- Exhaust - AWE Twin II, Borla or let me know what you have
- 01E Master Rebuild Kit (I don’t have to have now but if the price is right) - new preferred
- JHM Short Shifter Trio - (I don’t have to have now but if the price is right) - new preferred but let me know what you have
- S4 avant rear bumper or just the lower valance - Pending
Thanks for looking and for reaching out if you do. Please let me know if you feel I’m missing anything in my requested items.
Acquired Items:
- B&W K04s
- Bilstein PSS9s
- Hotchkiss Sways
Brembo GT 355x32 front brake kit - this turned out to be a stoptech st40 setup- went with an 18z setup- GLA45 AMG 350x32 Brembo front rotors
- Stock Size (256?) Zimmerman blank rear rotors
- Brembo ceramic pads front and rear
- PB5 18z caliper bolts
- New crossover tubes, bleeders, dust seals and pad abuttment plates for the 18z switch around
- SMICs: Wagner w/ carbon fiber shrouds
- Bosch Injectors: EV14 630cc - sending them off for ultrasonic cleaning and flow testing at Race City Injector
- OEM Flywheel
- LUK RepSet B5 RS4 clutch
- ESCTuning Clutch install kit
- CSF Aluminum radiator for a manual car
- Bi-Pipes - 2005 allroad cast throttle body boot with factory bi pipes
- 3 Bar MAP sensor
- MAF sensor - Hitachi 85mm used to my chagrin
- ETSpec Hitachi MAF pigtail
- Tuning - Blake at ETSpec stage 3 no anti-lag, no water meth, no e85
- AEM Wideband sensor and center vent pod - not happy about having to buy this - I don’t want to look at it
Bosch Adjustable fuel regulatorETSpec didn’t want it in the equation while tuning sent back- 034 end links F&R
- 034 adjustable rear upper control arms
- 034 RS4 rep turbo inlets
- 034 SMIC Silicone piping
- 034 Adjustable Front Upper Control Arms Camber Correcting/Street
- 034 Density Line Lower Control Arms
- 034 Heavy Duty Tie Rods
- 034 density line motor mounts
- 034 density line transmission mounts
- 034 Silicone breather hose/spider hose replacement
- Fuel Pump - Walbro 450 and “044” dupe from 034 ordered as well just in case
Y-Pipe with integrated 85mm MAF flange & Intake - Ideally PB5 or SEP or similarI was forced to go with the ETSpec intake tube with integrated Hitachi MAF holder - I hope the stock y and engine covers will still work.
- I went with 034’s Bosch billet MAF housing, S4 airbox adapter, and reinforced silicone intake hose instead to keep the stock engine covers and stock y- G2 custom caliper paint - Porsche Ruby Star Neo
