Originally Posted by
willemml
Something is wrong with my key/module though because it unpairs every other time I get out of the car (have to repair almost every drive cycle... I just don't bother locking it anymore.)
I had one like that. I replaced with another FOB and it has worked fine on same car ever since. Probably a crack or corroded joint in the bad FOB. Note that you can change out the FOB portion of the key, leaving the immobilizer RFID unchanged. Check the FCC ID on the board if replacing and get another that matches. Cheap clone keys I tried off amazon had wrong version of board and would not work, better to go with a used A4 key. Agree, no need to use VCDS for FOB pairing, plenty of tutorials on Youtube if you need that.
