Results 1 to 29 of 29
    Junior Member Two Rings
    Jun 18 2018
    Calgary
    Buying a 2016 S5 w/super low kms
    Hi,
    So I found a 2016 S5 with 21000kms. I am travelling next week to go pick it up hopefully, the owner is meeting me 8 hours away.
    Anyone have thoughts on mileage here? I am a little suspicious, having dealt with an odo rollback issue in the past. I have purchased a carista and tried it on a friends 2015 S5 and it only pulls in the cluster odometer, contrary to what it does on my f150 where it shows a bunch of other module milage.
    I have a carfax report which appears mostly clean and up to date, however there has been no logged kms since 2020 when it was 20000kms.
    Want to make sure I don't get hosed here, thought was just to do a good visual on brakes, tires, hoses, belts - check for dash rattles or anything tampered.
    Any other suggestions?
    Thanks in advance
    Stage 3 Forum Advertiser Four Rings John@Nemesis's Avatar
    Nov 15 2014
    Las Vegas, NV
    Super low mileage vehicles are out there, for sure. I have a 2015 with 17k miles on it. It was more of a weekend daily for a long time and then I didn't need it for that anymore. Now I maybe put 500 miles a year on it, been that way for several years. Could be a similar situation. Check everything and if in doubt, have a ppi done on it.
    AKA: Hippiekiller
    2025 Deep Green Pearl SQ5
    2019 Cornflower Blue GTI Rabbit
    2017 Grey Black 911 C4S
    2015 Sepang Blue S5
    [email protected]
    @hewhohateshippies
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Low KM cars are definitely around. I have put less than 11000 KM on my RS5 in 5 years. It is smart to be cautious and do your due diligence, but low KMs aren't always a warning sign of odo tampering.
    Sent from my Pixel 8 Pro using Tapatalk
    Jun 18 2018
    Calgary
    Thanks yes, I agree I am sure there are lots of people who sunny weekend only their cars. I am curious how much tampering really happens out there with these cars, I assume not a ton but perhaps that is a bit naive.
    Dec 20 2012
    Quote Originally Posted by dsmp View Post
    Get a carfax for the vehicle and provided there is adequate history available, that should help you validate the KMs on the car. Also, ask the PO for the service records, which will also validate the KM.
    You should be able to get both of these items before traveling 8 hours to get the car.
    Jun 18 2018
    Calgary
    Quote Originally Posted by Mrads View Post
    Yeah got this stuff ahead of time, but the last service was 2020 at 20500kms, and now it has only 21350 or something which has me a bit nervous.
    Established Member Two Rings eskimo0101's Avatar
    Jan 22 2019
    Williamsville, NY
    850 KM in 5 years? Or for the majority on here, 528 miles in 5 years... just over 100 miles a year from 2020 to 2025. I'd be suspicious too, especially since it had averaged 5125 KM/year from 2016 to 2020. Did the seller give any explanation of why the car basically stopped being driven in 2020? I'd also be concerned the car hasn't seen a service in 5 years. With so few miles how old is the gas in the tank? Has it been sitting flat spotting the tires for years? How has it been stored? Rodent issues?
    Jun 18 2018
    Calgary
    yeah all good questions, however sort of lines up given he bought the car in 2017 with 17,500kms then drove it 1400kms where he lives and the next service was in 2020 with 20,481. Has been garage stored under a cover with battery tender and comes out the odd sunny weekend apparently. Pics look mint and went over it over facetime, but yeah.. seems really low.
    Nov 15 2014
    Las Vegas, NV
    Quote Originally Posted by eskimo0101 View Post
    Not at all weird. Especially if you're a car guy that loves the car. No real need to get rid of it, but also no real need to have it. 5 years go by and then the time comes. Same thing I have looked at with mine.
    AKA: Hippiekiller
    2015 Sepang Blue S5
    [email protected]
    @hewhohateshippies
    Jun 18 2018
    Calgary
    Well wish me luck I’m flying to get this thing and drive it home unless there are some major flags when I get there.
    Sent from my iPhone using ]][emoji[emoji6]][emoji6][emoji[emoji6]][emoji6]]Audizine
    Jan 22 2019
    Williamsville, NY
    Ok, didn't have the piece of the puzzle that the current owner bought it with 17500. Good luck on you trip. An 8 hour road trip is quite a haul for a car that hasn't been driven much at all since 2020. I'd definitely have AAA (Or I guess CAA since you're in Canada).
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    I'm down to a commute now that is less than 2mi a day for low mileage. Short trips and low mileage can be worse than longer trips and higher mileage due to fuel dilution. I try to get my car up to full operating temperature at least once a week and now change my oil at 3k instead of 6k.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    A little less than 2 years ago I bought a 2013 Q5 with 11,850 miles on it. It also hadn't been driven much in the past year. It was in Albuquerque, about 5+ hours away from me. Drove it home without issues. It was, however, bought from an Audi dealership, so it had been gone through. Belts inspected and changed, fluids changed, new tires, etc. As long as the car has had recent maintenance, there shouldn't be any issues with an 8 hour drive.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Jul 19 2024
    F150 Raptor, 4Runner, Silverado... past- 991, NSX, e36 m3, e46 m3, e92 m3, OG M2, multiple STIs
    Hudson Valley NY
    low mileage s5
    Quote Originally Posted by John@Nemesis View Post
    Yep. I have a 2011 S5 with 24k miles. I've also bought, owned, and sold many other ultra low mileage "weekend" cars that were 10yr, 20yr, + yrs old. In addition to the Carfax and service history of the car, some of the key things I look at to validate mileage include seat bolster wear, wear on the pedals, steering wheel, shift knob, audio controls, situation with the tires, undercarriage, etc. My best advice would be "buy the seller".
    Nov 15 2014
    Las Vegas, NV
    Quote Originally Posted by feelgood View Post
    Exactly. Just have to pay attention to the little things. My 911 had 2300 miles on it when I bought it. CPO, so wasn't concerned. People have different uses for their cars than daily drivers. Hell, all mine sit in the garage the majority of the time. My wife and I both have work trucks, 95% of the time we're in the work truck.
    OP, post some pics when you get it home.
    AKA: Hippiekiller
    2015 Sepang Blue S5
    [email protected]
    @hewhohateshippies
    Dec 20 2012
    Funny, my 911 had ~2300 miles (3800kms) on it when I bought it 2 weeks ago. Also a CPO car.
    Nov 15 2014
    Las Vegas, NV
    Mine had passed through a few more owners than I would care for. But it is PTS and slick top with a manual...couldn't pass it up. If you get the itch to modify it, give me a shout. Enjoy the car. They're meant to get driven.
    AKA: Hippiekiller
    2015 Sepang Blue S5
    [email protected]
    @hewhohateshippies
    Jan 22 2019
    Williamsville, NY
    Well @dsmp any updates?
    Jun 18 2018
    Calgary
    Going to pick it up Monday! Stay tuned.
    Jun 18 2018
    Calgary
    Picked her up today. She drove like a dream. Seems fully legit. The guy is an RCMP officer as well.
    Dec 20 2012
    Congrats
    Jun 18 2018
    Calgary
    Here is what I’m thinking for a start for tasteful mods
    Rims/tires. Keeping stock height and size
    Tint
    Roof rack maybe? My son and I mtb a ton
    Single pulley.
    Dec 20 2012
    I could write you a book on the things you can do to the B8.5 platform.
    Nothing wrong with your list as a starting point. But IMO a 20" wheel and tire combo fit this car better. 275/30/20 square on a 10" or 10.5" wheel with an ET of ~25 looks awesome on this car.
    If going single pulley stage 1+/2 tune you should tackle the exhaust to make it breathe a little more freely. H-pipe and a center resonator delete would yield decent results and not be too spendy.
    I could go on and on. DTS, transmission and diff inserts, intake, adjustable sway bars...
    Jun 18 2018
    Calgary
    Sweet thanks. I had a 2015 S4 back in 2015-18 but it was a lease and I didn't feel like modding something I wasnt going to keep. I used to stay up to speed on what everyone was doing but I lost track and there is so much info on here it's hard to sift through it all.
    I am stuck on a wheel I like, but they only come in 20x9 25ET - perhaps that would look a little better than the 19x8.5 stock option....
    https://wheelwiz.ca/fr/products/r318...Dl_xc3nbDDJQ5m
    Dec 20 2012
    If you are looking for a flush fitment, you will need to run spacers with those wheels. I avoid spacers at all costs but that is a personal preference since they can introduce vibration, but more importantly, they add unsprung weight.
    I just put 2 and 2 together and realized you are a fellow Canadian. Where are you located?
    Jun 18 2018
    Calgary
    Calgary... you? Unfortunately, I am on a bit of a timeline to find wheels/tires as I need an out of province inspection before I can register the car, and the tires on the originals and they're cracking so wont pass.
    I've been to two tire/wheel shops both said hard no in Calgary on 20s as the roads are too shitty. I def don't want spacers...
    Dec 20 2012
    I am in Vancouver. My son lives in Calgary.
    Yeah, 20's with low profile tires isn't ideal in Calgary for a daily driver.
    Since 19's are the sweet spot for you just get the OE 255/35/19 tires so you can pass OOPI and continue your search for wheels until you find "the ones.". You're only be out the cost of mounting and balancing but worth it to find the right wheels.
    Jun 18 2018
    Calgary
    Took your advice to get rolling and wheels and tune go in Tuesday! Thanks.
    What would you say is more important, intake or exhaust? I will eventually do both but I’m leaning towards exhaust first just trying to spread out my spending.
    Dec 20 2012
    Well, that depends but typically both are important as they allow the motor to suck and blow better.
    The stock airbox is decent if you change the filter to one that is less restrictive. The in engine bay intakes are often called Hot Air Intakes because they will suck hot air from the engine bay which is the last thing you want. This might not be an issue if you are only going occasionally go for a spirited drive, but ideally you want an intake that draws cold air from outside. APR, 034 and others make enclosed intakes that draw air from outside the engine bay.
    I would go with an exhaust first since you also get the enjoyment of better noises.
