Results 1 to 7 of 7
    Apr 26 2018
    New Jersey
    2011 s5 peelers on 2015 allroad fottament question.
    9Jx19H2ET33
    Found a pair of peelers for a good price. Know I will need spacers but just trying to see exactly what I would need before I pull the trigger. And if not messing with suspension what size tires could I use?
    Not sure if this is the right place to ask this question so sorry if this is in the wrong spot.
    Thanks in advance!
    Jul 16 2018
    Atlanta
    8K allroad 19" wheels are 19x8.0 et26. et33 -> et26 = 7mm spacer
    8K allroad 19" tires are 245/40r19 98Y XL.
    Using Michelin PSAS4 as an example (seems they don't make the CC2 in this size), 245/40r19 is supported on 8.0"-9.5" wheel width. The measuring rim width for 245/40r19 is 8.5". 1" wide wheel is going to give you about .4" wider tire cross section (9.6 on 8.0; 10.0 on 9.0). So if you don't want the outer tire face any further out, you might even not run a spacer at all.
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    I used S5 peelers with stock suspension and no issues.
    Feb 17 2004
    Liberty Hill, TX
    255/40/19 tires and 15mm spacers all around. 245's will be a little rounded (not quite stretched) on a 9" wide wheel
    2012 TT-RS | Sepang/Ebony
    2014 Allroad | Glacier/Ebony (sold and bought back)
    Sold: 2007 RS4 | Sprint/Ebony
    Apr 26 2018
    New Jersey
    Thanks so much everyone! Picked them up today.
    Apr 26 2018
    New Jersey
    And matt I just have to start looking at your previous posts. Whenever I have an allroad question you always have the answer I'm looking for. BTW the aftermarket brushed aluminum mirror caps you suggested fit perfectly.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by ShaneC View Post
    glad to hear :) I haven't posted a ton on here for Allroad stuff (not like I did for my B6/B7s), as the community is largely on FB and Discord now, for better or worse
