Hey, so maybe the car really is overheating.
I think one place we should be looking is at the radiator itself. How old is the unit that's in there? If it's clogged or scaled up, then it might not be operating efficiently anymore. Your symptoms of overheating while not moving, even with the fans cycling on, might indicate a problem like that. If it was a faulty sensor, then you'd be just as likely to see the temp gauge climb while you're coasting down a hill on a highway at 70 mph as you would be sitting in a drive through behind a drunk college kid while he argues for 10 minutes with the unfortunate Wendy's drive-through person because he wants a "Big Mac", and he knows he's at McDonalds.
Let's talk coolant, too. Do you use the appropriate coolant that matches the Audi specifications? Preferably coolant sold by Audi? If not, then we need to look at the radiator even more closely, because you could have mixed incompatible coolants in there. There's some sciency stuff that happens when you mix the wrong coolants, and I don't fully understand it--I just know not to do it. Maybe they react and form solids that block coolant passages?
Is there air in the cooling system? I had this issue on my own car. I ran it on the dyno, and it overheated almost immediately. I drained and then vacuumed the system and refilled it. No issues after that.
How's the thermostat? Is it new? Regardless of age, let's make sure it's not getting stuck closed. If you're removing it to check it, you might as well just toss it in the trash and put a new one on.
egovreau made some very good points--check to see that the impeller is still firmly attached to the water pump, and check to make sure you're not dealing with a cracked cylinder head. The fact that the car cools off while you're moving suggests to me that the impeller is at least moving water (i.e. not completely detached), but it could be slipping, or broken, or something. Check on the J-plug to make sure it didn't disintegrate into that cavity and damage the impeller (I seem to remember that the J-plug is like... right there behind the pump.) My own J-plug came out of the engine when I rebuilt it in pieces. It literally crumbled into pieces.
If you really are experiencing overheating, and not just erroneous temperature readings, then it's best to figure that out as soon as you can so that you can avoid damaging the car. I had an overheating issue when I drove my car on the race track early on. To be honest, I'm not exactly sure what caused it, because once it ruined two track days, it had lost me enough money to warrant ripping the whole system out and throwing it away. New radiator, thermostat, even the oil cooler. Something fixed the issue, because it doesn't overheat anymore.
Good luck. Keep us informed.
Edit: I reread and saw that the thermostat is 3 years old. I also saw that Gunnnarrrr posted some good stuff that wasn't there as I was writing this. Good advice there. I agree that doomsday cracked head should be last on the list of things to worry about--go after the low-hanging fruit first.
