clean and test it if so.
    Pon
    Jan 01 2018
    utah
    https://fuelinjectionutah.com/
    They say they offer 24hr turn around times.
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by chili dog View Post
    Pon
    Thank you for the information on the injectors! Additionally, yes I’m certainly interested in the Walbro fuel pump. I’ll shoot you a message. Thanks again!
    Great, thank you for the information!
    °2011 A4 | 6MT
